Old 08-11-2013, 07:32 PM   #1
86TruenoFRS
Drives: Rocket Bunny v1 FRS
BC BR Extreme Low Coilovers install pics
I installed my BC coilovers today and during the process took quite a few pics of the install. its was pretty straight forward and quite easy due to it being a brand new vehicle so all the nuts/bolts broke free fairly easily! hope you enjoy!
the day I got them. I couldn't tell at first but notice how the box has 10/10 ext, that means they are extreme lows.(I almost though they were reg BRs and almost got )
first impression of the packaging wasn't that great
started with the front. this is the main setup w/ the wheel removed. the brake line and abs wires are bolted/mounted to the OEM strut.
this is the OEM struts and end links compared to the BCs
Be sure to mount the camber plates properly or you wont be able to adjust camber properly
the BCs have mounting locations just like the OEM assembly
86TruenoFRS is offline   Reply With Quote
Old 08-11-2013, 07:33 PM   #2
86TruenoFRS
the rears were a little more difficult but not bad. you have to remove the lining from in the trunk in order to gain access to the upper strut bolts. From underneath I had to remove the endlink bolts, strut bolt, and the bolt that connects the LCA to the hub. after that it was smooth sailing!
pic of the OEM assembly w/ wheel removed
and w/ trunk lining removed
comparing the OEM rear strut assembly to the BC
and the Finished result. this is out of the box no height adjustment. w/ stock wheels and tires I'm very pleased!
The Following 2 Users Say Thank You to 86TruenoFRS For This Useful Post:
klearfade (05-27-2015), mush (08-21-2013)
Old 08-11-2013, 08:30 PM   #3
Charky
Charky's Avatar
Drives: Fr-s 2013 Hot Lava
Love it looks awsome.
Charky is offline   Reply With Quote
The Following User Says Thank You to Charky For This Useful Post:
86TruenoFRS (08-12-2013)
Old 08-11-2013, 09:13 PM   #4
mfbmike
Drives: 2013 FRS, 2008 R32
Looks great. Where did you buy those, price?
mfbmike is offline   Reply With Quote
The Following 2 Users Say Thank You to mfbmike For This Useful Post:
86TruenoFRS (08-12-2013), Circuit Motorsports (08-12-2013)
Old 08-11-2013, 09:43 PM   #5
86TruenoFRS
I got them from @Circuit Motorsports pm them for price. The include free rear extenders for dampening adjustment.
The Following User Says Thank You to 86TruenoFRS For This Useful Post:
Old 08-11-2013, 09:47 PM   #6
FRS1010
Drives: 2013 FRS
Wow looks great!
FRS1010 is offline   Reply With Quote
The Following User Says Thank You to FRS1010 For This Useful Post:
Old 08-12-2013, 03:19 PM   #7
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Thinking about this set up too! If this is with no height adjustments can you still raise it? How is the ride now compared to stock?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
The Following User Says Thank You to FRS Johnny For This Useful Post:
Old 08-12-2013, 04:15 PM   #8
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
if you want somethings a bit higher "out of the box", but could actually go as lower if not lower. Opt for the normal Bc racing coilovers
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
FRS Johnny (08-12-2013)
Old 08-12-2013, 10:09 PM   #9
86TruenoFRS
I still have room to go lower and could raise it back to stock height im sure! as far as ride quality, I will let you know for sure when the springs settle and suspension breaks in. as of right now with the 10k springs its a little stiff but I need to adjust dampening a bit and see
Old 08-12-2013, 10:51 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Ok, I'm wondering how this works.. I have just a 20mm drop and I've already ruined one catback. When you go this low do you just plan to write off exhaust systems and other undercarriage bits?
Old 08-12-2013, 11:05 PM   #11
FRS Johnny
FRS Johnny's Avatar
Which catback did you ruin? I have the N1 exhaust, and the pipe sits pretty low, it will probably scrape when I drop. It's kind of a problem haha. Maybe aftermarket hangers will raise it? not sure..
Old 08-12-2013, 11:17 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
I had a system from Accelerated Performance. The lowest point was a flange. It caught on a bridge expansion joint and bent both flanges back; at the narrowest point too.
Old 08-13-2013, 06:28 AM   #13
86TruenoFRS
Driving in OH you might!lol (I'm from Cleveland so I know how the roads are) but really you just need to be prepared that you night damage stuff underneath. Down hear the roads are pretty flat and it doesn't snow so they don't have plows and salt to destroy the roads. As of right now I'm on stock exhaust w/ track pipe and have no issues but I will look into it when I go the exhaust route!
Old 08-13-2013, 06:46 AM   #14
Slash
Slash's Avatar
Drives: 2013 FRS
I drive my car lower than yours around Cleveland everyday you'll be fine. Unless you're completely oblivious to what's up ahead.
Sent from my SGH-T999 using Tapatalk 2
Slash is offline   Reply With Quote
The Following User Says Thank You to Slash For This Useful Post:
86TruenoFRS (08-13-2013)
RS*R SUPER DOWN SPRINGS AND COILOVER AND MORE! ExtremeAutowerks Brakes, Suspension, Chassis 32 12-23-2013 02:39 PM
BC Racing Extreme Drop Coilovers 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 10-16-2013 11:42 AM
FT86 Cup exhibition event results, pics, and video CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 2 01-08-2013 01:49 PM
How (NOT) to install coilovers daytrip00 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 09-06-2012 02:20 PM
HKS Exhaust install Pics gtauto AUSTRALIA 23 07-23-2012 01:51 AM
