Old 08-14-2013, 10:07 AM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Installing a hood for the fr-s?
Im getting an Ams hood for the fr-s and was just wondering how difficult it was? It looks like the hing bolts are all i need to take out and remove the old hood and put the new hood on and put bolts back in. If im missing anything please let me know? Thanks
Frs32907 is offline   Reply With Quote
Old 08-14-2013, 10:31 AM   #2
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
One word of advice. Use the bolts they provide in the hood. Do not try to use your OEM ones. I kept thinking I was stripping out the threads because it would go in and then stop half way.
Also use 2 people.
FR-Shadow is offline   Reply With Quote
Old 08-14-2013, 11:03 AM   #3
Frs32907
Is that really how easy it is?
Old 08-14-2013, 11:11 AM   #4
Iceblazer
Drives: Hot Lava Fr-s
Like Shadow said, having 2 people makes things alot smoother.
Iceblazer is offline   Reply With Quote
Old 08-14-2013, 11:12 AM   #5
FR-Shadow
FR-Shadow's Avatar
to install yes. To strip threads i dont know. I never ended up stripping mine. But I was very cautious.
easiest way to get the angle right is to have the hinges all the way up and then try to put the hood on that way.
3 may be even better.
2 to hold and 1 to put in the bolts
Old 08-14-2013, 11:22 AM   #6
Frs32907
The latch doesnt need to be transfered?
Old 08-14-2013, 12:45 PM   #7
FR-Shadow
FR-Shadow's Avatar
Nope everything is already there ready to just change out 4 bolts.
Now if you had hood pins thats your own doing and will obviously take time. Whether its required will be argued up and down.
Just a little hint: i dont have hood pins and just drove from Phoenix to 86fest and back and the hood didnt move. In fact it shakes less than the OEM hood did.
Old 08-14-2013, 02:49 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Where did you find this? Their site doesn't show any BRZ/FRS category. I'm interested to know what is out their besides Seibon.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-14-2013, 02:51 PM   #9
FR-Shadow
FR-Shadow's Avatar
Outkast garage sells them.
And ShowstopersUSA
The Following User Says Thank You to FR-Shadow For This Useful Post:
Cjymiller (08-15-2013)
Old 08-14-2013, 07:48 PM   #10
Frs32907
So i just installed the vis ams hood. Install was relatively easy adjusted the hood levelers a bit and it fit great. Easiest thing ive done. Quality is amazing
Old 08-14-2013, 09:40 PM   #11
khan
khan's Avatar
Drives: FRS 10 Series
Pictures! Would like to see how it looks
khan is offline   Reply With Quote
Old 08-16-2013, 11:06 AM   #12
FR-Shadow
FR-Shadow's Avatar
Installing the q300 myself hunter3232792 Engine, Exhaust, Transmission 16 12-08-2013 09:24 AM
Hood pins with vis hood or is it okay Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2013 08:02 PM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-29-2013 11:25 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 02:47 AM
