Old 08-20-2013, 12:13 AM   #3095
Luis_GT
Thanks to my friends from SubaruSense
The Following 4 Users Say Thank You to Luis_GT For This Useful Post:
chanomatik (08-20-2013), Pablitomarrero (08-20-2013), SurfAndSand (08-20-2013), TRD-X (08-20-2013)
Old 08-20-2013, 12:30 AM   #3096
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by Anaxilus View Post
Per JDM tradition, cryptic. Of options unmentioned, my hope is for TRD USA to release a sorted S/C kit based on the World Challenge FR-S kit.
torqdork is offline   Reply With Quote
Old 08-20-2013, 09:34 AM   #3097
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by JSMIL View Post
Mine is more like a click and loud gear noise on acceleration, as if there is play in it somewhere. Well I am going into the dealer tomorrow to have the chirping looked at anyway. They better not try and give any run around either. I am going to keep making noise up the chain until it is fixed for good. I don't care how many fuel pumps they have to replace!
Good luck with that. Some people who have stuck with their original pumps are seeing the crickets fade once they get past the 10k mark. At this point, replacing the pump only prolongs how long your car will have crickets.
It has priests in it?
Old 08-20-2013, 10:53 AM   #3098
Enthalpy
Drives: FR-S 10 Series/'93 RX-7
Has anyone else noticed some drivetrain slop in theirs. It is definitely evident in first and second gear on mine. Feels like when I had a bad driveshaft in my RX7 and it had a little play in it. The transmission is very noisy and sounds like a transmission with some serious milage on it instead of a new car. Just curious if anyone else has noticed this. It could be normal for these cars, but I am not used to it.
RX-7s tend to have a lot of drivetrain slop, even with a new driveshaft (FD owner here). A lot of that comes down to tuning, since rotaries do not handle low loads as well as piston engines. I actually notice two "jerks" on my 7, one is due to the injectors cutting off rather abruptly when closing the throttle plates (ecu limitation...), the other feels like stored energy in the powerplant frame is being released to the differential casing. The second jerk is likely caused by the first.
I have noticed that yes, the FR-S' drivetrain can be seen as a little loud if you compare to many other modern cars. Compared to a modified FD, our twins' Aisin may as well be silent (to me). NVH with the twins is far, far less than an RX-7.
Not saying your situation is normal. Hard to convey loudness through typing. Not sure what was done to your FD (or FR-S), but 7s typically have a lot of NVH. I wouldn't expect the same level of roughness.
Enthalpy is offline   Reply With Quote
The Following User Says Thank You to Enthalpy For This Useful Post:
JSMIL (08-20-2013)
Old 08-20-2013, 11:24 AM   #3099
PSORngr
The drop into first from neutral can be loud sometimes for me, same goes for first into second. I didn't think too much about it though since it's my first manual car in a long time and I just don't remember the two manual vehicles I'd learned on enough. My motorcycle (Kawasaki Versys) also has a loud and noticeable "clunk" when dropping into first from neutral, but I know that is normal for that transmission (everyone with a Versys comments on it).
PSORngr is offline   Reply With Quote
The Following User Says Thank You to PSORngr For This Useful Post:
JSMIL (08-20-2013)
Old 08-20-2013, 11:53 AM   #3100
Obsidiank
10 Series Fanatic
Drives: Scion FR-S 10
you guys are forgetting that this forums represents just a small fraction of BRZ/FRS owners who know/care about what chirps are.
I saw a BRZ yesterday and the guy started up and it was chirping like crazy. I was like, how do you feel about the chirp and he looked at me like, wtf you talking about. I told him and he was like, oh, I figured that's just the sound the car makes.
Obsidiank is offline   Reply With Quote
The Following 2 Users Say Thank You to Obsidiank For This Useful Post:
chanomatik (08-20-2013), HotLeopardMama (08-20-2013)
Old 08-20-2013, 02:07 PM   #3101
HotLeopardMama
Hello Kitty FRS ^_^
HotLeopardMama's Avatar
Yeah, I think I went a couple thousand miles before I caught the crickets. I'm at almost 18,000 miles and still chirping, but if it ain't hurting nothing, I'mma leave them. :-\
2013 Scion FR-S Whiteout AT owner since June 2, 2012 - #2803
RS*R Sports-i Coilovers & LCAs|OEMaudio+ Reference|Milltek Exhaust|OZRacing FormulaHLT Wheels|Downforce CF Lip Kit|Beat-Sonic Fin & Roof Spoiler|Cusco Rear Subframe Brace
My Build Thread|Tuesday Night Irvine DJ Meet|@HotLeopardMama
HotLeopardMama is offline   Reply With Quote
Old 08-20-2013, 03:25 PM   #3102
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
more like a clunk when I gear out to neutral or change gears. Doesn't bother me
Mine does a chattering noise sometimes when shifting 4th 5th and 6th at about 4500 RPM
yes...I get this too.
Pablitomarrero is offline   Reply With Quote
Old 08-20-2013, 05:43 PM   #3103
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
Well I took my car to the dealership and they were great! They tightened every bolt on the undercarriage, including the drivetrain of the car. They then said they would order the fuel pump and all of the gaskets needed and change it tomorrow. He said he has changed 4 fuel pumps to the new ones and that fixed the problem on them all. When I left the dealership all of the slop in the drivetrain was gone, including the clink the rest of you described when changing gears. Me an the mechanic think it was a combination of loose bolts. My bet is on the transmission mounts. She drives smooth now. Hopefully this fuel pump fixes the crickets, but if not they said they will continue to work the problem until they are gone. The mechanic told me if he just paid $30k on a new car, he would want those crickets exterminated too.
JSMIL is offline   Reply With Quote
Old 08-20-2013, 06:27 PM   #3104
torqdork
torqdork's Avatar
Drives: RV-7
JSMIL, glad they're fixing you up!
Of those with suspected driveline clunks and tranny noise, how many still have the OEM exhaust? It might be part of the problem. I haven't had any of those symptoms running a Perrin catback. Their midpipe design is radically different than stock with a flexible mesh coupling about 4" long at the front end that might decouple NVH compared to the rigid OEM midpipe joint shown on the left. The Perrin system is also two pipes joined with another coupling back to the muffler effectively doubling the resonant frequency by cutting the beam length in half compared to the stock one piece system. I only had the stock exhaust on for an hour, not long enough to notice anything unusual, so this prolly a short-lived theory.
The Following User Says Thank You to torqdork For This Useful Post:
JSMIL (08-20-2013)
Old 08-21-2013, 09:21 AM   #3105
JSMIL
JSMIL's Avatar
Not sure if you guys saw this, but looks like the only updates the 2014 FRS is getting will be the knee pads. No engine upgrades, no interior upgrades except for knee pads and the new stereo we have, and they are not getting our headlights as an option! Congrats on having a unique vehicle for at least another year!
http://www.motorauthority.com/news/1...price-increase
Old 08-21-2013, 10:34 AM   #3106
frs10
Drives: tezla
wasnt all the new updates for the 2014 posted in the scion blog already?
http://www.scion.com/blog/2013/08/15...or-all-models/
frs10 is offline   Reply With Quote
The Following User Says Thank You to frs10 For This Useful Post:
JSMIL (08-21-2013)
Old 08-21-2013, 12:35 PM   #3107
JSMIL
JSMIL's Avatar
Yeah, I didn't read the blog, I just saw the article.
Old 08-21-2013, 12:41 PM   #3108
frs10
Drives: tezla
anyone with a 10 series get the TRD exhaust/air intake/fog lights installed by dealer?
2014, brz, fr-s, gt86
Limited edition WedSports GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-17-2013 03:03 AM
Limited Edition FT86 Oil Cap #127 phenom86 Engine, Exhaust, Bolt-Ons 2 12-12-2012 05:30 PM
Toyota TRD GT86 Special Edition Announced for UK Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 56 07-18-2012 12:23 PM
Limited Edition Colors? bambbrose Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 04:23 PM
