Old 08-12-2013, 02:00 PM   #113
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Originally Posted by FRSRAVEN View Post
So we are talking about 260WHP and 185 ft/lbs of torque at 9 psi. That is on par with the Vortec and Innovate units, and makes more sense then the 280whp number that was mentioned earlier.
How I got my estimate
+54% of 200hp = 308hp (crank) - 15% for driveline loss = 260whp
+45% of 151ft/lbs = 219ft/lbs of torque (crank) - 15% for driveline loss = 186ft/lbs
Rough estimates of course...
Also, it uses a dedicated oil cooler for the Rotrex unit. Without additional knowledge, I'm assuming this is standard for Rotrex supercharger units? Anyways, it should increase reliability for track scenarios. I always wondered about the self contained oiling systems in these superchargers. That oil has gotta get pretty hot on the track...
Also I forgot to mention that according to them the 54 and 45 increase in HP and torque, respectively. Is using WHP and wheel torque. He said stock they got 185whp. So to do that math you will have to use those numbers, not the crank. The representative of Jackson, mention that all their numbers are to the wheels.
Again, this is coming from them. So if it is true and accurate, it'll be a great option.
Asphaltfrs1 is offline   Reply With Quote
Old 08-12-2013, 02:02 PM   #114
Asphaltfrs1
Originally Posted by NoppyNop View Post
They told me when I talked to them the tune it yourself kit was around 3995 which is a pretty good deal.
Yeah I could've been off on that lol
Sun was too hot. So 4k and 5k, I think that's a reasonable price if their numbers hold up.
Old 08-12-2013, 02:08 PM   #115
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
185 whp stock is by far the highest I have ever seen, so they must be using some kind of serious dyno correction factor to inflate numbers.
Old 08-12-2013, 02:49 PM   #116
Asphaltfrs1
Lol if I remember correctly that's what the guy said.
Old 08-12-2013, 02:55 PM   #117
SigmaHyperion
Drives: 2013 SWP BRZ Limited
All the more reason why I like the fact that they usually advertise their kits in terms of % gain, not absolute numbers. Plus, starting from a higher stock WHP can only hurt them, not help them, so there's no reason to exaggerate that figure if anything.
They also are apparently using a hub dyno which is fairly uncommon, and likely to lead to appreciably different readings from what we're used to seeing.
SigmaHyperion is offline   Reply With Quote
Old 08-12-2013, 03:11 PM   #118
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Both Oscars (Sr & Jr) did quote the "T-I-Y" kit as a $3995 price point. This included an intercooler, all the necessary essentials AND a SETRAB oil cooler for the SC unit.
Essentially, this is a more economically priced unit than the similar HKS setup, with an easier install (no restriction plate either) and offers us another FI option that I think might be interesting. Here are some of the pics...
What was interesting was Oscar Sr saying that they've put >12000 miles on the car with the kit already and the dyno pack (Hub Dyno) numbers I saw was about 280ish WHP / 218#s TQ (SAE corrected) and was told on two occasions that those were 91 Octane numbers, stock fueling, 9 PSI pulley.
Kit purportedly comes out in Oct 2013.
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 8 Users Say Thank You to Drift-Office For This Useful Post:
B L U E S L A T E (08-28-2013), Calum (08-12-2013), Cessblood (09-20-2013), flippy (08-23-2013), hmong337 (08-13-2013), NoppyNop (08-12-2013), ramiram1984 (10-26-2013), Yruyur (08-12-2013)
Old 08-12-2013, 04:50 PM   #119
Yruyur
Yruyur's Avatar
Is that a catch can with the blue cap in the second picture? What is the accordion looking thing in the thrid?
Sent from a Motorola DynaTAC 8000X
Old 08-12-2013, 04:58 PM   #120
Opposed
Drives: 2013 Asphalt FR-S
Looks like its the oil reservoir for the supercharger unit. The accordion looking thing may be an oil filter coming from the oil cooler???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 08-12-2013, 05:07 PM   #121
Foobar
SLO NO MO
Foobar's Avatar
Correct on both counts. You can Google the Rotrex install guide and see a diagram of the full system.
The Following 2 Users Say Thank You to Foobar For This Useful Post:
Opposed (08-12-2013), Yruyur (08-12-2013)
Old 08-12-2013, 05:38 PM   #122
jamesm
they could've taken a minute to wash the damn thing lol.
Old 08-12-2013, 08:19 PM   #123
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
For those complaining about the "look" of the kit in the engine bay: go buy a turbo
hamlet is offline   Reply With Quote
Old 08-12-2013, 08:47 PM   #124
Sully
Drives: In the market for something fun
How are rotrex different than other centrifugal superchargers? Functionally, are they the same?
Sully is offline   Reply With Quote
Old 08-12-2013, 09:12 PM   #125
DJCarbine
Thupercharged
DJCarbine's Avatar
The vortech is helical gear driven, the rotrex unit is plentary gear type.... in general, the planetary gear system of the rotrex unit will allow it to use smaller compressor wheels and spin a lot faster than a helical gear driven supercharger.
This comes at the expense of extra heat from the planetary gearset, which is why you see this kit using an oil cooler while the vortech has a simple resevoir system.
Someone correct me if I am wrong
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
civicdrivr (08-12-2013), Opposed (08-12-2013)
Old 08-12-2013, 09:26 PM   #126
Frs300
Frs300's Avatar
Drives: Pile of junk
i loved the jackson racing sc in my civic back in the day. be interesting to see what this kit does on the fa20
Frs300 is offline   Reply With Quote
Enjuku Racing - Installs Vortech Supercharger Kit Enjuku Racing Forced Induction 9 03-12-2013 01:32 PM
Anybody catch this? Stout Racing SCCA Scion FR-S w/ TRD Supercharger at SEMA BK025 Scion FR-S / Toyota 86 GT86 General Forum 68 01-30-2013 03:29 AM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
FRS Jackson MS execoll Southeast 0 09-18-2012 09:53 AM
SWP BRZ at Jackson, MS Dealership execoll Southeast 0 09-15-2012 07:17 AM
