Old 08-11-2013, 05:53 PM   #211
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by Sensisnow View Post
I just got back from a 4 hour road trip and I'm happy to say that I didn't have any leaking issues that I know of. I smelled a whiff of e85 a few times, but I didn't see any visual indication of leaking and my car didn't burst into flames, which is always a plus. I'm still using the single thumb clamp that I purchased to replace the clamp that John provided, which was absolute garbage. I think I posted a photo of it, along with a link earlier in this thread.
Have you heard any more from @Visconti regarding the installation instructions? According to his post above, we all should have received an instructions days ago, but he seems to have disappeared. I figured you would be the first person to receive anything, which is why I'm asking.
I assume you're referring to me? I haven't heard anything from John.
post_break is offline   Reply With Quote
Old 08-11-2013, 06:08 PM   #212
Sensisnow
Drives: 05 TSX & 13 BRZ
Yeah, sorry about that. I edited my previous post to make that clear for anyone else following this thread.
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 08-11-2013, 07:14 PM   #213
chilltpr
HPDE Instructor
Ok I got the update parts on.
Taking off the black heat shield thing made the hose work a lot easier.
As for the sensor, there are 2 holes that matched up perfectly so I threw it there in the pic. I am guessing this is where they intended it to go. The screws worked perfectly.
Was easy enough and no leaks.
chilltpr is offline   Reply With Quote
The Following 3 Users Say Thank You to chilltpr For This Useful Post:
cobrabyte (08-12-2013), Sensisnow (08-11-2013), Yruyur (08-11-2013)
Old 08-11-2013, 07:23 PM   #214
Yruyur
Yruyur's Avatar
Did you cut the hardline?
Sent from a Motorola DynaTAC 8000X
The Following User Says Thank You to Yruyur For This Useful Post:
mikalem (08-11-2013)
Old 08-11-2013, 07:24 PM   #215
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Matrix flashback.....
Sent from my SGH-M919 using Tapatalk 4
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
charged86 (08-11-2013)
Old 08-11-2013, 07:26 PM   #216
Sensisnow
Thanks for the info!
What size bolt did you use to mount the sensor? I didn't receive one with my kit.
2013 DGM BRZ
Old 08-11-2013, 07:28 PM   #217
chilltpr
HPDE Instructor
Yes just below that flange/flare thing. Had to use a file to debur a little so the compression fitting slipped on. Get that bottom piece with the compression ring on first line it up by eye and put the fitting that goes on top with a socket. Compression fittings are 17mm so box wrench on bottom with a 17mm deep socket on top. Then repeat with the 3/4 adapter on top of that.
Old 08-11-2013, 07:29 PM   #218
chilltpr
HPDE Instructor
It was a self tapping screw. Sorry didnt measure the size. My kit came with it.
Old 08-11-2013, 08:21 PM   #219
Sensisnow
No bolt included with my kit.
No padding in my kit.
No responses from @Visconti or @Rich@ViscontiTuning
Now we learn from someone who has 6 posts that we have to cut the metal line, preventing any option of taking our car back to stock, therefore ruining any chance of having any warranty work done. WOW!
2013 DGM BRZ
Old 08-11-2013, 08:52 PM   #220
chilltpr
HPDE Instructor
Well if you need to take it to the dealer just use one hose and bypass the sensor. If they dont like that you can always get a flaring tool and use the stock hose assuming you didnt cut it up. I was able to get it off without slicing it.
Old 08-11-2013, 09:17 PM   #221
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
I've been hunting down a proper hose and little wonder John/Rich went with the kit's hose (i.e. took the easy route). The required hose (7.5mm ID/13.5 OD) is FACKING hard to find (here in Aus anyway). Especially one that is compatible with E85. I found one with correct dimension by Codan but the inner tube material (NBR/PVC) isn't E85 compatible. To think, they got all this leaking issues just because they were 1mm off (kit hose is 8.5mm).
Final solution for me will have to be ghetto setup with two bits of OEM pre-bent hoses. Not going to look pretty but definitely wont be any leaks.
Also one of the threaded connections near the sensor has a very tiny leak when engine is running. Thankfully I can swap it out with the coupler I couldn't use. Yet another headache to deal with. Good thing they aren't replying - I'd friggin chew their heads off at this point.
enouf is offline   Reply With Quote
Old 08-12-2013, 11:18 AM   #222
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
It's fairly simple to re-add the bubble flare back to that hard line.
I am probably going to go a different route rather than using the compression sleeve that John sent out. It will involve cutting that bubble flare off, adding a fitting, re-flare and then assemble permanent fitting. You can 'borrow' a flare tool set from most auto parts stores, since it's something that's used so rarely.
I need to take the measurements on the hardline to find out what size fittings to get but I'm looking to get this done soon and for good.
I've not had any leaks with the clamped version but I'd rather have the peace of mind.
cobrabyte is offline   Reply With Quote
The Following 3 Users Say Thank You to cobrabyte For This Useful Post:
enouf (08-12-2013), Sensisnow (08-12-2013), Yruyur (08-12-2013)
Old 08-12-2013, 07:18 PM   #223
mkivsoopra
Going with a proper 37° AN fitting? That would be the most ideal...
mkivsoopra is offline   Reply With Quote
Old 08-13-2013, 12:25 PM   #224
cobrabyte
cobrabyte's Avatar
Yeah, that's the plan. I just don't want to have to mess with it again in the future.
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
