Old 08-19-2013, 09:49 AM   #1
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
running fully independent suspension
Is anyone or has anyone experimented with running without the front and rear stabilizing bars? If so what spring rates have you tried? how snappy does the car get under aggresive or track conditions? What shocks are you using to compensate and how are the tires holding up to the load changes?
no sways is a common mx5 debate for gaining grip without rediculous camber or tire width. i'm hoping at least one person has considered or tried it. i haven't.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
The Following User Says Thank You to BadCompany235 For This Useful Post:
u/Josh (08-20-2013)
Old 08-20-2013, 08:54 AM   #2
BadCompany235
#TrackAddicts
90 views and no comments. i guess i should direct this at the suspension developers.
Old 08-20-2013, 09:32 AM   #3
Turdinator
Señor Member
Turdinator's Avatar
I believe @robispec runs his race car without a rear stabiliser to get more droop. But he is the only person I have read about doing this on here.
1974 TA22 Celica
2013 86 GT
Old 08-20-2013, 10:14 AM   #4
For a dedicated track car you can make it work without a rear bar. Spring rates will get a bit stiff and there are drawbacks.
I wouldn't bother running without a front bar for sure.
- Andy
Old 08-20-2013, 08:23 PM   #5
xwd
Phil @ Element Tuning ran his Time Attack car with no rear bar as well. Also for droop and found when running over curbing the LSD wasn't working as well. I think he is running 12K springs.
People have also tried it in autocross but not real successfully. Front strut suspension definitely wouldn't run without a front bar.
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
fully loaded 86 is 34k $ here :( beirouty Scion FR-S / Toyota 86 GT86 General Forum 42 12-20-2012 04:02 PM
Fully Loaded FR-S! Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 39 07-17-2012 12:52 AM
BRZ fully detailed (video) ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-18-2012 10:33 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
