Old 08-14-2013, 02:11 PM   #1485
R L Newb
Drives: LR BRZ Ltd, 06 STi
Originally Posted by HunterGreene View Post
So where are you supposed to put the jack stands after you use the floor jack?
you can get slotted ones or just be careful setting it down and use those points. If you use normal jack stands though it may eventually bend. The jack is usually what bends them because of the way it raises a car. They're almost flat on my sti from tire changes at autox events :P
depending on what you're doing other parts of the car, like control arms, are good too.
R L Newb is offline   Reply With Quote
The Following User Says Thank You to R L Newb For This Useful Post:
HunterGreene (08-14-2013)
Old 08-14-2013, 02:15 PM   #1486
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Originally Posted by Mikem53 View Post
The cruise control works fine for me.. Accurate increments .. Just takes a second or two to notice..
The outside temp can be adjusted via techstream.. There is a setting for it.
My cruise just doesn't function that way. Given this car's DBW I don't understand why it can't be more accurate.
That's interesting about the outside air temp. I've gone to the dealership twice (for other reasons) and have had them look at the air sensor. I even specifically asked if the sensor can be programmed to have a built in error amount (in this case I'd tell them to lower it 5 degrees) but the shop supervisor told me that it's not possible.
Old 08-14-2013, 02:33 PM   #1487
Messier45
Horizontally-unopposed
Drives: 2003 WRX WRB- 2013 BRZ WRB
Originally Posted by DJCarbine View Post
My Samsung Note 2 HATES the bluetooth on the stock headunit.
I have to change it to radio/bluetooth/radio/bluetooth for it to start working when I first turn the car on.
Its the only thing that makes the bluetooth audio work.
Galaxy S3, on my BRZ limited I have issues where the phone keeps disconnecting /reconnecting randomly... pretty annoying but its the only complaint about the car I've had so far so
Messier45 is offline   Reply With Quote
Old 08-14-2013, 02:41 PM   #1488
ciro
Drives: Scion FR-S
I keep getting annoyed by a rattle in the trunk while going over bumps, and my sh!t stealership that thinks it takes a week to replace the high pressure fuel pump.
ciro is offline   Reply With Quote
Old 08-14-2013, 02:41 PM   #1489
Mikem53
Drives: FR-S 6MT
I think I was wrong about the ambient temp... The setting is there but seems to be related to the AC operation.
http://www.ft86club.com/forums/showt...ght=Techstream
Mikem53 is offline   Reply With Quote
Old 08-14-2013, 02:43 PM   #1490
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
-The cruise control sucks. What's so hard about designing a system that adjusts your speed +/- 1 mph based on if you push the stalk up or down once? I have to push the damn thing up 3 times to get it to increase 1 mph.
I've never had a cruise control that worked like that. With this and every other car I've ever owned, you hold the Accel/Decell button until the car reaches the desired speed, and then release and it will stay there.
Is this your first car?
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 08-14-2013, 02:49 PM   #1491
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
The air conditioner seems to be fairly inconsistant/underpowered. It gets pretty cold if it's a cloudy day but as soon as it has to compete with the sun it fails to keep it very cool, which I guess makes sense and all, but it gets a little old sweating despite opting for air over windows. Maybe it's just me though. It's certainly nothing to throw the car out for, just really my only complaint.
(It might also be the air-shutting-off under load thing that's doing it. Maybe I should have less foot on pedal?)
Nevermore is offline   Reply With Quote
Old 08-14-2013, 02:51 PM   #1492
chimmy
Because BOXER
chimmy's Avatar
Drives: Asphalt FR-S
My Chevy 2500HD will do 1mph increments. But its also the only vehicle that I've noticed to do it.
chimmy is offline   Reply With Quote
Old 08-14-2013, 02:53 PM   #1493
Meehow86
Drives: 2013 Subaru BRZ Premium 6MT
Originally Posted by R L Newb View Post
those aren't the jack points. There's a spot at the front of the car and the rear diff. those are for the emergency jack only...
They're still jack points though. And its pretty silly that for a car like this (one were people WILL be switching and working on wheels, breaks, etc a lot), that its made it such a crappy way. After owning a couple "sporty" cars before, having something like this happen for the first time is pretty disappointing.
But from now on I will have to use the front and rear diff's for all my wheel changes.
Meehow86 is offline   Reply With Quote
Old 08-14-2013, 02:54 PM   #1494
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
The lack of automatic headlights is beginning to be annoying.
Ammonia is offline   Reply With Quote
Old 08-14-2013, 03:18 PM   #1495
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Seating position. Seats are comfortable but unless I'm driving with both hands on the wheel, the seats are too low to rest my arm on the door while driving.
Frs x3 is offline   Reply With Quote
Old 08-14-2013, 03:22 PM   #1496
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Seat height is adjustable. Use the pump lever to pull up or push down the seat height. You need to use a pump action for each direction (each pump raises or lowers the seat by a few inches)
EK_Golfer is offline   Reply With Quote
Old 08-14-2013, 04:33 PM   #1497
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Right now its just fighting my woman on being able to buy shit I want for it lol
The Following 5 Users Say Thank You to BlueDubbinTDI For This Useful Post:
blanco (08-14-2013), CK_Bladesmith (09-03-2013), gt8613 (08-31-2013), jbravo373 (08-14-2013), wootwoot (08-14-2013)
Old 08-14-2013, 04:48 PM   #1498
Randyliciious
Randyliciious's Avatar
Having no money but wanting to get EVERYTHING!
Randyliciious is offline   Reply With Quote
The Following 4 Users Say Thank You to Randyliciious For This Useful Post:
BlueDubbinTDI (08-14-2013), HotLeopardMama (08-14-2013), wootwoot (08-14-2013), yuicebox (08-16-2013)
ha ha!, hate, playerhatersball, potatopants
Errr... Hate to ask... Crash Testing?? slusoccer00 Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2015 04:03 PM
Hate those ugly visor warnings? avusblue Cosmetic Modification (Interior/Exterior/Lighting) 28 12-17-2014 04:16 PM
I hate you Jaguar [I love you!] Ryephile Other Vehicles & General Automotive Discussions 2 04-04-2012 04:56 PM
Why hate Justin Bieber? LSxJunkie Off-Topic Lounge [WARNING: NO POLITICS] 29 03-27-2012 11:09 AM
dont hate me for asking.. weight? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 27 03-08-2012 03:09 PM
