Old 06-22-2013, 02:55 PM   #57
SWAMechFRS
SWAMechFRS's Avatar
Drives: 2013 Scion FR-S Asphalt 6-Spd
Installed Swift FR-S springs this morning. Got a solid 1" drop on all 4 corners. Ride is pretty much just like stock if not slightly better. Big thanks to Randy over at Evasive Motorsports for getting me the FRS
Springs. Also installed Perrin master cyl brace and transmission mount. I don't have to double pump the brakes anymore to get good pedal. Will need track time to see if the trans mount helps while shifting with a lateral load on the car.
Sent from my iPad using Tapatalk HD
Don't Text and Drive
KCCO:happy0180:
SWAMechFRS is offline   Reply With Quote
Old 06-22-2013, 02:58 PM   #58
SWAMechFRS
SWAMechFRS's Avatar
Originally Posted by VenomRush View Post
so i was trying to install the Swift Springs for the FRS and i noticed the springs on the front only fit correctly on the strut with the swift logo upside down, is that the right way to install them? or does the logo have to be right side up
Smaller coils to the top.See my pic above. Not sure if the logo stamp has to be right side up but mine was.
KCCO:happy0180:
Old 06-22-2013, 05:10 PM   #59
Anaxilus
Drives: They have four wheels
Can anyone weigh the Swifts versus stock and count the number of windings for each? Thanks.
Anaxilus is offline   Reply With Quote
Old 06-22-2013, 09:41 PM   #60
cto424
does anyone know the swift spring spring size for coilovers?
cto424 is offline   Reply With Quote
Old 07-01-2013, 12:10 PM   #61
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Just installed these springs this weekend. It's the perfect drop and I couldn't be happier with my choice. I was a bit worried about scraping on driveways (especially being in the city) now that I'm lower, but I haven't run into any issues or scraped at all yet.
Ride also feels great, definitely not harsh at all, just a tad stiffer than stock. Also sounds strange but I feel its less jarring than stock, like some of the harsh bumps are more smoothed out, whereas they hit harder on stock suspension. But maybe I'm crazy.
Only thing I'm worried about is my rear camber, cause it looks way off to me right now. Will be getting an alignment next weekend.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
The Following User Says Thank You to overlookedx For This Useful Post:
TouchMyHonda (07-01-2013)
Old 07-01-2013, 12:32 PM   #62
waterbison777
Same here; front logos were upside down. Rears were right-side up though. (FR-S springs)
waterbison777 is offline   Reply With Quote
Old 07-01-2013, 05:18 PM   #63
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
Thumbs down
Originally Posted by Coaster View Post
I got the numbers from Evasive Motorsportshttp://www.evasivemotorsports.com/mm...R_S-SUSPENSION.
Every time I go to the Swift website my computer blocks a virus.
Same here, two viruses!
GoSharks is offline   Reply With Quote
Old 07-01-2013, 05:27 PM   #64
overlookedx
Edit: Nevermind. Just got an email from Swift. My springs are installed correctly, with logo right side up on the fronts (BRZ springs)
Superfast Jellyfish
Old 07-01-2013, 06:31 PM   #65
Ben_G
Drives: Blue BRZ
scroll down at the below link...there are some pre-production springs that may help with your question about the number of windings
http://www.vorshlag.com/forums/showthread.php?t=8145
Actually, just saw production spring pics at this later updated page....
Ben_G is offline   Reply With Quote
Old 07-02-2013, 03:13 AM   #66
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
just fyi 45et and 245 tires will hit the lower spring perch on the front shocks, even more so if you add camber bolts. i was going to do the swift springs too but found that my wheel set hit the front shocks. went coilovers and now wished i didn't. the reduced suspension travel has me 3 wheelin it at almost every driveway i encounter.
Originally Posted by TouchMyHonda View Post
2.4 in the rear isn't so bad actually that may be ideal for me. I plan on getting some whiteline front camber bolts for when I snag some 17x9's. that way I am prepared.
garfull is offline   Reply With Quote
Old 07-06-2013, 11:35 AM   #67
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
Any BRZ's fitted with 18's?
ihaskrayon is offline   Reply With Quote
Old 08-03-2013, 11:21 PM   #68
garfull
garfull's Avatar
im eating my own words. ive decided to get the swift springs and 3mm spacers. i hope the 17x9 et45 will still clear with the camber bolts.
but i don't know which ones to get FRS or BRZ spring rates. i will probably never to autoX and only occasional track days but I also dont want understeer.
Old 08-06-2013, 01:39 AM   #69
_hollywood
Drives: 97 itr sold
So what is the black and white answers for the brz versus frs springs, i dont plan to autocross, i just enjoy spirited mountain driving with a tail happy preference....i am unhappy with my megan super streets and want my original great handling frs back...
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 08-07-2013, 03:11 PM   #70
altezza280t
altezza280t's Avatar
Drives: Ultramarine FR-S
if you like the tail loose then go FR-S spec. BRZ spec will make the car more neutral
altezza280t is offline   Reply With Quote
The Following User Says Thank You to altezza280t For This Useful Post:
_hollywood (08-07-2013)
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 10:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 07:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 05:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 04:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 07:15 PM
