Old 08-06-2013, 12:10 PM   #799
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Mikem53 View Post
If the tensioner is working properly, then you should have the intended preload on the belt. I don't know enough about the install or SC system to know.. But it looks like its using the stock intended tension if the tensioner is in its normal position. Congrats on your new setup!
Yep - uses the stock preload. Its a matter of pulling the tensioner back, taking off the new belt, putting the new one on.
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
Mikem53 (08-06-2013), xjohnx (08-06-2013)
Old 08-06-2013, 12:23 PM   #800
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Apt observation. The orientation of the tensioner with the system installed in relation to it's corresponding pulleys is identical to a showroom stock FA20 engine's serpentine layout. For the belt to come out of the groove and make contact with the shield, the tensioner would have to be on its way out, completely shot or the belt would have to walk off of the side of a pulley which could only happen if something were out of alignment or loose. Other then constant hard driving/and or track use or an extreme heat environment, your belt maintenance requirements should be identical to a factory FR-S/BRZ.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
Xero-Limit (08-06-2013)
Old 08-06-2013, 01:18 PM   #801
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
The one thought I had about he belt walking off was if you don't have all the spacers correct when you install the new idler puller on the alternator it could cause the belt to walk off the pulleys.
MattF is offline   Reply With Quote
Old 08-06-2013, 01:26 PM   #802
mines13
mines13's Avatar
Yes, if assembled in the wrong order this would certainly fall under putting the belt out of alignment. I helped write that part of the manual so I hope it is clear.
Old 08-06-2013, 01:46 PM   #803
sw20kosh
Drives: 2013 Black FR-S
If I wanted to have a spare belt or two what belt and where would I go to get one?
Old 08-06-2013, 01:47 PM   #804
MattF
MattF's Avatar
I thought it was pretty clear but I could see how someone might mess it up and its the only thing I could think of causing the belt to walk off other then the supercharger tweaked somehow..
Old 08-06-2013, 01:49 PM   #805
swift996
swift996's Avatar
[ame="http://www.amazon.com/Gates-K061015-Multi-V-Groove-Belt/dp/B000C2YCXM/ref=wl_it_dp_o_pd_S_nC?ie=UTF8&colid=3R25DPLAMKZAD &coliid=I1730Q9ERKMUCY"]Gates K061015 Multi V-Groove Belt : Amazon.com : Automotive[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 3 Users Say Thank You to swift996 For This Useful Post:
ill86 (08-09-2013), mines13 (08-06-2013), sw20kosh (08-06-2013)
Old 08-06-2013, 01:59 PM   #806
mines13
mines13's Avatar
This or the reinforced version. I would stick to Gates brand but other brands like Goodyear or Continental are likely just fine as well.
Old 08-06-2013, 02:03 PM   #807
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Is there any kind of oscillation in the belt as it runs?
Subzero is offline   Reply With Quote
Old 08-06-2013, 02:07 PM   #808
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
The belt supplied with the kit is the standard belt not the reinforced correct?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-06-2013, 02:39 PM   #809
xjohnx
Grip>Slip
xjohnx's Avatar
I believe this is correct. The reinforced one is the blue one.
Link: [ame="http://www.amazon.com/Gates-K061015RB-Blue-Racing-Micro-V/dp/B000TTILZI/ref=sr_1_1?s=automotive&ie=UTF8&qid=1375814426&sr= 1-1&keywords=K061015RB"]Amazon.com: Gates K061015RB Blue Racing Micro-V Belt: Automotive[/ame]
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
evo4g63 (08-06-2013), ill86 (08-09-2013), mines13 (08-06-2013)
Old 08-06-2013, 03:36 PM   #810
mines13
mines13's Avatar
Yes, the belt in the kit is the standard version which should be just fine. The blue reinforced belt costs about 3 times as much. Keeping a spare belt and some basic tools in your spare tire well would be a good move even in a bone stock car.
The Following 2 Users Say Thank You to mines13 For This Useful Post:
evo4g63 (08-06-2013), sw20kosh (08-06-2013)
Old 08-06-2013, 03:42 PM   #811
sw20kosh
Ordered the regular one.
Old 08-06-2013, 03:45 PM   #812
evo4g63
evo4g63's Avatar
I did just that. Ran down to my local O'reilly's today and picked up an extra belt to have. I am suprised for as bad as my alt cover was chewed that the belt didn't really suffer any damage. I have since ordered a new cover and replaced. I keep checking tension and clearence now as I don't want this time happen again.
-2016 Subaru WRX
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
