Old 08-15-2013, 11:45 PM   #169
PMok
Codename: Stitch
PMok's Avatar
great write up for the DIY @Enigmus -- gave me all the info I needed to install my Kartboy crank pulley. Though like many of you the toughest part was taking getting that damn crank bolt loose. It requires a ridiculous amount of force to break it loose. Broke one breaker bar and bent another ratchet using a jack handle for leverage. Bought a 3rd 24" breaker bar and it finally gave, though not before a good amount of struggling and me almost throwing in the towel. Everything else was pretty straightforward. Did have to double-check the belt was properly seated everywhere, and on my re-check found that the belt was a little off on the underside of the crank pulley, so glad I re-checked it all before I put everything back on and started the car.
Like others have noted with the Kartboy pulley there is a whine at about 2500 rpm but since it's a known thing I am not too worried about it. Definitely felt some improvement in the throttle response and acceleration, though it's hard to quantify. I was going to buy a Perrin but picked up the Kartboy for a good deal less at 86FEST, so I am happy with the bang-for-buck factor of this mod.
The Following User Says Thank You to PMok For This Useful Post:
2point0 (08-19-2013)
Old 08-16-2013, 04:24 AM   #170
BRZ68
Drives: BRZ m/t
Originally Posted by BRZ68 View Post
Did anybody notice the tensioner vibrating after the pulley install? Not sure if this is a normal vibration of the tensioner with the stock pulley..i didnt notice. The vibration on the tensioner stabilizes when there is throttle. Any input is appreciated. Thanks
Here are vids of my pulley and tensioner vibration after the install.
[ame="http://youtu.be/lx9HqeEd2z0"]http://youtu.be/lx9HqeEd2z0[/ame]
[ame="http://youtu.be/dXUJLwLBCg4"]http://youtu.be/dXUJLwLBCg4[/ame]
BRZ68 is offline   Reply With Quote
Old 08-16-2013, 07:41 PM   #171
DriftEm
DriftEm's Avatar
for me, it vibrated before the pulley install.
DriftEm is offline   Reply With Quote
Old 08-17-2013, 09:30 PM   #172
Panman
Panman's Avatar
Drives: 86 GTS
If you follow the DIY - you should remember that the tensioner pulley is a LH thread, if you loosened it to remove the belt you are going to need to tighten it again to spec (but bear in mind, LH Thread).
Panman is offline   Reply With Quote
Old 08-19-2013, 02:04 PM   #173
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Like others have noted with the Kartboy pulley there is a whine at about 2500 rpm...
Glad to hear someone else mention this. I barely notice it anymore.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 08-19-2013, 03:47 PM   #174
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Mine is shaking more with the stock pulley.
Efferalgan is offline   Reply With Quote
Old 08-19-2013, 04:29 PM   #175
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I saw a car at 86fest with the stock pulley and it was shaking way worse than that.
Sent from my iPhone using Tapatalk - now Free
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-02-2013, 12:11 AM   #176
frsdiy
Drives: frs-2013 raven
With the OEM crank pulley my tensioner pulley would wobble slightly. The car idles smoother now with the new perrin pulley.
[ame="http://youtu.be/aVxm-ia2Y7I"]http://youtu.be/aVxm-ia2Y7I[/ame]
My suggestion for people experiencing wobble is to put some slack in the belt using the tensioner pulley. Feel with your fingers around any pulleys that have a ridge and make sure the belt is not riding on the ridge. I did this and found that the belt was sitting on the ridge.
frsdiy is offline   Reply With Quote
Old 09-02-2013, 02:40 AM   #177
Panman
Panman's Avatar
Drives: 86 GTS
Quick question on the alternator pulley if anyone has replaced it with one of the options out there. Does anyone know the size of the nut you need to remove?
The Following User Says Thank You to Panman For This Useful Post:
cdemaar (11-10-2013)
Old 09-02-2013, 03:07 AM   #178
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Its a 24mm nut. If you have an impact gun that is fast enough, it'll zip it off with ease. If not, you'll have to use a chain wrench or something to keep the pulley stationary.
VietnamPhenom is offline   Reply With Quote
Old 09-06-2013, 02:15 PM   #179
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Has anyone had any CELs with any aftermarket pulley so far?
The Kartboy pulley says "A good bit lighter than stock but not light enough to throw a CE light."
http://www.fa20club.com/product.php?...cat=293&page=1
So anything lighter than 1 lb, or 1 lb with carbon fiber drive shaft with throw a CEL from what I've read.
Mike
mike_ekim1024 is offline   Reply With Quote
Old 09-09-2013, 02:03 AM   #180
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Very nice, I'll be using this guide in the near future!
Jolaessss is offline   Reply With Quote
Old 09-21-2013, 10:16 PM   #181
Sexyeve
86 Fanatic
Drives: 2013 firestorm 86
Good guide ! Just switched my alternator , water pump and crank pulley and I love the way the car feels now.
Sexyeve is offline   Reply With Quote
The Following User Says Thank You to Sexyeve For This Useful Post:
ravenblackfrs (11-18-2013)
Old 10-06-2013, 02:38 AM   #182
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
Thanks for the guide @Enigmus ! Still having trouble with the crank bolt. I was trying to loosen it and thought I was making progress when something gave and had me diving head first into the engine bay. My socket adapter snapped!!! Luckily I caught myself and didn't ding anything. This is one stubborn bolt!, doesn't help with the squishiness of the pulley.
While i tough out the night in defeat, Id appreciate any more advice on getting this sucker loose.
Techfl3x is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
