Old 08-15-2013, 11:56 AM   #1
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Exhaust Noise that goes away after warmed up
Guys, I've posted in the overpipe threads but I'm not sure thats my issue. I did have to adjust things to clear the hotckis sway bar but I've taken care of that. I have an exhaust noise which I would describe as rasp. I hear it when the car is not up to full operating temperature. The exhaust needs to be heat soaked before its gone but it does go away so that tells me its not the overpipe hitting. I have the FA20club header and was wondering about the Vband. The noise is under full throttle at 5K RPM or higher. Anyone else notice this sound and found a resolution? Exhaust is FA20Club EL header catted and coated, Motiv overpipe coated, and Motiv Front pipe catted. Rear is stock. Thanks for your input.
FastLane1000 is offline   Reply With Quote
Old 08-15-2013, 11:59 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Easy fix, don't go WOT 5+K RPMs with the car not fully warmed up, your motor internals will love you for it.
Old 08-15-2013, 12:03 PM   #3
FastLane1000
Thanks, but its doing something it shouldn't. must be a leak somewhere. Motor is fully warmed but exhaust has just cooled off a little.
Old 08-15-2013, 12:04 PM   #4
Ross
Drives: 85 corolla gts
If there is a leak you should be able to find it at idle. When cold spray with soapy water at your connections before you start it. Then see if you get any bubbles (this is the safer way). I typically will place my hands around all connections making it a point to try and not actually touch any thing to see if I feel any air coming out (the not so safe way). I would also recommend letting your vehicle get up to proper operating temperature before you drive aggressively. Hope this helps.
Ross is offline   Reply With Quote
Old 08-15-2013, 12:09 PM   #5
qoncept
qoncept's Avatar
That's going to be hard to do at 5k with any load on the engine.
Sportsguy83 said it though. Don't go over 5k when the engine isn't warm. Your engine internals DO hate you for it.
qoncept is offline   Reply With Quote
Old 08-15-2013, 12:21 PM   #6
FR-S Matt
Betting its the noise of the aggressive cold start vibration in the header, which explains why it goes away when it is warm. There's a million videos of how awful this sound is on un-resonated exhausts with headers that quiet down after warmup.
Don't drive any car hard until it is warm, unless you want to replace it in 50k miles.
Old 08-15-2013, 12:26 PM   #7
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
I have a header back exhaust that has a lot of rasp on startup. After about 1 minute of driving and letting the engine warm up, it's completely gone. It's just the pipes being cold.
husker741 is offline   Reply With Quote
Old 08-15-2013, 12:31 PM   #8
FastLane1000
I appreciate the input regarding a solution but I really don't drive the car hard before the motor is warmed. I was trying to explain that the exhaust needs to be heat soaked before the sound is gone. This happens long after the motor is fully warmed. Sounds like the consensus is its header related. Thanks!
Old 08-15-2013, 09:38 PM   #9
wparsons
wparsons's Avatar
It's not just cold pipes, the ECU runs aggressive amounts of overlap to help heat up the engine faster which also makes it A LOT louder.
It's easily 5x as loud at a cold startup than once warm, even 100% stock.
flickr
Old 08-15-2013, 09:43 PM   #10
FR-S Matt
Aftermarket headers are thinner and the heat plate on the stock header acts as a muffle too.
Old 08-15-2013, 10:06 PM   #11
husker741
You're very right and I totally forgot to mention this. Thanks for the input.
Exhaust Noise Levels EN2_Squirrel Engine, Exhaust, Transmission 0 07-11-2013 10:32 PM
Road/Exhaust noise mitigation? l0aded Scion FR-S / Toyota 86 GT86 General Forum 10 03-05-2013 06:55 PM
What's this noise? Nitesh31 Issues | Warranty | Recalls / TSB 3 12-19-2012 09:35 PM
HID noise Carlsbad BRZ First-Gen (2012+) — General Topics 6 06-20-2012 12:39 AM
