#29 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I'm not worried about longevity in the sense of treadwear, but I definitely don't want a hard slick tire that appears to be a healthy performance tire. I'll look into this too.
#30 | |
- Andy |
#31 | |
In the slipstream
Just say no to R888's and A048's. |
| The Following User Says Thank You to Robbie For This Useful Post: | Anthony (08-05-2013) |
#32 |
Weight Nazi
Well like I said, long lasting is not a priority. And like I didn't say, being streetable is not a priority either. But if you say grippier, you've got my attention.
#33 |
In the slipstream
Well, if you want grip, Hoosier R6's are at the top of the pile. Unless you're looking for the fastest one lapper, and then you'd get an A6. Otherwise Kuhmo V712's or BFG R1's are other similar options that are a big step up from the NT01/RA1/R888 category.
#34 |
Weight Nazi
Oh jeez. So much to research. This is my first not-a-DD car, so I'm a serious tire noob. Thanks!
(Newbie to serious tires, not a serious newbie to tires)
| The Following User Says Thank You to Anthony For This Useful Post: | CSG Mike (08-05-2013) |
#35 | ||
E.g. if you have a Lotus, NSX, or GT-R, and you want a 100TW R-comp, you have... the R888. The R888 is peakier; the NT01 is more forgiving. With a highly experienced driver and 100% dialed in setup, you'll extract marginally faster times with the R888 once the car is properly set up for the tire. The NT01 is more forgiving with minor setup errors and has a larger "sweet spot" for both tire pressure and temperature. It also heat cycles out slower (longer useful life; both tires are fastest when stickers) I prefer the NT01 as well, as does @robispec. The Maxxis RC1 is similar to the NT01; both @Evasive Motorsports and us have used them with great results. IMO, they're the fastest R-comp for when the weather is cooler. Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | Anthony (08-05-2013) |
#36 | |
Weight Nazi
#37 |
Drives: 2013 Scion FR-S Ultramarine
While I was swapping the left and right rears, I thought I'd share a picture of the mark it left on the sidewall. As you can see, it got down to about the top of the Goodyear wording. But, it still wasn't enough to rub off the sprues (the tire is still pretty new). I'm really surprised that it would have more grip than the sidewall could handle, these aren't very tall sidewalls.
http://www.flickr.com/photos/brianpo...57629116296457 Last edited by Big-B; 08-05-2013 at 12:40 PM. Reason: Picture didn't display |
#38 | |
Overthinking it
Drives: BRZ in CS
The picture you show doesn't look out of the ordinary. edit: did you have curb rash on the wheel? or just the tire? |
#39 |
The wheel never scraped, the scrub marks only go down as far as the picture shows. Which is about an inch past anything resembling a tread.
#40 | |
Are you sure this isn't from hitting a dip hard and the tire had some extra flex? |
#41 |
Drives: '13 BRZ in WRB--let's mod!!!
I'm staying off the roads in Polk County!
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#42 |
That's the $100,000 question. It was a quick corner and the sensation only lasted for a fraction of a second. I would say the sidewall laid over and it slid on the sidewall for just that fraction of a second (only about a quarter of the tire has the scuff mark). That's the best I can explain it.
| Post your rolling shots! | jeffsides | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 118 | 10-17-2014 03:57 PM |
| Lightning Red BRZ Rolling Shots | ChandlerSwyng | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 05-07-2013 08:56 PM |
| fender rolling | Andybui82 | Northwest | 0 | 03-30-2013 10:44 PM |
| Streaks down windows after rolling them down | FRS TT | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-13-2012 09:09 PM |
| A Rolling Tour of DC...aka...my Commute | sho220 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 08-17-2012 06:20 PM |
