#169 |
Drives: Scion FR-S Whiteout
Actually, just a couple of random used tires. Used because this next event I'm going to is more of a drift-practice skid-pad event and last time I went, my stock tires lost a lot of thread.
2013 Scion FR-S
#170 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | retrosmiths (08-06-2013) |
#171 |
Ok, I'll switch back to the stock tires and just keep the used ones as backup instead of the other way around. This way I'll have the same compound for all 4.
2013 Scion FR-S
#172 |
Drives: 2007 Mazda 3, New Raven FR-S 6mt
my first autox
Hi cgs mike I love reading your article its help a lot to the comunity I have a couple of question that would like your experts skill
1) on sunday I am going to my first autox the car is bone stock I just want to learn how it is and learn the car behavior any tips you can give when I arrive there, also any concern on the car i have to be aware of, i am gonna try my first time with aids of to start like that 2)I want to buy a set of coilover since I want to autox and track racing that help me on lap times but still maintain a good daily driver since some times I am gonna use it for work and the wife is gonna use it I am aware that if I buy coilover the car will be a bit stiffer and feel more bump I don't mind so wich one you can recomend me I am planning to buy 18 wheels Xxr 527 since I like them and in my area nobody run thems they are 18x8.75 35+ and on widht tires I was thinking front 225/40/18 and rear 245/40/18 since I like that stance of people watching my ass lol oh and most important a good option of tires that I go DD but take a weekend abuse and 3 hours drive lol since my tracks are far away Thanks for your time and help sorry if I miss something I am a little noob on forums |
#173 | |
2. Leave your car stock. As you drive it more, you will discover what aspects of it you want to change. At that point, start modifying. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Carlysh (08-07-2013), retrosmiths (08-08-2013) |
#174 |
Drives: 2013 FRS / 2013 427 Vert
For anyone considering trying to learn a throttle blip technique and especially for those who may have tried but were unsuccessful I have some suggestions.
Before focusing on the physical aspects, make sure you understand the why and when portion including knowing at what stage of the braking process this should occur. Hint: trail braking probably should not be on your mind at this point. Moving on to the physical side, consider breaking down the technique into steps that will build muscle memory. Start with simply braking using only the right edge of the pedal. Most people have years of stepping on the center of the pedal which needs to be unlearned before adding throttle blipping. When you are ready, try both the foot roll and traditional heel toe technique with the car sitting in neutral until you can maintain steady brake pressure while also completing a throttle blip. Next move on to an empty parking lot and add actual downshifting to the equation. This all may seem remedial but taking actual traffic conditions out of the process really contributes to skill development.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#175 | |
#176 |
Curious cat.
Drives: 86 GT base M/T - Red
Any thoughts on the effects of removing the rear sway bar and just keeping the stock front bar?
I'm wondering if it'd plant the rear nicely and allow me to push harder through the bends or whether the car might just become an over steering pig. Heard about the S2K guys doing it. Curious if it's worth looking at for our cars.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#177 |
Curious cat.
I'm wondering if it'd plant the rear nicely and allow me to push harder through the bends or whether the car might just become an understeering pig and lose the ability to rotate at will. I'd also not want to lose front grip. Heard about the S2K guys doing it for AutoX. Curious if it's worth looking at for our cars (AutoX or track, pros & cons). Currently running - coilovers (RSR), upgraded street rubber, camber + caster bushings, alignment, stock sways.
#178 |
Drives: GR86
Mike,
After you have bed-in your brake pads. Is there a way to maintain the burnishing longer using a certain braking style on the street? |
#179 |
If heated properly, the bedding should be permanent. Generally, I brake slightly later and slightly harder than "normal", and that seems to maintain the bedding for me, as well as most of the socal track crowd that daily drive on race pads.
#180 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
What does your cars alignment print sheet look like?
#181 |
#182 |
Is it a full on track animal or do you street it like that? I'm seeking something between the two I think. How does that much camber feel in straight line at high speed like over hundred?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
