Old 07-18-2013, 07:58 PM   #43
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by DarrenDriven View Post
That is in line with what I was told by Scion.
Yeah I think I read it from you in another thread actually haha.
It's a long shot but does anyone have any idea if USB+AUX to 30pin to RCA would ouptut video onto the BeSpoke? Or if it's even possible with tweaks?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-28-2013, 05:58 PM   #44
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
@UbSaMrC where can i order these cables? nowhere around me has female video or jus has audio that is both female or male
lbroskee is offline   Reply With Quote
Old 08-02-2013, 03:06 AM   #45
l0aded
Addicted
l0aded's Avatar
Grab a male video or audio cable and buy a coupler to change it to female. Something like this: http://www.frys.com/product/1646410;...H:MAIN_RSLT_PG
Old 08-02-2013, 10:17 AM   #46
lbroskee
lbroskee's Avatar
ya, i've since done that but now i just need to figure out where to buy pins and which wire is which (bare wire and gray wire )
Old 08-02-2013, 02:03 PM   #47
l0aded
Addicted
l0aded's Avatar
If you have the Zypr BeSpoke I recommend you just stop now but if you really want to keep going you connect wires to pins using computer parts. In your computer (fan or power button connection) there are these 2-4pin sleeves that go into the pins and fit snuggly onto the HU pins. It won't "lock" as well as a whole harness but they aren't likely to come loose.
Old 08-02-2013, 02:09 PM   #48
lbroskee
lbroskee's Avatar
So it really is impossible then?
There's gotta b someway to make that video feed work
Old 08-02-2013, 02:15 PM   #49
l0aded
Addicted
l0aded's Avatar
No idea. I had an idea when I heard Zypr model used the AUX cable for video input for the ipod. Hardware wise I think if you used the aux+usb cable to 30 pin ipod adapter -> 30pin ipod to RCA it might work but I feel like it's a longshot in terms of the software in the BeSpoke.
Another possible way I think is to use the backup camera video slot on some kind of switch except wiring your RCA video cable to it as well. So basically the same idea as backup camera on a switch except it's your AV instead.
Old 08-02-2013, 02:32 PM   #50
lbroskee
lbroskee's Avatar
O well. Then ill see if its possible on the 2014 headunit or jus give up on it
Old 08-02-2013, 02:57 PM   #51
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
For BeSpoke owners that have Zypher or whatever the hell it's called... just put in a switch and use the backup camera input for Aux.
It won't be super simple but the idea would be to have a switch with some relays. A switch could be mounted for the driver to flip and that would send 12v to the trigger wire on the head unit, it would also swap the RCA input from the backup camera to an RCA cable of your choosing.
Again this isn't rocket science. RCA input sucks and the resolution on the head unit is crap but this would be your only option.
post_break is offline   Reply With Quote
Old 08-02-2013, 03:00 PM   #52
lbroskee
lbroskee's Avatar
Never thought of that lol. It's only for an SNES so quality isn't an issue for me lol
Old 08-02-2013, 03:22 PM   #53
l0aded
Addicted
l0aded's Avatar
Is there a way to output sound using that method though? Video switching relay wouldn't be too complicated but has anyone found which pins do sound for the backup camera... if it even exists lol.
Old 08-02-2013, 03:25 PM   #54
post_break
post_break's Avatar
Not sure on sound. Also you'd have the nagging text telling to you watch your surroundings too.
Old 08-02-2013, 03:29 PM   #55
lbroskee
lbroskee's Avatar
In low def that's not too big an issue
For sound jus run it thru the 3.5mm jack with an RCA to 3.5mm converter and keep it on that input. Music still plays wen i go in reverse so should work
Old 08-02-2013, 03:46 PM   #56
l0aded
Addicted
l0aded's Avatar
Which pin do you go into though? The one in the AV Hidden Menu guide won't work for Zypr.
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
FS: Pioneer Premium Upgraded Head Unit (Not-Bespoke, Canadian option) pheoxs Audio/Visual, Electronics, Infotainment, NAV 1 03-22-2013 05:47 AM
I suppose this is an option....for someone. Pscylo Cosmetic Modification (Interior/Exterior/Lighting) 11 06-21-2012 11:34 PM
