Old 08-20-2013, 02:34 PM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Best FI for 91 gas?
I'm in LA and it's inconvenient for me to find an E85 station and 91 is the highest we got.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 08-20-2013, 02:44 PM   #2
sw20kosh
Drives: 2013 Black FR-S
91 gas doesn't limit what kit you can get. It limits what boost level you can run and how much power you can make vs. better fuels.
So all the stage 1 kits will work fine.
All these kits are sold with a base map that will run safe on 91. Id recommend that your tuner should have a look at the ecutek data logs to make sure everything is safe.
Old 08-20-2013, 02:57 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Electric supercharger.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
NickFRS (08-21-2013), suaveflooder (08-20-2013)
Old 08-20-2013, 03:06 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Up to 1.5 minutes of continues boost
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 08-20-2013, 03:13 PM   #5
nonicname
Drives: it has 4 wheels and a motor
non! move to a normal state.
nonicname is offline   Reply With Quote
Old 08-20-2013, 05:12 PM   #6
retrosmiths
Sorry, I meant which kits would give me the best results given only 91 gas?
2013 Scion FR-S
Old 08-20-2013, 05:24 PM   #7
tahoward
tahoward's Avatar
Drives: Firestorm FR-S
That's going to be kits that charge with the least parasitic power loss. I.E. Best bang per pound of boost.
If you are OK with a NOS like boost experience the electric supercharger phantom is working on looks to fit the bill.
For continuous boost next down the list is a turbocharger then supercharger. Look at AVO or Vortech/Innovate, there are several dyno's from 91 tunes for those kits floating around this forum.
In the end you will be limited by the maximum amount of boost you can cram into your engine based on the octane rating of your fuel and how prone it is to detonation.
Also, 'best results' is something that can be a subject matter of contention between members here. You may want to describe what 'best' means for you. I.E. top high end power, down low, flat, roller coaster...etc...
tahoward is offline   Reply With Quote
Old 08-20-2013, 05:42 PM   #8
fenton
I know your trying to be funny but the electric supercharger actually requires very good gas as it makes 5 psi at 2000RPM and generates a huge amount of load because of it.
Currently the system gets 3.8psi at 5250 rpm and 2.3 psi at 7000rpm...not to shabby for 1500 bucks not to mention its the only 1500 you can spend and get 80 ft/pd torque increase and 50 hp
fenton is offline   Reply With Quote
Old 08-20-2013, 05:49 PM   #9
Dipstik-sportech
Dipstik-sportech's Avatar
Pretty sure I could buy a nitrous setup for way less than 1500$ and make more power but to each their own.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Freeman (08-20-2013)
Old 08-20-2013, 05:50 PM   #10
OrbitalEllipses
Drives: Attitude
No FI would be best results.
Old 08-20-2013, 05:58 PM   #11
sw20kosh
Again that is so subjective. "Best results" could mean a lot of things.
I am going to assume you mean peak whp numbers. In that case grab the kit with the biggest turbo you can find. You can make the most whp with low boost with this type of set up. Will you enjoy daily driving it? Debatable.
The Following User Says Thank You to sw20kosh For This Useful Post:
JackSmiley (08-21-2013)
Old 08-20-2013, 06:04 PM   #12
fenton
You may very well be able to however i will never ever have to re fill my supercharger with juice. No bottle warmers, and safety switches needed. No lines running from trunk to engine.
Initial cost may be a little less for NOS but overall i would have used like 30 bottles of the stuff in the last 5000km.
Old 08-20-2013, 06:06 PM   #13
fenton
That isnt even remotely helpful....sometimes i wonder.
To the OP the lower boosted kits will be best. AVO or innovative are my two favorites right now with the BASE FA20club kit a close third.
Also think about adding water meth to increase the knock threshold and reduce the charge temp if you go with innovative.
Old 08-20-2013, 08:05 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I was trying to be funny. The fact is that it doesn't matter what octane fuel you have available to you. Pick the kit you want and run as much boost/timing as the fuel you use will allow. I would tell him to buy a Full Blown kit, but everyone knows that.
fenton (08-20-2013)
