View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-13-2013, 03:54 PM   #2563
Allch Chcar
Drives: N/A
Originally Posted by fatpwr View Post
Just wanted to report that I have about 3600 miles. chirping on and off.
AND I have noticed that if I gas up 91 w/o ethanol I never hear/have any chirping of any kind. and if I gas up 93 with ethanol, after maybe 20-30 miles, the chirping is there again and it's just really annoying. Tested it on 2 other FRS's and the exact same symptoms. So I figure it was a ethanol related issue. afaik, it doesn't affect performance or drive-ability yet.
Originally Posted by Area86 View Post
Not sure if anyone else has posted this here but whenever I run e85 the crickets go away and as soon as I switch back to pump gas 91 e10 they come right back.
Sent from my DROID RAZR using Tapatalk 2
Originally Posted by cantholdanymore View Post
These last couple Of days temp is about 10f below average and chirps are gone
That's because it's temperature related! Different fuel mixtures have different density/cooling properties. The HPFP generates a lot of heat. Give it time.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-13-2013, 10:16 PM   #2564
thill
Crickets last night. Filled up on empty this morning with ethanol free at a Mobil station. No crickets this afternoon even after driving for about 30 minutes in rush hour and the heat.
Old 08-14-2013, 12:02 PM   #2565
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Are you saying it chirps more when hot? Funny, mine was quiet under hard driving in 110+ heat and noticeable when it was ~80 and I was taking it easy.
Very few people have found a repeatable relationship other than some with access to ethanol free.
ineedyourdiddly
Old 08-14-2013, 01:01 PM   #2566
HunterGreene
Hail Magnet
HunterGreene's Avatar
I assume he means a range of engine temperatures in which there are chirps, which would actually make sense, given the currently suspected causes. Of course, as has been stated, its just conjecture. Just waiting for my crickets to fade away (probably sometime over the winter).
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Allch Chcar (08-14-2013)
Old 08-14-2013, 03:01 PM   #2567
FR-S Matt
Sometimes my crickets are out in full force, sometimes my crickets are retarded and occasionally chirp here and there when idle. Temperature doesn't seem to affect it. I'm nearing 9.5k miles total on the same pump and nothing has changed.
100+ degree days, I get them loud. I could let the car sit for 10 minutes at home, come back out and drive and they're gone while idle. Engine is still warm.
I've tried different gases from Chevron 93 to Shell 93 to HEB 93 and get the same results across the board. There's no real pattern to it. It either happens and they're loud, or other times they are just slightly there or not at all.
Regardless, Toyota needs the real fix of just creating a new part. Hell, at this point, I'd buy an aftermarket fuel pump if someone made one, but I think no one wants to due to the complexity/reliability part. All just speculations..... I'll continue to keep waiting for the true fix.
Old 08-14-2013, 03:50 PM   #2568
SurfAndSand
8SiX
Drives: FRS 10series
Sorry - why do we need to wait until after 300mi to vote again?
I am at 100 mi and already have what I believe to be the crickets sound...
SurfAndSand is offline   Reply With Quote
Old 08-14-2013, 05:09 PM   #2569
strat61caster
300 miles is the typical range for a tank of gas, the "problem" seems to surface after the first fill up, if 300 miles wasn't specified you'd get a bunch of guys posting the day they bought with < 100 miles on the odometer saying "mine doesn't chirp!" only to come back a week or two later with a chirping car unable to change their vote.
ineedyourdiddly
SurfAndSand (08-14-2013)
Old 08-14-2013, 06:08 PM   #2570
thientai
thientai's Avatar
Drives: Firestorm Scion FR-S
I've only been using Shell V-Power but I had my first fuel pump changed at around 3500 miles for the crickets and they came back at around 4000 miles. I let my dealer know and they told me the crickets shouldn't have come back and that I can change the pump again or wait for an updated version of it? So I waited and now I'm at 9700 miles and I think the crickets are worse now because I can also hear them while I'm driving, not just when I'm idling... Going to call and ask about it tomorrow though.
thientai is offline   Reply With Quote
Old 08-14-2013, 06:59 PM   #2571
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
Originally Posted by BadMoon View Post
Welcome to the board. There is no "fix". You might as well wait for them to come back (the crickets) before you take it back in. Or just wait untilt here is an actual fix that fixes the problem.
Hmm... cool i'll just probably wait until it comes back. thanks
Zen86 is offline   Reply With Quote
Old 08-14-2013, 07:09 PM   #2572
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Do you mean the car is moving at 35 MPH but the gear is in neutral and the engine is idling at 600 RPM?
Or do you actually mean the car is moving at 35 MPH and the gear is in 5th and the engine is running at 2000 RPM?
Old 08-14-2013, 07:50 PM   #2573
mrdanyo
Drives: 2014 BRZ Limited (World Rally Blue)
This chirping issue has been holding back potential buyers like myself for a while now. I'm really starting to wonder if it'll even be fixed in the 2014 at this rate.
mrdanyo is offline   Reply With Quote
Old 08-14-2013, 11:27 PM   #2574
thientai
thientai's Avatar
I still hear the chirping while I'm in gear, moving, and engine running at over 2000 RPM.
Old 08-15-2013, 07:00 AM   #2575
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
I set up a service appointment yesterday (my analog speedo registers ~15 mph, when the car is sitting still), and mentioned the crickets. The advisor said they've had some success replacing pumps, so I figured I've got nothing to lose.
It really does sound like a tolerance stack issue. My first BRZ didn't ever have crickets, in 8900 miles.
Admiral Ballsy is offline   Reply With Quote
Old 08-15-2013, 08:46 AM   #2576
HunterGreene
Hail Magnet
I think you think this is more of an issue than it is. At this point, it just appears to be an annoyance, nothing more. Pull the trigger, you won't regret it
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
