Old 08-19-2013, 09:11 PM   #127
mike the snake
How do these turbos compare to the GTx28?
I'm hoping to hit 350whp someday, but probably will start out with what i can get on 91, then later upgrade clutch, radiator, oil cooler etc (Actually, radiator will go in when I do the turbo install).
Originally Posted by Ross View Post
For pump gas of poor quality look at the 30r not the 35r. The 35r will not shine until higher pressures. Gt3071 or Gt3076 (for the garret gt options) would not be bad to look at. Also recommend looking into a meth kit.
Old 08-19-2013, 09:50 PM   #128
Ross
Drives: 85 corolla gts
They have a higher flow rate and are larger. They will not spool as quickly. You can hit your goal with a properly sized gt28 and gtx28 series turbos but not on stock compression and 91 octane. If you plan on dropping compression and turning boost up I think it could be doable, no problem with the smaller turbos. Even with the larger turbo's and 91 octane you will not see that power on the stock compression. If e85 or meth injection is an option it will definitely help you get to your goal with stock compression.
Ross is offline   Reply With Quote
Old 08-19-2013, 10:37 PM   #129
mike the snake
I live close to Sears Point, so I can get race gas when I want, and WMI is also an option.
To start I'll probably go with a 91 tune and a race gas tune, then when I go for "stage 2" I'll add Meth and clutch and other parts to make it handle the bigger power safely.
I know I won't be going crazy, I'll be happy if I get to 350 but will probably be fine with 275 for 91 and whatever I can get with WMI or race gas.
Old 08-20-2013, 06:40 PM   #130
1slowbrz
1slowbrz's Avatar
Drives: 2017 WRB BRZ PP
Originally Posted by pixel67 View Post
So how is the kit working out for you now?
Sent from my Nexus 7 using Tapatalk 2
It's running awesome, finally had a day off to jump on the dyno and do some quick logs, put down 251 whp and 199 lb ft without any fine tuning on 93.
Can't wait to finally turn it up, 250hp was cool but it got old fast!
1slowbrz is offline   Reply With Quote
The Following User Says Thank You to 1slowbrz For This Useful Post:
pixel67 (08-20-2013)
Old 08-21-2013, 06:51 PM   #131
peteralfonso
Drives: Scion FRS
Is this on the base tune of 93 octane that ships with the kit? What other performance mods do you have?
Sent from my SGH-M919 using Tapatalk 4
peteralfonso is offline   Reply With Quote
Old 08-21-2013, 06:56 PM   #132
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Going on waiting on the 5th week since kit has been ordered...can't wait, wanna put this bad boy in
Ny Brz is offline   Reply With Quote
Old 08-21-2013, 07:15 PM   #133
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by Frs300 View Post
@pixel67 can you put this link next to my name i made a built thread and put all the info in one place adding pics of both my fbm kit and fa20club kit from start to finish and a bunch of other crap.
http://www.ft86club.com/forums/showthread.php?t=44750
sure thing. Awesome build so far! Need to get a vid of the first time it cranks over...
pixel67 is offline   Reply With Quote
Old 08-21-2013, 07:17 PM   #134
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Any idea what this kit weighs? I know power will trump the weight addition, but the fact it's all up front (like many kits), I just wonder what it does to the balance for handling with whatever extra weight is added.
boarder1995 is offline   Reply With Quote
Old 08-21-2013, 07:19 PM   #135
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Shipping weight is 50 lbs. Actual weight is less.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-21-2013, 07:24 PM   #136
pixel67
pixel67's Avatar
Last I heard mine was getting packed up. Waiting for the folks at top speed to give me an install date.
Old 08-21-2013, 07:26 PM   #137
Ny Brz
Hella Flush
Ny Brz's Avatar
when'd you order yours?
Old 08-21-2013, 07:43 PM   #138
pixel67
pixel67's Avatar
Little over a month but I already have the manifold installed.
Old 08-21-2013, 07:47 PM   #139
Ny Brz
Hella Flush
Ny Brz's Avatar
Guess we are both waiting, hopefully i can get an eta...even if they let me know they are waiting on things thats cool, i know they are swamped.
Old 08-21-2013, 07:50 PM   #140
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
*sigh* doesn't sound too promising for the 3-4 week estimate I received when I ordered mine 2 weeks ago.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
