#16690 |
Kuruma Otaku
How long of a wait until Xbox1/PS4?
Because titanium. |
#16691 |
Member of the year - 2016
Drives: Scion FRS
Are there any diecast FRS models that are Ultramarine?
#16692 |
Drives: Firestorm FR-S (MT)
I would probably trust a refurb PS3 more, but it is an extra $50. Tough choice. Since you're asking, i'll assume the price difference isn't an issue. I'd get the PS3, especially if it's the 1st gen PS3.
#16693 |
Wayward Member
Drives: Hot Lava 86
Despite it's weight, the 300 isn't that bad at stopping.
#16694 |
I just got stumped... my bimmer loves burning oil as of late, I've already replaced all the seals and it ain't leaking, I replaced the PCV valve about a year or 2 ago, and I just did a compression test and got 190+ PSI across all cylinders, the head gasket is fine as well (no chocolate milk oil)
Anyone got any bright ideas? |
#16695 | |
Drives: Attitude
Headgaskets doing okay? Valve cover? |
#16696 | |
Headgasket is perfect, otherwise I would have oil and coolant mixing (Symptom numero 1 for headgasket failure on an M54 engine) Valve cover and gasket are about a year old (the original cover cracked...) May just try replacing the CCV valve... again... what a PITA... a Quart between 750 and 1000 miles is just ridiculous! |
#16697 |
Site Moderator
Drives: ichi 86 Project
Got home from 86Fest... I am exhausted... I wanna hit the bed, but before that, I need to go through 300~400 photos I've taken.
Gonna be long night... |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | kanundrum (08-14-2013) |
#16698 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
How can you tell?! Should I be concerned if my oil is Hebrew?
#16699 |
| The Following 2 Users Say Thank You to Luis_GT For This Useful Post: | Anthony (08-14-2013), IntotheOcean (08-14-2013) |
#16700 |
Weight Nazi
I'll have to check. I thought they were all made in Japan, but I would end up with the one Egyptian one in existance, then load it down with disgruntled Jewish slave oil. Ah, mechanical issues...
| The Following User Says Thank You to Anthony For This Useful Post: | Luis_GT (08-14-2013) |
#16701 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Did Mizuno-san take a direct stab at Tada-san in this statement???
[ame="http://www.youtube.com/watch?v=pxUCILsTv5s&t=1671"]Nissan GT-R Supercar On Budget - YouTube[/ame] (It's at 27:53) He says, "Anyone that tells me that a good car is light, with a low power-to-weight ratio, is an amateur." and then he does this shifty eyes thing and looks kinda at the camera... lol, the Kings of Japan seem to have some beef...
- The Ancient BRZ Sacrament by Zaku |
#16702 |
Drives: N/A
So Monday I spent 8 hours of my day in a 2 man canoe, fishing. 16 feet of floating real estate to myself was luxurious. The sunburn is starting to huuuurt. D:
I went to Nashville on Friday. I found some time to sit in the used BRZ limited at the Subaru dealership. It was pretty cramped inside. The seat was lowered all the way and the steering wheel as high up as possible. I moved the seat until I was comfortable and there was less than 3" of leg room in the back. Which wasn't too surprising. What is surprising is how close my knees were to the steering column. :/ Any further back and I couldn't comfortably press the clutch down all the way. I'm only 6' so I dunno. Am I sitting too far forward?
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-22-2014 12:46 AM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 03:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 10:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 08:59 PM |
