Old 08-18-2013, 11:44 AM   #1
GTS 86
Drives: Tornado Grey 86 GTS AT
Help! Trim clips lost down inside chassis!
So basically in accordance with this thread, http://www.ft86club.com/forums/showthread.php?t=10002 I lost trim clips and they fell down inside the gap in the boot/rear area and are now somewhere inside the side of the chassis rattling around in the doors. Any ideas how to remove these? (get inside the rail that runs under the doors) or stop them from rattling? Cheers guys for any help Driving me nuts and i'm starting to hate the car
GTS 86 is offline   Reply With Quote
Old 08-20-2013, 04:59 PM   #2
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Could you not spray some type of wax anti-corrosion aerosol into the box section? Then, when it dries, it 'should' stick the clips down, stopping them from rattling.
Dave
Pitman is offline   Reply With Quote
Old 08-25-2013, 03:41 PM   #3
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Maybe a strategic application of some of this stuff might help "trap" the clip
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-26-2013, 10:50 PM   #4
wjamin
Drives: GTS86
If you take off the rear plastic panel (where the rear speaker is), you will see a big hole where the rear speaker is.
Stick a small torch and a camera in that hole and start snapping, you may be able to find clip in there some where.
To get it out, I used a double sided tape (foam type) at the end of TWO coat hangers stuck together to get it out. I needed two coat hangers as it was too deep
First picture shows the clip near the front wheel arch, the second photo show the clip on the double sided foam tape.
I think I took about 30 photos trying to get close to the clip.
wjamin is offline   Reply With Quote
The Following User Says Thank You to wjamin For This Useful Post:
|-Goku-| (09-05-2013)
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
WE LOST :( Johnp Scion FR-S / Toyota 86 GT86 General Forum 47 03-29-2013 04:10 PM
WTB: OEM Shifter Trim Piece Not Knob (pic inside) jadu Interior Parts (Incl. Lighting) 1 02-01-2013 02:55 PM
Need Help... Missing Clips NoLeftHere Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2012 12:13 AM
im lost... lol _F-R-S_ Mid-Atlantic 2 10-07-2012 11:04 PM
