View Poll Results: Which would you go with?
18x9.5 +44 Square 35 58.33%
18x8.5 Front and 18x9.5 Rear 25 41.67%
Voters: 60. You may not vote on this poll
Old 08-13-2013, 01:41 PM   #1
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
18x9.5+44 square vs 18x8.5-18x9.5+44
I'm tryin to zero in on some wheels and am torn as to what to go with.
Hopin all you guys with these set-ups can chime in as to what you think, recommend, etc..
It seems as though most are going staggered.
Beyer Subaru is offline   Reply With Quote
Old 08-13-2013, 07:11 PM   #2
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I would only stagger if the wheels I wanted didn't match each other. If you aren't doing any autocross or track time, then staggered probably won't be an issue. Narrower front tires than the rear introduce understeer, meaning your car when driven spirtedly will push through the turn and not bite. This may or may not bother you.
Here's 18x9 +45 offset square on my FR-S:
At this offset and wheel width, I feel the front and rears are close enough to not require staggered wheels and offsets. Also, you don't have to worry about tire rotation issues or worry about matching tire sizes ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Beyer Subaru (08-13-2013)
Old 08-13-2013, 07:16 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The car came with a square setup, stick with a square setup.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Beyer Subaru (08-13-2013), John.Hong (08-15-2013), tinma (08-13-2013), TrogDor the Burninator (08-13-2013)
Old 08-13-2013, 07:49 PM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
car came with crappy tires, should we stick with them?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following 4 Users Say Thank You to WolfsFang For This Useful Post:
Ammonia (08-15-2013), Beyer Subaru (08-13-2013), hmong337 (08-15-2013), microbionic (08-20-2013)
Old 08-13-2013, 07:52 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sure, if the other option is going with a staggered setup that just creates more understeer.
Old 08-13-2013, 08:32 PM   #6
OrangeJuleas
OrangeJuleas's Avatar
Is there a particular reason you want this tire width? Aside from being expensive, they're also heavier. If I had to pick it would be a square 8.5 setup (square to prevent mean understeer, and allow for rotation, 8.5 because 9.5 in the front might cause rubbing issues).
Listen to @King Tut, he knows what he's talking about.
I'm not insane, in fact I'm kinda rational, when I be asking y'all, "Where did all the passion go?"
OrangeJuleas is offline   Reply With Quote
The Following User Says Thank You to OrangeJuleas For This Useful Post:
Old 08-13-2013, 09:04 PM   #7
Beyer Subaru
I haven't even started to speculate tire width. I am just trying to work through the wheel set-up first then I'll bug you guys about what you recommend for tires.
I want the 9.5 to fill-out the wheel wells. Right now I have 18x8 set-up with 20mm spacers. Spacers bug the ish outta me and I want a more true set-up that gives me the more flush look I want without spacers.
I'm really not a fan of the sunken in look. No, I won't be auto crossing or tracking the car. It's my daily and I'm shooting for a blend of form=function and not really one over the other if possible.
Old 08-13-2013, 09:15 PM   #8
coyote
coyote's Avatar
Drives: Slowly
Then you're approaching things back to front (most people do).
Tyres first. Everything else (wheels, brakes, suspension, etc) is a function of that.
Stock power or FI? That matters too.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
Beyer Subaru (08-14-2013)
Old 08-13-2013, 10:28 PM   #9
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
Just ordered 18x9.5 +44 offset square wheels from Wheeldude. He mentioned that x9.5 +44 will not clear stock struts in the front. You either need a small spacer or aftermarket coilovers.
if anyone has experience with this please chime in
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
The Following User Says Thank You to ShoGun For This Useful Post:
Old 08-13-2013, 11:18 PM   #10
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
18x9.5 all around with 255/35s all around.
Fills the whole fender wells. Tires have very minor stretch (depending on which tire). Flow the function and form you're looking for.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 08-14-2013, 11:10 AM   #11
Beyer Subaru
Thanks for the input but it is what it is. Stock power.
I'm on coils. So I should be good to go there.
Word. Thanks. Will this require fender work? I'm shootin for a set-up that won't require fender work or ridiculous amounts of camber.
255 seems to me a bit wide for the fronts?
Old 08-14-2013, 11:52 AM   #12
djdnz
1337
Drives: 2013 BRZ WRB S/C
It will be fine, there's a few people on here with 265/35/18 in the front on a 9.5+40 with coils. You will be okay with 255's and a lower offset.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Old 08-14-2013, 11:57 AM   #13
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I went staggered and I wish I had gone square, purely for looks.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
Old 08-14-2013, 12:05 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
He is probably correct. Here is a picture of my 9.5 +40 and you will be 4 mm closer:
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Beyer Subaru (08-15-2013), ShoGun (08-15-2013)
Considering going from 18x8.5ft/18x9.5back to 18x9.5 squared what to expect?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-18-2013 11:10 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 10:52 AM
17X9 SQUARE OR 18X8.5F AND 18X9.5R DAN_BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-03-2013 02:33 PM
WTB: TE37SL 18x9.5 +40 Square triwoody Wheels and Tires 1 04-18-2013 11:23 PM
