Old 08-06-2013, 10:35 AM   #323
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by tonystewart View Post
Header installed, 4 hours without a lift. cleaning/washing every part/component/ bolts of the under pans and the exhaust during disassembly.
PB Blaster penetrating oil is amazing.
PB Blaster Dry Film Lubricant works well on those under body bolts during reassembly.
I used new gaskets for the engine, the overpipe and the front pipe.
Extensive use of permatex ultra copper on the vband clamp. No leaks, no noise.
The sound is the same at idle in the engine bay. At the exhaust tips there is a hint of change but nothing loud
At cruise it is still quiet, everywhere else it is louder, and you can hear the FA20 CAI distinctly.
The hot idle with AC on has a shiver/shake that wasn't there prior, wondering if upping the idle would solve this.
All this data is from my daughter, I haven't driven it.
Big smile on her face as she left.
I will send Toni a data log for an updated tune from FA20.
thats what that sound is? i thought it was the header clamp vibrating lol
lbroskee is offline
Old 08-06-2013, 07:14 PM   #324
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
New FA20 Club ECU Stage2B File Installed. "It's Fantastic" was the report I just received from my daughter.
Thank you Toni
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
The Following User Says Thank You to tonystewart For This Useful Post:
lbroskee (08-06-2013)
Old 08-06-2013, 07:17 PM   #325
lbroskee
lbroskee's Avatar
Thank you Toni
Im startin to think its her car that ur building lol
lbroskee is offline
Old 08-06-2013, 07:22 PM   #326
tonystewart
It is her car, she got it over a year ago for her 16th Birthday, 10 days before the official release date. Other than Data Logging and Suspension Shakedown I do not drive the car.
I build them, they drive them.
Old 08-06-2013, 07:34 PM   #327
lbroskee
lbroskee's Avatar
Awesome. Starting her out right
lbroskee is offline
Old 08-06-2013, 07:38 PM   #328
tonystewart
Her older sister has a badass 2008 Scion TC. Great car and built heavier.
Old 08-06-2013, 09:53 PM   #329
Andy@FA20Club
Drives: FA20Club.com
Thank you Toni
Refined you have to love it.
Andy@FA20Club is offline
Old 08-10-2013, 08:21 PM   #330
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Idk if its been mentioned. But it looks a lot like p&l's header.
TouchMyHonda is offline
Old 08-12-2013, 08:27 PM   #331
apexaddict
Mine came in Saturday, really looking forward to putting it in this weekend.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline
Old 08-12-2013, 09:11 PM   #332
Andy@FA20Club
The Following User Says Thank You to Andy@FA20Club For This Useful Post:
Wolfking (08-12-2013)
Old 08-18-2013, 11:11 AM   #333
apexaddict
Got my header put in yesterday, some thoughts.
- The build quality is really good. There is not a weld out of place or a odd metal burr in sight. But the build quality is almost *too* good. The tolerances are extremely tight, and the header must be put onto the studs on the engine as straight as you can possibly muster to get it to go on. Whereas the stock header has a bit of play in it, this absolutely does not. It took a lot of tries and a little persuasion with a rubber mallet, but it does fit.
- I didn't care for the V-band clamp that was included. The clasp on it was huge and I couldn't get it oriented in a way where I was comfortable with its clearance to things around it - primarily the radiator support/fan. Thankfully, since I was also putting on a Perrin exhaust - which also include V-bands in the same size - I just swapped in one of those and it worked like a charm.
- The car is significantly faster in the midrange now - the powerband is definitely more linear. I will need to have the tune tweaked for the header and the other stuff I put on, but just based on the base map I was using before, it feels pretty awesome. First time I've ever been impressed with the power of the car.
- If you hate the UEL sound (I do), then you will love this. It's much smoother sounding than even the stock header, and combined with the Perrin intake/exhaust, it sounds very S2000-ish under load. Definitely different. It's also louder, but with the resonated Perrin exhaust, it's very tolerable. A bit boomy at certain RPMs on the highway, but that is definitely more a function of the exhaust, IMO.
- There is a bit of a buzziness/resonance around 3500rpm at WOT, and a bit more vibration at idle. I think the header is causing these things, but since I did so many other things to the car at the time, I can't say for sure. My header is catless so I wouldn't be surprised if that were the cause. Still, it's not nearly enough of an issue to bother me.
Hope that helps point people in the right direction. I had about a 2-month wait for this, and I'm happy with the initial impressions.
Andrew P.
The Following User Says Thank You to apexaddict For This Useful Post:
ShoNUFF (08-19-2013)
Old 08-18-2013, 11:24 AM   #334
xjohnx
Grip>Slip
xjohnx's Avatar
@Andy@FA20Club @FA20Club.com -
What's the current estimated wait time on these?
is the wait any longer or shorter for the UEL's?
Can a bung for wideband be added?
xjohnx is offline
Old 08-18-2013, 11:48 AM   #335
lbroskee
lbroskee's Avatar
So the Perrin clamp is more compact for same size area? Mind a pic?
lbroskee is offline
Old 08-18-2013, 12:00 PM   #336
FA20Club.com
Drives: 2013 White Out FR-S
Your raised idle with a tune adjustment takes care of the idle vibration i usually idle around 850-900 instead of 600 to eliminate the issue. nd that raspiness is to be expected with any catless header. glad you like it. there is more power to be had with tune adjustment.
FA20Club.com is offline
header, turbo manifold
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
FA20CLUB Power Pack #1 Tested FA20Club.com Engine, Exhaust, Transmission 31 01-16-2013 03:32 PM
Borla cat-back w/ UEL header tested at the track BeltedBiscuit Engine, Exhaust, Transmission 17 12-30-2012 02:57 AM
Turbo FR-S Tested For Drift Reportedly Spotted DanPO Scion FR-S / Toyota 86 GT86 General Forum 123 01-24-2012 01:25 AM
