#15 | |
Drives: FR-S 10 series
#16 | |
Drives: Some rust bucket
An out aligned toe will chew up your tires just as much, possibly more. Imagine taking a tire, face it 45 degrees, and try to drag it straight. This is an exaggerated example but you get the idea. I believe the Michelin PSS are non-directional. You can swap tires left to right and vice versa if you're worried about camber wear. Don't lower your car too much (eg., 1'' or less), and you won't get that much rear negative camber. If you do lower it a lot (eg., more than 1''), there are rear camber adjustment options. Lowering it too much may change your suspension geometry too much and actually hurt your performance, but that's an entirely different topic .
| The Following User Says Thank You to ayau For This Useful Post: | Chase86 (08-13-2013) |
#17 | |
Drives: Ultramarine FRS
Won't larger wheels cause there to be a greater difference in camber then smaller/stock wheels? |
#18 |
Drives: GMC
I'm pretty new to suspension mods, so this is all good info. I have some RCE springs on the way with OEM crash bolts and have some related questions.
@ayau You mentioned above that you were able to get -1.5* and -1.7* camber in the front... Is this with the camber adjustment slammed, or did you have it aligned to max camber, was this your final numbers? In other words, I like to do all of my own work, when I install springs with crash bolts and slam it into the most negative adjustment, is that roughly what I will get? I figure that variance wouldnt be far off from what an average alignment shop could do. I'd just be at the mercy of the factory tolerances. You also mentioned getting the toe dialed in since you are getting an alignment anyways. This doesn't change with the drop, correct? I assume this is just a recomendation. edit: Thanks! |
#19 | |
Most people get -1.2 or so when they install the crash bolts. I'm not sure what methods they used to max out the camber, but I'm guessing they simply pushed the upper rotor towards the center of the car with their hands. My mechanic maxed out camber by using the weight of the vehicle as leverage. Make sure to replace the OEM bolt with the OEM crash bolt FIRST before you do the following. -Jack up the front of the car -Loosen the 2 19mm bolts holding the hub to the knuckle -Place a wooden board that's about 4'' tall on the outer edge of the tire. -Lower the car so that the tire's outer edge sits on top of the wooden board. -The weight of the car combined with the board pushing in towards wheel should max out the camber. -Tighten the 2 19mm bolts. Your toe will most likely change when you change the ride height. Even if nothing else was changed on the suspension, the factory toe setting most likely won't be "aligned". If I recall, the assembly line only checks the alignment every nth car. |
#20 | |
PROUD OF BOXER
Drives: Raven FR-S
our cars also gain camber when lowered. it would be reasonable to assume they toe-in when lowered as well
#21 | |
I believe that's only to a point for McPherson struts. After a certain point of compression/drop, you actually gain positive camber. I'm not sure about the camber curve for the rear multi-link. |
#22 | |
Drives: GMC
Ayau, thanks for the response.
Edit: More thought... This probably has to do with the caster, thats why the toe changes with camber? (learning on the fly here) |
#23 |
Drives: 2019 Mazda Miata RF
Toe change is due to either the steering link (front) or toe link (rear) being a fixed length, and moving in an arc, which is a different radius than the arc the wheel/tire/upright is moving, much like "bump steer".
#24 |
Drives: GMC
Aaah that makes sense. As the camber increases, the top of the wheel wants to get tighter to the car and the bottom wants to get further away, so the tie rod connecting to the front of the hub (on the bottom half of the wheel getting further away) at a fixed length will pull it in. Creating toe in. Got it.
#25 |
Drives: 6MT
Installed swift springs 2 weeks ago.
For rear, SPC LCA's ($220), brought the rear back to stock spec. For front, nothing, got half a degree of negative camber after lowering. |
#26 |
Drives: Vortech Supercharged FR-S
Can anyone give me a link of those "crash bolt"? BTW, since we r going to do the four wheel alignment after changing lower springs, do we get things like crash bolt and ask mechanists in the store to change camber for us? I am going to do it at SEARS.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#27 | |
Drives: 2013 Black BRZ Limited
The crash bolts are available from Subaru for under $10. They are a factory bolt that replaces the upper strut bolt (there are two). The factory bolt in that location has a thickened shank and the crash bolt has a normal sized shank. This allows you to push the strut to adjust your camber. You should install these with the springs and have your alignment techs loosen them to adjust each side of the car. Whiteline and SPC also make crash bolts which should gain you some additional camber, but their torque settings are much lower, around 70-80ft/lbs vs 116ft/lbs for the factory crash bolts. Honestly, I think your tire size will limit how much camber a bolt can get you up front before the size of the bolt will, so I would go with the much cheaper OEM crash bolts. |
#28 |
Drives: Scion FR-S/Toyota Yaris
What about tread wear? With rce yellows or swift springs and max crash bolt front camber will you maintain stock treadwear or will it be new tire time every 10k miles (assuming you don't skid around or do burnouts.)
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| lowering springs - if you did it tell me more.. | rikdrt1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 09-23-2013 12:50 PM |
| which lowering springs should I get? | abling2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-22-2013 03:27 PM |
| TRD Lowering Springs? | kALMIGHTY | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-29-2013 11:10 AM |
| For those with lowering springs. | wawro569 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-10-2013 02:36 PM |
| Lowering springs HELP | FRS_13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-27-2012 11:03 PM |
