Old 03-09-2013, 10:40 AM   #1
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FR-S/BRZ/BRZ (Smart Key) Wiring Info
Finally made it to the requisite 10 posts before you can create a thread.
Just what the DIY junkie needs.
FR-S Wiring Info
BRZ Wiring Info
Enjoy
:happy0180:
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
Trap63 (11-22-2013)
Old 03-10-2013, 11:04 PM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What can we do with this info? I'd like remote start in a manual car.
Old 03-11-2013, 10:22 AM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Personally, I can do a lot with this info.
If you have to ask what you can do with it, you probably shouldn't be doing anything with it.
The information in the PDFs alone is enough to install a remote start, but you'd lose a key in the process. In conjunction with some data bus modules (AL-DS, FLCAN, BLADE) you can avoid losing a key and have most of the hardwiring controlled through data.
You'd also need to wire a relay (such that the vehicle thinks the clutch is being pressed during the remote start sequence) to interface with a remote start that had a manual transmission mode, (i.e. Compustar FT-6200-S or higher end Viper/Python/Clifford/Automate) systems.
Also, any information you'd need related to the audio system is included so if you're changing speakers or the headunit.
If you wanted to integrate window control modules (DEI 530T) so the windows automatically roll-up when you lock the doors, that information is there as well.
The benefit of directechs is you have a guide to wire color, wire location, and pin location but you better still use a multi-meter to verify. So for me, directechs wiring info is the holy grail of any 12v electronics person...in conjunction with my trust multi-meter I can do nearly anything, very easily.
Old 03-11-2013, 04:45 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Nice answer! They gave us three keys, so I'd happily sacrifice the buttonless one. It's chip would have to be integrated into the system?
Sounds like buying a kit would make this much easier. I'm not into hacking it.
Old 03-11-2013, 08:30 PM   #5
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I will agree with you on one point, not hacking it.
There are other elegant, albeit more involved, methods of completing the remote start rather than placing a key inside a box, hiding said box then running the coil around the key cylinder/ignition switch.
In conjunction with the directechs documents, properly wired relay, purchase either 2 FLCANS and mated with the appropriate Directed or First Tech remote start system you can complete a remote start; given you have the cables to program the aforementioned data bus modules.
Old 03-11-2013, 11:50 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Too bad I live in Cali and you live in Texas. I'd pay you to do it!
Old 03-12-2013, 08:42 AM   #7
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
No need to pay. Case of beer & 2.5hrs :happy0180:
Old 03-12-2013, 04:13 PM   #8
EAGLE5
Dismember
EAGLE5's Avatar
Not sure about Texas beer, but we have some damn good breweries in California. http://beeradvocate.com/beer/profile/112/412
After two beers at 9%, you'll be confusing red for blue.
Old 06-25-2013, 03:33 AM   #9
blanco
DNGZONE
blanco's Avatar
Drives: Raven FR-S
FR-S Wiring Info
BRZ Wiring Info
Enjoy
:happy0180:
Hello, do you still have these? They will not open for me.
blanco is offline   Reply With Quote
Old 06-28-2013, 08:23 AM   #10
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yeah I still have them somewhere
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
Old 08-17-2013, 03:32 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by 18Bravo34 View Post
It was a while ago since I did my remote start install. If you install an immobilizer you will not loose a key. The system copies the chip and makes the car think it has a key in the ignition.
Why kit did you do? Manual or auto trannie?
Old 08-17-2013, 04:50 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
I'd really like a remote start with windows down feature that can use the factory remote or something similar. Also, does the remote start keep the car on when you get in and drive away or do you have to put the key in and turn it on? How do you turn the car off, then?
Old 08-17-2013, 08:19 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Methinks you and I got this car for different reasons.
Old 02-20-2014, 10:58 PM   #14
Greenhorn
Greenhorn's Avatar
Drives: 2013 FR-S 10-Series #1394
FR-S Wiring Info
BRZ Wiring Info
Enjoy
:happy0180:
Sorry to bump this again, but same as the other poster - do you still have these? The links on the OP won't open. Specifically the SmartKey one. Thanks!
Greenhorn is offline   Reply With Quote
Smart Key options? Sythellri BRZ First-Gen (2012+) — General Topics 39 02-25-2017 12:11 AM
Where do you put your smart key? Surok Scion FR-S / Toyota 86 GT86 General Forum 61 03-03-2013 05:01 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
Smart key? tawheed BRZ First-Gen (2012+) — General Topics 5 10-18-2012 01:19 PM
