#43 | |
Drives: 2014 Widebody Cosworth FR-S
The thing with this system, just as anything else in the world is the nicer things cost lots of money. Manufactures can put out anything that the market wants, but with that being said if the market is not willing to pay the money for such complex systems the manufacture will not come out with it. rheomagnetic damping has been out for some time, but is only a OEM quiped system due to the high cost that less then 1% of people looking to buy an aftermarket suspension system would even want to pay the price for such technology. We are looking forward to getting our hands on this and putting it through the ringer on our shop BRZ. Should have some feedback sooner then later...only if this 1'+ of snow that we got last night would melt Kirill RallySportDirect.com |
#44 |
Drives: They have four wheels
News?
#45 |
We have them on our BRZ, but sadly I have only been able to play with them on the street so I cannot comment on their effectiveness on the track. They sure are fun to play with on the street though, we also have the optional GPS which is pretty cool too
I am super happy with them and If I get the opportunity to really test these out I will post up here, I'm hoping Mike from CSG can comment as his knowledge on suspension is much better than mine.Thanks, Rick |
#46 | |
Drives: Sterling BRZ Ltd
This EDFC definelty looks cool
| The Following User Says Thank You to mrk1 For This Useful Post: | CSG Mike (08-03-2013) |
#47 | |
What I wanted was to be able to program damper settings based on GPS location, so that I could have different damper settings for different corners at the track. Unfortunately the Active EDFC doesn't have that capability at the moment. |
#48 | |
#49 |
#50 | |
It would also be nice to know how fast they react. I know magnethereological systems have a published spec, not that I'd ever expect these to match those. |
#51 | |
There's no need for these when you're using high end dampers, but for the average FRS/BRZ owner that's on a 800-2500 dollar set of coilovers, these will help quite a bit. There's no published reaction time, but it's fast enough that you can do G-force based active adjustment. |
#52 |
Drives: GT86
This kit looks cool, although possibly a gimmick.... Price?
#53 |
http://www.tein.com/products/edfc_active.html
About $600. No info on what a 'compatible' system would be yet it seems. |
#54 |
Drives: 1985 AE86, 2013 GT86
I've just had a set of Tein Street Flex and EDFC Active Pro system fitted to my GT86.
The pro version does lateral G as well as braking and speed and uses the GPS system too for the speed. This means that when you corner the outside dampers go stiffer than the inside ones. It's a very impressive system and the manager of Tein UK came to inspect the installation and to talk me through the setup process. How my display looks, note that it displays settings for all four dampers which can adjust independently of each other. ![]() There are now three of us in the UK with the EDFC Active Pro running Street Flex coilovers. The other two have 6/6kg though I went for 5/6kg spring setup.
1985 AE86 Sprinter Trueno
2013 GT86 White Leather, MT Injen intake, Milltek Exhaust |
#55 |
Big in Japan
Drives: turBRZ
Definitely going to be my next big suspension upgrade
#56 |
Drives: FR-S stock for now
Hey guys as you know I have been working on the Bilstein Damptronics package using the CAN data and a G sensor to make the shocks reactive to all the same inputs with great success, this is the next suspension upgrade for everybody. We just got back from VIR testing and other than changing some front dampner worked perfectly going flat through the Ss. I'm working on the spring mounts and camber plates getting rid of all the clicks and bumps from the coil overs but getting close to having a product as well. The car rides like a Camry on the road and a Porsche on the track with the push of a button. I will be at Road Atl in May for the David Murry track day if anybody wants to see it.
Thanks DougW |
| The Following User Says Thank You to DougW For This Useful Post: | DAEMANO (04-13-2014) |
| Tein MonoFlex | Kenno | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-18-2015 01:17 PM |
| Frs on Tein S-Tech springs | Juanito08 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 75 | 10-22-2015 11:19 PM |
| Tein Street Advance Available | 86drift | Australia Classifieds | 26 | 02-05-2013 11:31 PM |
| eibach pro kit vs tein H tech | lbroskee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 10-04-2012 12:11 AM |
