Old 01-16-2012, 03:17 AM   #29
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
^I assume you can ignore Japan's "Base" grade if you are purchasing in the US. We should only see 2 trims: Premium (equals Standard in Japan) and Limited (equals Premium in Japan). Anyone disagree?
And it looks like Japan's Standard and below grades do not get dual climate control? What do the controls for that look like (I don't remember)?
Old 01-16-2012, 05:04 AM   #30
Levi
Drives: Toyota
Only two airbags for base car? That is nice.
Levi is offline   Reply With Quote
Old 01-16-2012, 05:31 AM   #31
serialk11r
Drives: '06 AM V8V Coupe
What? It probably has something like 6-8...side curtains, side (probably pops from seat), front.
And @switchlanez yea I guess but I like how the stripper version has cheapo wheels, and no radio :/ Maybe the STI will have no radio option.
Oh wait I'm being a tard, there is a radio delete option. But if it doesn't save money, then it's pointless right?
Old 01-16-2012, 05:32 AM   #32
frusciantrix
Drives: Mini R56 JCW
Do the charts say something about top speed and acceleration?
frusciantrix is offline   Reply With Quote
Old 01-16-2012, 07:20 AM   #33
ajc209
Drives: GT86 Cosworth
Based on the ratios in the chart, it should hit 61MPH in Second gear @ 7500RPM with the manual gearbox......
ajc209 is offline   Reply With Quote
Old 01-16-2012, 08:47 AM   #34
wcbjr
Drives: 2006 Subaru LGT
6 speakers? Are they counting the two-way separates on the dash as one speaker? Or are there not any rear speakers?
wcbjr is offline   Reply With Quote
Old 01-16-2012, 08:53 AM   #35
ninjavwc
Drives: Mercedes ML 320
Typical Toyota style is to count the 2 dash tweeters, the 2 door speakers and the 2 rear speakers mounted behind the head rests of the back sets.
Hence, 6 speakers.
Sube practice may differ, but this is my guess.
ninjavwc is offline   Reply With Quote
Old 01-16-2012, 08:58 AM   #36
wcbjr
Hence, 6 speakers.
True, but in those models, there actually were only 6 speakers.
Old 01-16-2012, 09:40 AM   #37
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I wish the auto had better gearing. But it's not to bad versus the manual. I suspect a close acceleration between the two.
SUB-FT86 is offline   Reply With Quote
Old 01-16-2012, 11:05 AM   #38
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
Damn I was really hoping for Plasma Blue, ah well.
NemesisPrime909 is offline   Reply With Quote
Old 01-16-2012, 11:30 AM   #39
nrclptcnsmniak
Professional Athlete
Drives: Marty's Hover Board
+1
Or the return of java black pearl :p
I'm the type of guy who loves his girlfriend.
nrclptcnsmniak is offline   Reply With Quote
Old 01-16-2012, 01:51 PM   #40
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
My calculation doesn't agree with that value. The ETRTO rolling circumference for a 215/45R17 tire is 1907mm according to here:
http://www.club80-90syncro.co.uk/Syn...calculator.htm
Even calculating for increased circumference at a speed of 100 km/hr for 215/45R17 87W here:
http://bndtechsource.ucoz.com/index/...alculator/0-20
Only increases the circumference to 1909.7mm. So my calculation for 2nd gear at 7500 RPM is:
1909.7/25.4/12*7500/(4.1*2.188)/88 = 59.5 MPH.
This value seems a bit too low for good 0-100 Km/hr. times unless the fuel cutoff is extended slightly in second gear. Given the 3.727 rear end ratio then 2nd gear reaches 65 MPH at the stated 7450 red-line: which seems higher than expected from some of the posted videos. I wonder what ratio Subaru will use in the US?
BTW I noticed that the gear ratios including the 4.1 rear end ratio are exactly as given in the GT-5 game as I posted here:
http://www.ft86club.com/forums/showp...5&postcount=25
Last edited by DSPographer; 01-16-2012 at 01:55 PM. Reason: Corrected tire size typo
DSPographer is offline   Reply With Quote
Old 01-16-2012, 02:03 PM   #41
frusciantrix
Sounds like 150mph could be possible when 6th gear is in optimal power rev range.
Old 01-16-2012, 02:12 PM   #42
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
So the colors are:
20 = ???? Maybe this is the gloss white?
7G = Stain White Pearl
6S = Platinum Silver Metallic
1K = Dark Grey Metallic
4S = Crystal Black Silica Pearl
7P = Lightning Red
2C = World Rally Blue Pearl
8H = Galaxy Blue Metallic
bambbrose is offline   Reply With Quote
2012 brz, 2012 subaru brz, 2013 brz, 2013 subaru brz, brz forum, brz forums, subaru brz, subaru brz forum, subaru brz forums
Subaru BRZ Chop *Updated with full body chop* Snoopyalien24 BRZ Photos, Videos, Wallpapers, Gallery Forum 32 10-19-2012 06:55 PM
Scion FR-S / FT-86 / Subaru BRZ Specs and Options. 200hp / 151 lb-ft tq Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 510 09-03-2012 06:39 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 06:43 PM
