#29 | |
#30 | |
This is something I've been interested in for years but never had the time to get too into. I've been following others work. We generally don't touch our damper settings too much once we dial them in BUT this is still very interesting to me. Even in that small window around "critically damped" there is some potential to work with when it comes to street and track settings (i.e. soft and not bouncy vs. firm and controlled but also not exactly Baltimore city friendly). And it's a Bilstein, so it's a good shock. I think it's cool. I'd love to do some testing but our car has been occupied with testing our own stuff for a while and will be getting another round of track mods soon so not sure when we'd get a chance. - Andy |
#31 |
Drives: FR-S stock for now
To get true regressive damping using the Damptronic shocks would require more sensors to know shock velocity/time and that may come but for now I'm trying to offer the average driver a way to have a soft ride on the street and good control in the turns. This is not MR fluid so you still have a normal valve stack with a solenoid controlled orifice everything is reactive to sensor inputs probably could add some high pressure internal valving to deal with high velocity venting. I don't think many street customers run 1200lb springs to need regressive control, where do you run your car to need this much control?
DougW |
#32 | |
I'm waiting for details
#33 |
What else you need to know?DougW |
#34 |
Is this system calibrated to one specific valving of the Bilstein damper? What kind of setup time is there to re-calibrate the system to a different valving/driver? When will it be available? What is the expected MSRP?
#35 |
The system uses a Windows interface that lets you recalibrate the response to sensor inputs so in effect the shock hard valving sets the profile range but not actual curve. Think of it as an adjustable manual shock with real time changes to the knob clicks per corner based on sensors and maps, see the graphs above. Setups are usb edits including data logging with simple downloads. Working to have some more kits in the next couple of months, they take only a few days to remachine but I want to get VIR testing before I build more. Depending on Bilstein I plan on $3200 as the retail if Bilstein helps with cost then it can come down. This includes the 4 shocks, wiring harness, controller and software plus the base curves we come up with. I hope that over time people can swap tuning data just like ecus, this should be the last set of shocks you would need to buy.
Hope that helps DougW |
#36 |
Because compromise ®
Drives: Red Herring
Impolite question coming up (apologies to DougW):
@CSG Mike. What do you think of the potential of this? I appreciate it is early days yet but do you think this might offer less of a compromise than a traditional damper/spring set up? @DougW Would there still be an option (would there need to be this option) of offering a package with stiffer springs for those who are wanting a more track orientated setup? |
#37 |
Because of the higher cost and ride I stayed with the stock springs these shocks on a GTR control 1200 lb springs without issues. The problem with sanctioned racing they are not legal as an "active suspension" in most classes. Impolite question coming up (apologies to DougW): nothing wrong here. ask away.
DougW |
#38 | |
It all depends on how well the system is calibrated, which is where my questions stem from. Theoretically, this would be "perfect". The actual execution is what I await. |
#39 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Ha! You could have a different suspension "tune" for each track!!
#40 |
#42 |
Stock so I believe they are 275lb I didn't measure them, You can have a different damping rate per corner of the car per corner of the track. If GPS was faster and reliable the software hooks are in place to track map at some point.
DougW |
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| Bilstein Damptronic on an FRS | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-10-2013 12:15 AM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Brakes, Suspension, Chassis | 24 | 07-31-2013 01:52 PM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Wheels and Tires | 24 | 07-31-2013 01:51 PM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 03:12 PM |
