Old 08-10-2013, 08:23 AM   #407
Allch Chcar
Drives: N/A
It only takes 20 years to be considered a classic.
The FA20 was built with a mind towards clean emissions. Toyota has their "environmentalist" credentials to consider. Hence the Toyota D4S system under the squidcap instead of the Subaru Direct injection system. If they had wanted to build a higher output engine or a turbocharged engine they very well could have.
The peak HP isn't as important as the torque curve anyway. And the FA20 has good torque for an engine of this displacement. Better than any Honda.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline
Old 08-10-2013, 09:29 AM   #408
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by jcX4ever View Post
Your whole point is good but your example is wrong. The Rotary engine 3 phase/stage/cycle which are the Intake, compression/ignition and Exhaust.
Um, without a power stroke, the engine can't make any, um, POWER. Rotary is indeed a 4-cycle engine with intake, compression, POWER, and exhaust cycles.
If they say 1.3L displacement, it is not. It is actually 1.3L x 3 = 3.9L (at least arguably)..
No no no. Some people suggest that, not because of three "phase/stage/cycles", but because of the three-lobed rotors, thinking that they all go through the 4-cycles each crank rev. But the rotors spin at 1/3 crank speed, so only one chamber goes through all 4-cycles each crank rev.
The 3 phase/stage/cycle happens all at the same time. Unlike in a regular engine, it will only be doing 1 phase/stage/cycle at a time.
No, the rotors do NOT go through all cycles at the same time. As the rotor spins, it goes through intake, compression, POWER, and exhaust cycles in order. How on earth could that all happen at the SAME TIME? There is some overlap of cycles, but then there also is in a 4-stroke piston engine (intake blends into compression, with intake valves still slightly open even as the piston starts to come up, exhaust stroke blends with intake as both valves are open at the same time around TDC).
So a 3.9L making 255hp is OK but not the greatest.
It's not a "3.9 liter". It is a 1.3 liter engine that aspirates its full displacement every crank rev (as opposed to 4-stroke piston engines that require two crank revs to aspirate their displacement).
TL;DR.. a displacement in Rotary/wankel engine does not equate or reperesent the regular 4 stroke engine displacement.. (at least arguably)
Like 2-stroke piston engines, the rotary does have an inherent power production advantage per displacement because they both aspirate their full displacement every crank rev, where 4-stroke piston engines require two rull crank revs. This doesn't quite amount to a 2x advantage, though, more like 1.5x. RX-8 engine vs. F20C is a good example. both make about the same power (F20C a bit more), the RX-8's rotary making it with 1.3 liters vs. the F20C's 2.0.
ZDan is offline
Old 08-10-2013, 10:05 AM   #409
CSG Mike
CSG Mike's Avatar
I can give you 1000 lb/ft torque if you give me a few 2x4's. Think I can push a car faster than 140mph?
CSG Mike is online now
Old 08-10-2013, 10:54 AM   #410
Allch Chcar
Drives: N/A
It's usually classed as a 2.6L compared to the standard piston engine. You can argue that the true displacement is 1.3L all day but it's a piston world. For all intensive purposes, it's a 2.6L engine.
You're still thinking peak, just peak torque instead of peak power. It's all about the duration, hombre.
What is this thread even about anyway?
-Allch Chcar
Old 08-10-2013, 08:52 PM   #411
CSG Mike
CSG Mike's Avatar
Work over time.... is horsepower.
Old 08-11-2013, 01:28 AM   #412
jcX4ever
X-Lurker
Drives: 2zz MRS
Not entirely correct. It all depends on what application and goal you want. For example, F1 cars.. they have a serious horsepower relative to their mediocre torque (but that 250-290ft/lb peaks at around 14k rpm). Now compare this to a truck that peaks 250-290ft/lbs at 2000 rpm.. different applications changes what is important.
If you want to win rolling races in the freeway, an engine with peak torque at higher RPM (6500 rpm) should win you more than an engine with peak torque at lower rpm (2000 rpm) -- this assuming that both engine are rated the same power and have around 12lbs/hp power to weight ratio. The engine that has a peak torque at higher rpm also gives you higher trap speed and top speed and longer power band (at high rpm).
However, an engine that has a peak torque at low rpm is better at towing, hauling or rock climbing application. Probably will get a better 0-60ft head start but are usually slow in accelerating at high speed.
Remember that HP is a function of Torque.. so where ever the torque peaks, the HP curve is always affected.. HP and TQ will always meet at 5252 rpm.. (using lbs, ft, hp .. as units of course).
jcX4ever is offline
Old 08-11-2013, 04:44 AM   #413
ZDan
ZDan's Avatar
Drives: '23 BRZ
It's a 1.3 for most intents and purposes. Only 4stroke pistonheads with inferiority complexes insist on calling it a 2.6, or even more incorrectly a 3.9. Nobody ever called a 250cc 2-stroke a "500cc", neither should the 1.3 rotary be called a "2.6".
The 2-stroke and the rotary both have the advantage of aspirating their full displacement every crank rev. It would make more sense to refer to a 2.0 4-stroke piston engine as a 1.0 liter than to call a 1.3 rotary a 2.6, or a 250 2-stroke a 500.
In both the 2-stroke and the rotary cases, thermal and other issues don't quite give them the 2x advantage, though. It's more like 1.5x, a bit less, really. A 1.5x equivalency factor (1.5x1.3 => 2.0) for competition purposes would make more sense than a 2x factor (2.6), to be as fair as possible. But it's still physically a 1.3.
ZDan is offline
Old 08-13-2013, 01:39 PM   #414
Allch Chcar
Drives: N/A
I'm not saying anything that disagrees with the fact that it does in fact displace 1.3L or that it is a 2-stroke. I know that 2-stroke tend to make 1.5x the power of a 4 stroke with the same displacement. I'm just saying that for racing they tend to classify it as a 2.6L engine.
Call it an offhand comment.
-Allch Chcar
Old 08-13-2013, 04:54 PM   #415
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
So where is the REAL Brz STi?
you know the version where they lower the weight through using more carbon fiber and tuning the engine to get an extra 20-40 hp? I don't care about turbo and i'm fine with NA... just give me a legitimate STi instead of one that is just full of cosmetic "upgrades"
Stigmaru is offline
Old 08-13-2013, 05:41 PM   #416
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
"Cosmetic" implies you see it, whereas these actually have performance upgrades with parts that aren't seen. You know, like suspension. Also, bigger brakes help with brake fade over the course of tracking. Wider tires that are sticky will actually get your car to stop. Therefore the Brembos are functional as well, even in an "underpowered" BRZ.
You're talking about a "fantasy" BRZ STI until further notice.
chanomatik is offline
Old 08-13-2013, 08:55 PM   #417
Pete156
I like to eat!
It's in my garage (just don't tell anyone)
Pete156 is offline
Old 08-13-2013, 09:00 PM   #418
AznBRZer
Drives: 16 CBS WRX Limited
In my pants.
AznBRZer is offline
Old 08-14-2013, 09:41 AM   #419
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Lol, gimme a break man. The stock brakes are more than enough for track duty. All you need are track pads. And guess what, even with these fancy Brembo's you'll still need track pads...that won't come standard from the factory.
WolfpackS2k is offline
Old 08-14-2013, 11:34 AM   #420
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
^ THIS.
people think because you have more piston/surface area etc etc fancy 4 pots you can now brake harder. well guess what, you can cook the OEM brakes just as fast as you can cook stock brembo'sc i've seen it happen to cocky people all the time, people think brembo's make you invincible.
there is no replacement for good pads, SS lines, and fluids.
Jive Turkey is offline
brz forum, brz forums, brz sti, brz sti forum, brz sti forums, brz sti ts, subaru brz, subaru brz forum, subaru brz forums, subaru brz sti, subaru brz sti forum, subaru brz sti forums, subaru brz sti ts
Official: Limited Run Toyota GT86 TRD confirmed for UK vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 71 02-28-2013 08:59 AM
teased & unpleased JERZgrl88 Scion FR-S / Toyota 86 GT86 General Forum 141 10-23-2012 03:12 PM
Lotus Esprit teased Levi Other Vehicles & General Automotive Discussions 17 12-18-2011 12:28 PM
Toyota Japan 86 Official website - http://toyota.jp/86 kaspa_lee Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2011 03:56 AM
