Old 07-30-2013, 01:22 AM   #71
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by denkigrve View Post
It depends on how wide you want your wheels to be, or what you're looking for.
You could go with 18x9.5 in either 38 or 40 with 265/35 or 40/18 should be fine with your drop.
I'm getting 18x9.5 et40 all around on 255/35/18, but I'm on coils and dropped down around 32mm all around.
Thanks for the advice. Is there a reason to run 9.5" versus 8.5"? I figure 8.5 would be enough upgrade from stock but I realize I need to find an offset that sits well with the car as well.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 07-30-2013, 01:40 AM   #72
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
It's all a matter of choice and personal preference. I wanted more grip. I felt like 9.5 was about the right amount for what I wanted.
An 8.5 would be plenty and would look pretty good. I personally wanted the more concave look so I sent with 9.5. I'm not sure if you remember seeing my car at any of the meets. My current setup is 18x8 +35 and the rear wheel looks a bit tucked.
denkigrve is offline   Reply With Quote
Old 07-30-2013, 01:41 AM   #73
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Size:  122.5 KB Going back into time... SE37Ks 18x7.5 +48
mit_peid is offline   Reply With Quote
Old 07-30-2013, 01:52 AM   #74
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Now this is a quality thread...
Keep it up, chaps!
- The Ancient BRZ Sacrament
by Zaku
Old 07-30-2013, 10:43 PM   #75
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
bump
Speed Element is offline   Reply With Quote
Old 08-01-2013, 07:35 PM   #76
Speed Element
Old 08-02-2013, 12:43 AM   #77
DaveH
Drives: Scion FRS White
Volk Racing TE37SL 18x9.5 ET40 on my Whiteout FRS
DaveH is offline   Reply With Quote
Old 08-02-2013, 09:14 PM   #78
DaveH
Another photo, just took it today
Old 08-08-2013, 12:42 AM   #79
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
got impatient waiting for volks.... here's some more shots of my gramlight 57drs
eddieEndo is offline   Reply With Quote
Old 08-08-2013, 12:45 AM   #80
mit_peid
Boosted Noob
mit_peid's Avatar
Much better photo
Old 08-08-2013, 05:38 AM   #81
JD86
Drives: 2013 Toyota 86 GT
57DRs
Gram Lights 57DRs 18x9.5+38 square set up. 245x35x18 Michelin PSS.
JD86 is offline   Reply With Quote
The Following User Says Thank You to JD86 For This Useful Post:
Killerbee (08-08-2013)
Old 08-08-2013, 08:59 AM   #82
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Looks awesome. Any informations about suspension you're running? any camber? And could you maybe add a side shoot to see how much the wheels poke out in the front?
Thanks
Killerbee is offline   Reply With Quote
Old 08-08-2013, 11:17 AM   #83
JD86
Thanks
Thought this was a thread about wheels? :-p
KW V3s, 25mm drop (1 inch) all around, vorshlag camber hats, -2 degrees of camber all around.
Front is flush at the top, slight poke at the bottom, rear is sunken by about 5mm from the guard. Perfect fit in my opinion.
Old 08-08-2013, 11:24 AM   #84
Killerbee
Killerbee's Avatar
Thank you very much for this. And I agree, perfect wheels and perfect fit for the car. Very good choice
TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer eauto Wheels and Tires 316 10-15-2014 02:41 PM
Wheel Directory: Volk Racing GT-M 19x8.0 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 10:35 PM
