Old 08-19-2013, 10:44 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
My E39 came with an Intake Res, whereas the E46, which has the same exact engine, didn't.
BMW may have added improvements in the intake manifold, runners, secondary valves in runners, or ECU tune to remove the need for an intake resonator.
There's many reasons beyond what you can see on the outside.
-alex
Old 08-19-2013, 10:48 PM   #16
Luis_GT
-alex
Same Engine, Same HP and TQ numbers, built at the same time... only difference... one marketed as an upclass sports saloon (quiet) the other is a sports coupe, sedan or vert.
Old 08-19-2013, 11:21 PM   #17
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Why do most aftermarket intakes do without resonators? To achieve max performance gains, with droning and emissions as secondary concerns.
http://www.ehow.com/info_12156112_ai...onator-do.html
The link talks about performance, but this also ties into the primary reason: stock ECU tune for maximum balance of performance/reliability/emissions.
OE intakes are designed that way for a variety of reasons, many are related to actual driving comfort of occupants in the vehicle from what we can hear/tell. A lot of aftermarket exhausts have annoying sounds at specific frequencies because of lack of sound tuning for this reason.
Just because it's TRD doesn't mean it's Toyota's aftermarket gift to this car.
-alex
I think the only reason the FR-S has a resonator is because of the sound tube.
Be it a TRD intake or any other brand they don't have a resonator because these intakes delete the sound tube so there's no need for a resonator.
I can check with Toyota Corporate about this to make sure this is why the stock intake has a resonator.
Old 08-19-2013, 11:28 PM   #18
mav1178
mav1178's Avatar
Aside from sound, the chassis is different... so the platform and conditions under which the car is designed is different.
Also, I'm willing to bet the gearing and final drive, as well as suspension (wheel) specs all play a role in how the engine intake is tuned.
Splitting hairs here but the main thing is, it's not just as simple as sound to most of us.
-alex
Enthalpy (08-20-2013)
Old 08-19-2013, 11:37 PM   #19
Luis_GT
-alex
Non of that has anything to do with a engine intake resonator, now you're just talking non-sense
The Following User Says Thank You to Luis_GT For This Useful Post:
InvalidJohnny5 (08-19-2013)
Old 08-19-2013, 11:51 PM   #20
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Leave him alone Luis, he used to drive a Camry. Let him feel professional.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
The Following 3 Users Say Thank You to InvalidJohnny5 For This Useful Post:
Luis_GT (08-19-2013), Symmetrical (08-20-2013), TRD-X (08-20-2013)
Old 08-20-2013, 12:06 AM   #21
OrbitalEllipses
Drives: Attitude
No one likes Mav, it's okay.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
ftc~brz (08-20-2013), Luis_GT (08-20-2013), TRD-X (08-20-2013)
Old 08-20-2013, 12:41 AM   #22
WOW - you folks are informative and fun .....
@campy - thanks for the diagram idfentifying the part.
@mav1178 - thanks for the link with the information.
@dsrttigr - so that's where they keep the cricket feed (I fixed them up, by dusting some DDT into the intake).
@TRD-X - now, I didn't fall off the pumpkin wagon here in Puyallup .... I do know that the flux capacitor is part of the electrical system....cause the black box didn't shock me.
@BANGER - no..no..no ... cause it doesn't have a yellow cap.
@Luis_GT - are you bi-polar..??? (jest ah messen wich ya).
@djleepanda - are you from the south .... ??
Well, thanks all .......... :happy0180:
This seems to explain it pretty well:
From the reference:
"The Resonator
Adding an expansion chamber to the intake tube forces air coming back out of the engine to slow down to fill the cavity, thus expending a great deal[IMG]file:///C:/Users/Roger/AppData/Local/Temp/msohtmlclip1/01/clip_image002.png[/IMG] of its energy and slowing the pressure wave reversion. This slowdown allows fresh air to flow toward the engine without fighting pressure reversion waves the entire way, thus aiding in cylinder filling. Since these pressure waves are essentially sound, giving them a place to expend their energy before exiting the air filter box ends up dampening the intake noise and quieting the engine. Thus, the resonator helps to make the engine paradoxically quieter and more powerful."
Thanks again.......
PS - no one mentioned it might be a muffler bearing .... ??
TRD-X (08-20-2013)
Old 08-20-2013, 12:43 AM   #23
Luis_GT
@dsrttigr - so thats where they keep the cricket feed (I fixed them up, by dusting some DDT into the intake.
The Resonator
Thanks again.......
I happen to have mood swings... you feeling lucky, punk!
Old 08-20-2013, 01:11 AM   #24
djleepanda
Panda
djleepanda's Avatar
Drives: 2013 Subaru BRZ
From the reference:
"The Resonator
Thanks again.......
It was a joke....
2013 Subaru BRZ Limited Satin White Pearl
Mods:
Invidia N1 Cat-back Exhaust System
Injen Power Flow Short Ram Intake (Black)
djleepanda is offline   Reply With Quote
Old 08-20-2013, 02:12 AM   #25
mav1178
mav1178's Avatar
They do, because again they're part of platform design goals. Yes it's just noise to you but that is one part of the unknown.
As for the other personal insults, keep them coming. It's entertaining to see what some people are like on here.
-alex
Old 08-20-2013, 02:19 AM   #26
Luis_GT
-alex
Right design goals other than suppress noise... keep thinking that... mean while, I just drop in the E46 intake tube and have glorious intake noise.
PS, a 330i Engine and transmission is plug and play with my 530i.
Old 08-20-2013, 02:50 AM   #27
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by TRD-X View Post
It's where they mounted the flux capacitor on the FR-S.....
What is funnier is that car wont hit 88 in the quarter mile
The Following User Says Thank You to ZionsWrath For This Useful Post:
TRD-X (08-20-2013)
Old 08-20-2013, 02:56 AM   #28
Symmetrical
Symmetrical's Avatar
Drives: 2013 DGM BRZ Limited
Yeah after seeing a bunch of his posts, all he wants to do is look superior to everyone. Everybody could appreciate a knowledgeable person, sure, but to always come off as a Mr. Know-it-All is really getting old.
Symmetrical is offline   Reply With Quote
mav's sandy lady parts, resonator
Piano Black Dash Panel and Black Traction Control Button? stoneman155 Cosmetic Modification (Interior/Exterior/Lighting) 13 10-02-2015 11:09 PM
XXR527 Chromium black 18x8.75 Hankook Ventus 225-40 Black BRZ random hero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 02-14-2013 12:20 AM
ADVAN RSII 18x8.5 & 18x9.5 (Hyper black / Semi-Gloss Black) - in stock! Touge Factory Wheels and Tires 13 01-15-2013 07:43 PM
Oakley Halfjacket 2.0 Polished Black with Black Iridium lenses. Zadkiel Miscellaneous 8 12-02-2012 01:51 PM
SoCal: 2004 S2000, Black on black, 70k miles, 16.3k OBO Mike Cars for Sale/Trade 0 08-01-2012 07:54 PM
