Drives: WRB BRZ
brake pedal doesn't return smoothly
Recently i've noticed that my brake pedal doesn't return all the way smoothly. If i depress the brake pedal hard, it'll return normally most of the way, but the remaining feels like it got stuck on gum or something, stick for a bit and returns. I checked my brake fluid it's fine. Is it a concern? Is it something that i can check myself?
#2 |
Drives: WRB BRZ
no one?
#3 |
Drives: FR-S 6MT
Did you look at the pedals and linkage to make sure nothing is obstructing or binding? Not sure there is much else to check.. Other than the master cyl.. Does it brake fine... Not spongy?
#4 |
Mechanical Guru
Drives: 2013 Scion FR-S (Argento) M/T
Also check after a drive and make sure your rotors aren't super hot, it could be that one of your calipers is sticking. This happened to my brother with his mustang, he just had to replace a small part. I don't recall what it was, but I remember it was a cheap fix.
#5 |
Drives: '13 FRS - STX
I started messing with it and I feel it too. It's probably just roughness in whatever return mechanism is used (spring, vacuum I'm not well versed on modern brake systems) and really only happens after you're on the last ~5% of travel.
I'm not going to worry about it, I'm just going to remove my foot from the brake smoothly and quickly like usual, you don't feel it if you're just driving, you have to play with it to find it. |
#6 | |
#7 |
Drives: Whiteout FR-S
My Brake pedal got stuck down causing the car to skid out of control. I am waiting for Scion to get back to me.
| Rock Hard Brake pedal in the middle of an autocross run... | Jedi1 | Tracking / Autocross / HPDE / Drifting | 67 | 05-22-2018 04:40 PM |
| Help! Oil filter isn't coming off smoothly | ShoGun | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 40 | 11-26-2015 09:58 AM |
| (6MT) Getting into 2nd smoothly | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-19-2013 06:10 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 01:29 PM |
