Old 08-11-2013, 02:35 PM   #253
Suzaku
Racecomp, quick question for ya.
I just got the Cusco 4.556 final drive installed on my car last week, and since then I've noticed quite a bit of thumping and popping sounds coming from the rear end; at its worst, it sounded like I left a couple of bowling balls rolling loose in my trunk. Usually at parking lot speeds, but on a few hard right turns it's been noticeably noisy too. Has yours been like this? Not sure if you're still running the stock limited-slip differential on your car or not, but that's what I've got on mine.
Suzaku is offline   Reply With Quote
The Following User Says Thank You to Suzaku For This Useful Post:
Hawk77FT (08-11-2013)
Old 08-11-2013, 02:57 PM   #254
wootwoot
Drives: FRS
NOT normal. I have one installed and it doesn't do that.
Old 08-11-2013, 10:42 PM   #255
troek
troek's Avatar
Drives: 2012 Toyota 86
Maybe they accidentally installed a cusco limit slip
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
TouchMyHonda (02-21-2014)
Old 08-11-2013, 11:16 PM   #256
Opposed
Drives: 2013 Asphalt FR-S
Sounds like it may not have been shimmed properly.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 08-11-2013, 11:38 PM   #257
fooyc
fooyc's Avatar
Drives: GT86-JDM
the sound is like u have a straight cut gear?
fooyc is offline   Reply With Quote
Old 08-12-2013, 02:48 AM   #258
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I think you have to get that checked.
Tye300 is offline   Reply With Quote
Old 08-12-2013, 10:32 AM   #259
37
degrees
37's Avatar
Drives: 6MT BRZ
Definitely not normal. I now have an MFactory 4.67 in mine and the gears are silent. The Cusco 4.56 uses OEM MKIII Supra gears so it's not likely a manufacturing defect.
37 is offline   Reply With Quote
Old 08-17-2013, 11:17 PM   #260
Racecomp Engineering
Yeah I get some of that at times under certain circumstances. I now have 6k on this set up I think...and its no issues.
Adding WL rear diff and cradle bushings makes it sound like a racecar when you put a sequential box in gear ! Yes at times you think you are in a very prepared car, but its normal to some degree DEPENDING on the bushings you have.
Stick a go pro back there and let me hear and I can confirm.
Myles
Old 08-26-2013, 12:31 AM   #261
PantsDants
Drives: Scion FR-S A/T, Whiteout
This thread inspired me to go with a shorter final drive ratio, which I'm now in the process of acquiring the parts for. Already have my IS300 carrier, just got to source the gears and then it's off to the diff shop.
One thing I've noticed is that people are concerned about running really high rpms on the highway after installing shorter gears. That may be true for the manual, but for those of us with automatics, swapping to a 4.556 final drive has you running right around 2500 rpm at ~70 mph. The reason for this is the AT (which is an Aisin A960E) has a really tall 6th gear (.582).
I got started researching this because I noticed that on the stock final gear, I run < 2000 rpm at 60 mph, so I realized the gearing between the MT and AT had to be different, if only for 6th gear.
Long story short, I may be looking at going to 4.88. 65 mph at 2500 rpm, I can live with that.
PantsDants is offline   Reply With Quote
Old 08-26-2013, 12:39 AM   #262
zoomzoomers
zoomzoomers's Avatar
Keep us AT drivers updated with your results!
The Following User Says Thank You to zoomzoomers For This Useful Post:
NWFRS (07-22-2015)
Old 08-26-2013, 12:53 AM   #263
PantsDants
Will do, it'll probably be a few weeks before I have it all installed as I'm taking a road trip for Labor Day. I'll post a new thread with my results.
The Following User Says Thank You to PantsDants For This Useful Post:
zoomzoomers (08-26-2013)
Old 11-04-2013, 10:43 PM   #264
Originally Posted by Grimlock View Post
I'm starting to like this idea. A very good mod that would be stealthy.
Once I return from SEMA next week we start un modding my car. If you are interested in this we could maybe swap rear ends plus some. Just a thought. Doesn't get any easier than that.
if email me.
Myles
Old 11-07-2013, 02:26 PM   #265
yoruck
Drives: ford fiesta st 150
hello , have some question who somes could answear
i have now Mfactory 4.67 FD in my car install.
but that whistle like straight cut gear, my mechanical say it s like his subaru rally with competion gear box he says not normal, is this need a break in time or not.
the back lash was set like the original one.
is it bad or not
yoruck is offline   Reply With Quote
Old 11-07-2013, 10:17 PM   #266
fooyc
fooyc's Avatar
Drives: GT86-JDM
more or less is the factory cutting the gear tooth no match enough. that's why hv the sound. for track is ok but for street used they should try to cut the sound off.
The Following User Says Thank You to fooyc For This Useful Post:
DAN_BRZ (12-01-2013)
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
