#99 |
Drives: 2013 FR-S Hot Lava
Is this similar to what you guys are experiencing?
[ame="http://www.youtube.com/watch?v=1-M3fM-G6k4"]FR-S startup stumble - YouTube[/ame]
Live to drive another day
#100 |
Drives: Perrin/VORTECH Supercharger TestBRZ
its 68F in CT?
#101 | |
Drives: Scion FRS in hot lava
#102 |
Drives: 2013 WRB BRZ Premium 6MT
Not for me. With mine every once and a while I will turn the key and it will just keep trying to start up, almost like when the battery is almost dead and doesn't have enough power to start it. I turn the ignition off, back on again and it fires right up.
#103 |
Drives: Ultramarine FRS 6MT
I just experienced this start up issue at about 1450km. Cranked the engine for 4-5 seconds but didn't start. Re-cranked for 2-3 seconds after and it started. I don't think it's a battery related issue as the engine turned over strongly. I suspect it has something to do with the fuel and/or ignition system. Either the fuel is not being delivered to the cylinders and/or there is no spark from the spark plugs. Gut feeling tells me it has something to do with the new direct injection system. Maybe the high pressure fuel pump needs priming before turning over the engine although I am not sure if the direct injection is used upon start up.
#104 |
Drives: Toyota gt86
it happens yo me first time today with 4800km, I have a gt86 and pressed the button, the starter motor start, and normally in 2 seconds engine come on, but this time it has like 6 seconds to try, like there is no fuel on injectors, I don't know how to explain better.
#105 |
Drives: Currently driving a 2013 turbo Tc
No tsb on this yet my new frs has done I twice today 1500 miles on it
#106 |
Drives: Moped
#107 |
#108 |
Drives: '13 BRZ Limited
This has happened to me 5 times since I bought it back in Aug 30th. And I have a feeling if I drove it more I would have experienced a couple more times. (maybe once a month) It has done this in hot, warm, and cold weather. I never brought it into the dealership cuz I know they won't be able to reproduce it. I have the push start button system.
'13 BRZ Limited - CBS MT
********************** STX Build - OFT Stage 2 EL 93oct (etune)/TRD intake/HKS EL catless/Motiv OP/Invidia FP catted/Perrin CBE resonated/All complete Whiteline bushings/MTEC trans & clutch springs/Kartboy SS & mount/Perrin 19mm f & 16mm r/Perrin crank & assessory pulleys |
#109 |
Drives: old
How much fuel is left in the tank when this happens? Does it always occur at roughly the same fuel level, or does it not matter at all?
#110 |
It seems like it doesn't matter. It happened half tank and full, can't remember when the last time I let the tank go way down.
#111 |
Drives: Raven Scion FR-S
My car is having similar problems .... Put the key in and turn it for the gauges and BOOM goes dead. I have to reset both terminals and hopefully it will spark up and turn on.... I had the battery checked and alternator and it's fine. He said he thinks it's the alarm system since Toyota put mine in and also auto start and disconnected the security box. I had this removed in hopes of it being fixed and nothing. I'm going to put the viper system in instead of a new battery since it's fine. Please quote me if anyone has any comments or advice
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#112 |
Drives: 2007 Honda S2000, 2013 BRZ LMT
has anyone changed their battery to see if that would solve the problem?
| After Market Problem Signals Fuse Popped- Car Wont Go into Gear | ScionFR-S | Issues | Warranty | Recalls / TSB | 14 | 11-20-2012 02:34 PM |
| Car Won't Start | schtebie | Issues | Warranty | Recalls / TSB | 25 | 10-15-2012 04:06 PM |
| trunk wont unlatch | bakerr6 | Issues | Warranty | Recalls / TSB | 9 | 09-24-2012 01:32 AM |
| GTS come with push start? | adam | AUSTRALIA | 13 | 06-04-2012 03:28 AM |
| Car won't start, no spark? | #87 | Other Vehicles & General Automotive Discussions | 5 | 12-19-2011 12:29 PM |
