Old 08-17-2013, 12:11 PM   #57
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Finally have a build thread of sorts going. Scroll to the bottom of the first post and then the following couple for a bit about the AVO now. I'll be adding more as I drive it more and get more of a feel for the car. Right now it's just one word, unbelievable.
http://www.ft86club.com/forums/showthread.php?t=44302
nataku is offline   Reply With Quote
Old 08-17-2013, 12:25 PM   #58
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Looks like my kit will arrive Tuesday according to the tracking page
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (08-17-2013)
Old 08-17-2013, 08:54 PM   #59
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My half assed build thread lol
http://www.ft86club.com/forums/showthread.php?t=44575
Old 08-17-2013, 09:00 PM   #60
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
18 eh? Haha totally kidding.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-17-2013, 10:27 PM   #61
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by spitfire481 View Post
Added.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
nataku (08-18-2013)
Old 08-19-2013, 11:10 PM   #62
DAMotorsports
Drives: 2013 Scion FRS "Raven"
@Tansey86 we are happy to see you like our meaty tire set up. we will be posting a full build soon and we hope to answer all of your questions. as you can see we are also run and proudly support AVO
DAMotorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to DAMotorsports For This Useful Post:
nix (08-20-2013), Sportsguy83 (08-19-2013), Tansey86 (08-19-2013)
Old 08-20-2013, 06:10 PM   #63
nix
nix's Avatar
Drives: AVO BRZ
Just went through all the fittings/hardware on the Turbo/manifold assembly. Some parts were barely snug. Definitely check everything, would have had a ton of issues if it was just thrown in the car that way.
That is intentional I think from AVO so that once its on the car and the exhaust is in place, you can tighten everything while you lever the over pipe as high as possible for extra clearance.
nix is offline   Reply With Quote
Old 08-20-2013, 07:42 PM   #64
spitfire481
Drives: 2JZ FRS
You can't get to half of the bolts clearance wise once the assembly is in place
Old 08-20-2013, 09:16 PM   #65
Sportsguy83
Drives: Limited BRZ
Yeah, I had the same thing happen.
Old 08-20-2013, 11:01 PM   #66
DAMotorsports
When we installed our kit, I tightened everything and did not have any problems. We did some track testing and blow the inlet gasket. Talked with Paul and a buddy of mine and found a set of locking nut plates that should fit to help stop the nut from backing out. Ill post the part numbers on Thursday once they arrive and I can confirm they work.
The Following User Says Thank You to DAMotorsports For This Useful Post:
Pitman (08-21-2013)
Old 08-20-2013, 11:47 PM   #67
nix
nix's Avatar
Drives: AVO BRZ
We did a few mock fits and tightened everything down in stages, there was a few mm of tolerance, but in my case not enough for Perrin over pipe clearance under full load. Now with STI engine mounts, the over pipe barely moves.
The Following User Says Thank You to nix For This Useful Post:
DAMotorsports (08-21-2013)
Old 08-21-2013, 12:22 AM   #68
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Maybe sooner than later
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following 5 Users Say Thank You to Mr.Jay For This Useful Post:
FrX (08-21-2013), ftc~brz (08-21-2013), SkAsphalt (08-26-2013), Sportsguy83 (08-21-2013), zuldajin (08-21-2013)
Old 08-21-2013, 01:26 AM   #69
DAMotorsports
@mr_jay
Old 08-21-2013, 01:26 AM   #70
nataku
Negative Mass
nataku's Avatar
Not really a complaint as much as an observation but, did any of you guys buy the blow off valve? I got it because I wanted that hissing when I shift (what can I say I care about stupid things like that). Anyway I don't even hear a peep out of it at any point, even if I redline and just let off completely. Is it just something that doesn't do much until I up the boost?
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
