Old 07-15-2013, 02:21 PM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Lightbulb TwinFoot Lamp H7017CA1000 - SOLVED - NOV.2013
Hi, guys....here is unpacking of genuine Twin foot Led for Subaru BRZ coming from Japanparts....
So, the big trouble is where wiring control unit harness (for the led harness no trouble!)
Is there guy that read and understand Japanese?
I enclose some pics and .pdf too.
I am wondering it's impossible they don't release english version!!!! The Impreza (H7010FG000) type is available in US version!!!! (but central unit harness seems to be very different). Impreza's hole is 16 mm, this one 18 mm.
UPDATE 07/17/2013
SoJ send me install guide as this part usually become part of dealer install action. Therefore they don't enclose in packaging.
Download attachment.
MANDATORY
Harness IV (http://www.japanparts.com/db/parts_d...&SEARCH_page=2) , you can find @Japanparts. So you must buy both twinfoot and accessory harness
Trap63 is offline   Reply With Quote
Old 07-15-2013, 02:35 PM   #2
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
I have the USDM version that is plug and play. H701SCA100 for the blue version.
Official install instructions.
http://stis.subaru.com/proxy/70910/p...H701SCA100.pdf
illmatic is offline   Reply With Quote
The Following User Says Thank You to illmatic For This Useful Post:
Trap63 (07-15-2013)
Old 07-15-2013, 02:41 PM   #3
Trap63
Trap63's Avatar
...thanks, quite different...
Old 07-15-2013, 03:09 PM   #4
Trap63
Trap63's Avatar
I try now to share request on Facebook, hoping to find solution in a clear translation.
My FB profile https://www.facebook.com/sstrap
Old 07-17-2013, 03:53 AM   #5
Trap63
Trap63's Avatar
Solved! the JDM fits on all BRZ, requirements: harness IV as described on first post.
The Following User Says Thank You to Trap63 For This Useful Post:
illmatic (07-19-2013)
Old 07-30-2013, 01:59 PM   #6
Trap63
Trap63's Avatar
here is the required mandatory harness!
Sent by iPhone with Tapatalk
Old 08-06-2013, 04:24 AM   #7
Trap63
Trap63's Avatar
NOT SOLVED.
Harness has come but the car side of this doesn't provide pins no. 11 and no.14
Old 08-09-2013, 07:08 PM   #8
mmontes
Drives: limited brz
DAMN IT!! WTF!! i want to do this
mmontes is offline   Reply With Quote
Old 08-09-2013, 07:10 PM   #9
mmontes
Drives: limited brz
are pins 11 and 14 the positive and negative for the led?
Old 08-10-2013, 03:30 AM   #10
Trap63
Trap63's Avatar
no, they aren't. Ground is always on module. I think that they might be map lamp and door courtesy lamp positive. As the module switch positive to ON to alternate blue led and white. I try now with tester. Last night I tried with tester (lamp) and I saw that if you wire with positive on pin 11, it switch on blue light.
Old 08-10-2013, 05:30 AM   #11
Trap63
Trap63's Avatar
Try now.....no way. Room Lamp (pin 11) fits in door light courtesy on negative, but wiring BKUp to pin2 (B+) of map light, white led doesn't go in OFF.
So it needs to identify what is this "BKUP (+B)" - pin 14. In wiring schema there is no reference to this definition.
Old 08-11-2013, 06:46 AM   #12
mmontes
Drives: limited brz
Might be for back up camera +? Just a guess tho?
Put the car in reverse, white led turns on then its ment to power a camera when ever you want to install that lol
Old 08-11-2013, 12:24 PM   #13
Trap63
Trap63's Avatar
I am afraid to break door map light dimmer (but no error on TIS)........if no help come from Japan these lamps are impossible to install.
Old 08-11-2013, 12:30 PM   #14
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
You should probably change the title of the thread back to not solved. :l
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
Trap63 (08-11-2013)
Tim Schrick tests Subaru BRZ (german, with english subs) Harlequin BRZ First-Gen (2012+) — General Topics 4 05-19-2012 09:19 PM
Toyota 86 Manual (English) dnjshin0bi AUSTRALIA 20 05-16-2012 02:50 AM
Keiichi And Tada San Speak English Pablo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 04-26-2012 01:24 PM
Presentation for the 86 w/ ENGLISH translation Mr.Jay FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-01-2011 11:40 AM
English Xlation of recent FT-86 Video spin9k FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 11-27-2011 08:39 PM
