Old 07-07-2013, 06:30 PM   #43
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
any updates on this?
mezdup is offline   Reply With Quote
Old 07-07-2013, 08:07 PM   #44
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
These threads are the reason why my clunky ass doesnt pull or pry off things that have soft plastic.
I rather install items without pulling off the bumpers or fenders, things that may creek or not stay still after.
Sent from my PG86100
CamryDS is offline   Reply With Quote
Old 07-15-2013, 06:07 PM   #45
Dipstik-sportech
Dipstik-sportech's Avatar
Any news in wether the scion ones fit the brz? Subaru doesn't list an updated part yet and my dealer has no clue what I'm talking about
Old 07-19-2013, 07:34 PM   #46
milkesfrs
milkesfrs's Avatar
Drives: hot lava
I ended up paying 958.00 for a new bumper, clips , paint and install. Scion field rep told me did not re install the bumper right and the bumper shrunk due to the heat.
milkesfrs is offline   Reply With Quote
Old 07-19-2013, 08:10 PM   #47
msile
msile's Avatar
Drives: ISF
Ok. So after reading through this thread, here is what I did:
1) New headlight clips (revised part number)
2) New side clips
3) While putting on the bumper, started with the clips under the headlight.
4) Next the side clips
5) Inserted the push pins under the corner marker lights
6) Installed and tightened the metal strip along the top of the bumper
7) Installed under body panels
Two weeks and holding.....
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
The Following User Says Thank You to msile For This Useful Post:
milkesfrs (07-20-2013)
Old 08-19-2013, 07:57 AM   #48
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good morning
Do you the part numbers (revised?) and the side clip numbers?
Royal Palm Beach Toyota isn't sure
Thank you
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-19-2013, 10:28 AM   #49
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Originally Posted by tonystewart View Post
Good morning
Thank you
Front bumper:SU00301484
Right Clip: SU00301496
Left Clip: SU00301497
FR-Shadow is offline   Reply With Quote
Old 08-19-2013, 05:18 PM   #50
tonystewart
You bought a new bumper?
Old 08-19-2013, 05:55 PM   #51
FR-Shadow
FR-Shadow's Avatar
yeah my tab broke all the way through, so it couldnt even clasp on. it was only 280
Old 08-30-2013, 03:18 PM   #52
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Subscribed, same issue, trying to resolve.
gdrider77 is offline   Reply With Quote
Old 09-11-2013, 10:36 PM   #53
Norcalmav23
Drives: SWP Limited manual BRZ
well at least I'm not alone... F... this is a lot more work than I thought it was gonna be. Had I known this was an issue I would have gone for a different CAI lol
- Clear Bra - 35% tint - Fa20 club intake - Rev Works header - Perrin OP - 3 inch FP - Resonated CB - Perrin LW crank pulley - Fortune Auto 500 V4 coil overs... pinky sized gap - Full CS knock off poly lip kit - JDM clear side markers - RPF1 18x8 - 35 offset - square 225-18-40 - Perrin shifter bushing - KartBoy positive shift kit - Hawk HPS pads - SS Lines - Visconti e85 tuned
Norcalmav23 is offline   Reply With Quote
Old 09-12-2013, 02:42 AM   #54
milkesfrs
milkesfrs's Avatar
Drives: hot lava
After spending over 900.00 for a new bumper cover and paint the problem came back I figured out a cheap ghetto way to fix the corner popping out. It cost me about 5 bucks and my bumper has been good for over 6 weeks.
I use small peace of speaker wire ( I cant remember if the wire was 16 gauge or 18 gauge speaker wire ) and pushed it into the seam using a plastic rolling tool i got at Home Depot for redoing screen doors. The fender pushes down on the speaker wire to keep the corner of the bumper from pushing out. You really have to work to get the wire all the way in so its pushing the tab down on the clip. Guys, unless you take the bumper off again the bumper isn't going to pop out. After I got the wire in I use black touch up paint to color the small peace of wire. You can even tell it there.
Hope this helps.
The Following 7 Users Say Thank You to milkesfrs For This Useful Post:
blackfireball5 (09-23-2014), mezdup (09-12-2013), Norcalmav23 (09-13-2013), Slowbaru (04-06-2014), sprintertrueno86 (09-13-2013), TheBRZsKnees (07-25-2018), TurtleFace (11-21-2016)
Old 09-12-2013, 02:54 AM   #55
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Try what I did . Its sound dumb but its worked. The nice thing is it cheap and you cant see the wire unless you take a flashlight to it.
The Following User Says Thank You to milkesfrs For This Useful Post:
Old 09-12-2013, 05:33 AM   #56
Dipstik-sportech
It's pretty bad we have to do ghetto fixes to a brand new car already. After replacing all the clips under the headlight and on the fender the drivers side is better but now the pass side did it fml!!!
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Front Bumper Black Vinyl Juanito08 Exterior Parts (Aero, Lighting, Etc.) 37 09-18-2015 04:09 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) — General Topics 29 08-14-2012 12:19 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 03:30 PM
BRZ to FR-S front bumper swap? r4m3n Cosmetic Modification (Interior/Exterior/Lighting) 4 04-20-2012 05:29 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
