Old 07-17-2013, 12:13 PM   #337
Diode Dynamics
Diode Dynamics's Avatar
Haha that's much better!
John C.
Diode Dynamics
Old 07-18-2013, 06:35 PM   #338
EmBoAnhRui
EmBoAnhRui's Avatar
Drives: frs
will it affect the lighting at night while driving?
EmBoAnhRui is offline   Reply With Quote
Old 07-18-2013, 06:40 PM   #339
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
No. Your not painting the actual bulb lol
Sent from my HTC One using Tapatalk 2
Scalzo is offline   Reply With Quote
Old 07-18-2013, 07:12 PM   #340
Diode Dynamics
Just don't paint the reflector surface of the high beam. If you just paint the bezel you'll be fine!
I know painting the turn signal housing looks cool but it will really decrease the visibility... make sure you get upgraded turn signals because that could be safety issue.
Tail lights are not sealed in the same way as headlights. You would need to cut them open with a dremel then reseal them. Not a fun process.
Paul
John C.
Diode Dynamics
Old 07-25-2013, 10:06 AM   #341
suaveflooder
My contribution. I'll post full pics when I can
suaveflooder is offline   Reply With Quote
Old 07-25-2013, 12:48 PM   #342
White-Out
White-Out's Avatar
Drives: '13 White-out FR-S 6MT
remove the front bumper seems to be "mission impossible" to me..
stuck at the pop behind the side marker..any tips?
is there anyone in local planning to do this soon? hit me up please.
'00 Toyota Solara V6 SLE
'13 Scion FR-S 6MT
White-Out is offline   Reply With Quote
Old 07-25-2013, 01:36 PM   #343
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Use these videos, if the side marker doesn't pop out, use a flat head and stick it into the hole, twist and push inwards and the side markers will stick out and just pull and it'll pop off. I thought it was hard but once it comes off you'll see how easy it was.
[ame="http://www.youtube.com/watch?v=xP6tbrGyN1o"]2013 Scion FRS Subaru BRZ Horn Upgrade DIY - YouTube[/ame]
Also check out this one for the screw driver method
[ame="http://www.youtube.com/watch?v=7MxukMxgPVQ"]JDM Clear Side Markers Lens - Unboxing, Install and Review - 2013 Subaru BRZ and Scion FR-S - YouTube[/ame]
Old 07-25-2013, 01:40 PM   #344
suaveflooder
Final
@White-Out, don't remove them while pulling it off. There is a little plastic tab up there that you just need a small screw driver to get to. Once the bumper is off, pull them then. You will see the metal tabs better then. I used a screw driver to push them in and the light came out pretty easily. Look in my first pic with the bumper off. They are still all the way in
Old 08-02-2013, 01:29 PM   #345
cabbagecookies
Drives: evo ix se
Anybody have a clue how long i should let the paint dry till i can drive around with my lights on? I've done this on my evo headlights but it turned out i didnt drive the car for 3 days before i reinstalled them so i didnt have to worry about melting the paint
cabbagecookies is offline   Reply With Quote
Old 08-02-2013, 02:00 PM   #346
Wes
Wes's Avatar
Dam 3 days?? lol I just let it dry for 3 hours then put it back to bake n reinstalled, nothing melted. I heated for 215 - 220 F (can't remember exactly lol) with a moist rag under it
Old 08-04-2013, 12:32 PM   #347
cabbagecookies
Drives: evo ix se
well i didnt wait 3 days on purpose, it just turned out that i didnt reinstall them until 3 days after. but just did my fr-s lights and waited like an hour and theyre fine lol
Old 08-05-2013, 07:31 PM   #348
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
So a few questions, I did mine the other day and now that they're painted there is a noticeable gap between the projector ring and the reflector. Was that there before, I didn't notice? Second, are the guts of the lights the same? I think I may have mixed up the projectors when I put them back in(I painted the rings and squirrel finders red) does it matter which side they go in? They look the same and looked to have the same part numbers. Lastly, after reinstalling everything the driver side side maker is loose and I can't figure out how to get it snug again, did I ruin the clips on it possibly?
Cade01 is offline   Reply With Quote
Old 08-07-2013, 05:08 PM   #349
Mikegraves777
Drives: 2013 Scion FRS
Does anyone do this in Monmouth ocean county area of New Jersey and if so how much u charge
Mikegraves777 is offline   Reply With Quote
Old 08-12-2013, 01:36 PM   #350
red-frsky
frstrm-frs
Drives: Red FR-S
Does Plasti-Dip also work for painting the headlights?
red-frsky is offline   Reply With Quote
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
