Old 01-16-2012, 02:10 PM   #43
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Lowering the car about 1-1.5 inches will do it for me.
Old 01-16-2012, 02:13 PM   #44
MiguelAE86
Drives: NB Miata
I'm lowering it about 3 inches and getting some m@d tyte stretch y0!
MiguelAE86 is offline   Reply With Quote
Old 01-16-2012, 02:30 PM   #45
fatoni
Originally Posted by LSxJunkie View Post
There is no functional benefit to stretched tires. Period. If your setup is safe and you're happy with it, good for you. However, a 245 on an 8" wheel and a 245 on a 10" wheel do the same thing. You'll actually get more traction out of the 8" wheel set up.
yes there is. period. i would imagine 245s are faster on the 10" simply because i know that 225s are faster on a 9" over the 8". and that isnt even considering what it would do for the response and crispness of turn in. but im also pretty sure that isnt very stretched since 245 should come out to be just under 10". i agree with your point but not so much the example i guess
Old 01-16-2012, 02:30 PM   #46
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
more response in terms of tire performance doesn't mean better performance, although it can at times.
Its true that when you have less sidewall flex the response from the steering becomes sharper, but at the cost of what? Which by nature, proper traction is more associated with performance and it reduces with less contact patch from stretched tires.
With less than ideal sidewall you start to run into many problems. Which isn't an issue for people with show cars, because frankly they aren't really using the tires for anything other than rolling around. But for motorsports function is everything (obviously).
also..Iv had better results on my rx7 with 17s than with 18s on the same aspect ratio.
WingsofWar is offline   Reply With Quote
Old 01-16-2012, 02:48 PM   #47
dabocx
dabocx's Avatar
Drives: Scion FRS
Looking to leave around a one finger gap on all 4 corners. Hopefully thats not too low
dabocx is offline   Reply With Quote
Old 01-16-2012, 04:03 PM   #48
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd like to see evidence.
You have the most contact patch at a specific wheel width. For 245/45/17s that 8.0". For 245/40/17 that is 8.5".
For 225/45/17 it's 7.5"
I know many people here know this stuff more than those idiots who engineer the tires.. but I'd like to see proof. (yes that was somewhat sarcastic)
I agree with the response, stretched tires FEEL faster and have better response because the sidewall flex is reduced by stretching. That doesn't mean they'll set a faster laptime though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-16-2012, 04:05 PM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Compared to the stock ride height you may not have much suspension travel at that point. I think we'll have to see the car in person and then people will start messing with it to find the limitations and issues with the suspension.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-16-2012, 04:16 PM   #50
dabocx
dabocx's Avatar
Drives: Scion FRS
Yeah i was thinking similar. Im going to get coils so hopefully ill have some play in the system.
Old 01-16-2012, 04:57 PM   #51
fatoni
all i have to go from is the people involved in supermiata and hours of conversation with 949racing and what they say they found when making the 6ul rims. i never looked farther than that because a. at the time i was only driving a miata and b. those guys have the fastest miatas. what do you mean most contact patch? contact is a function of weight and tire pressure.
Old 01-16-2012, 05:32 PM   #52
Blaster
Drives: 2007 VW GTI
Coils and whatever takes me to the height my GTI is at. Covering tread and nothing more with the fender. Wide wheels with a stretched stock width tire so I can slide around and have fun
Blaster is offline   Reply With Quote
Old 01-16-2012, 05:54 PM   #53
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tire section width and/or a shorter contact patch is what I should have said. With wider wheels you will get a wider patch, but a shorter length. Good for handling, bad for acceleration and braking. I care about both, but in my experience the measured wheel width provided by the tire manufacturer (and within +/- .5") has always resulted in the faster lap times for me.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-16-2012, 08:09 PM   #54
fatoni
This.
They're really not faster. Period. Read up on slip angle and it's effect on handling and maximum grip. Stretched tires, like putting a 245 on a 10" wheel, mean that the sidewall does not give at all. That's great for steering feel. That's NOT great for handling. Plus you can fit a 285 on a 10" wheel and have that much more tire. Or you can put a 245 on an 8" wheel and have that much less weight.
miatas with 225s (nt01 or rs3) are faster on a 9" rim than a 8" rim. period. thats counterintuitive to your theories. and if thats the case, i couldnt imagine why a 245 would be faster on an 8" rim than a 9" rim. and the way you are talking about rims and tires is a little misleading at least in my opinion. you pick a tire size you want to run and then you find the best rim to suit your needs so puttin 285s on a huge rim for grip or a 245 on a small rim to save weight isnt holding any value becasue they are conflicting statements in themselves if you are trying to tell me that both big and small wheels are faster
Old 01-16-2012, 09:16 PM   #55
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
suspension geometry plays a huge factor in this as well...especially since tires and wheels are part of this equation.
but before you guys go further, i suggest you guys create a new thread for Tire Selection for motorsports. As to not muddy up the thread too much by going too far off topic....
thanks!
-Josh
Old 01-16-2012, 09:25 PM   #56
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Stock. The way it was designed to be.
S2kphile is offline   Reply With Quote
Toyota FT-86 II Concept Height Estimate Study Sea1monkey2 Scion FR-S / Toyota 86 GT86 General Forum 49 06-20-2012 01:36 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
please explain the different lower front lights on US spec BRZ torquemada BRZ First-Gen (2012+) — General Topics 30 12-04-2011 12:18 AM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 10:42 PM
