Old 03-12-2013, 05:24 PM   #1
03Z33
drift
03Z33's Avatar
Wheel Directory: Volk Racing TE37 17x9.0 +36
I picked up the set of bronze that are 17x9.0 +36 all around, here are a few pics installed with 235/40/17 Dunlop Z2's and lowered 38mm/1.5" all around on RSR Sport*i Moto Spec Coilovers
03Z33 is offline   Reply With Quote
Old 03-13-2013, 01:13 AM   #2
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
THESE are MUCH better than the concave TE37 variants. STEPPED LIP > Concavity any day!
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
gkubed (06-28-2017)
Old 03-13-2013, 04:02 AM   #3
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I don't think big brakes will fit on this setup.... just based off the pics.
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
adprokid (04-08-2013)
Old 03-13-2013, 07:00 AM   #4
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Man that Bronze and Red look nice!
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 03-13-2013, 07:40 AM   #5
eckoflyte
Drives: Toyota 86 GTS
Bbk will not fit these wheels. They look sick, have my set on order and waiting for rays to ship em out! 17x9 +36 is correct. Ive got AD08 245/40/17 going on these bad boys.
eckoflyte is offline   Reply With Quote
Old 03-13-2013, 09:51 AM   #6
03Z33
drift
03Z33's Avatar
I have the Essex AP Sprint kit which fits with 3mm spacer. I plan to run 5mm-10mm spacer anyway as soon as I install the brakes and ARP studs.
The Following 3 Users Say Thank You to 03Z33 For This Useful Post:
B L U E S L A T E (04-08-2013), gkubed (06-28-2017), ultra (07-14-2013)
Old 04-07-2013, 10:03 PM   #7
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Hey i was wondering where you brought your bronze te37s from, they look great with red body
R2RO is offline   Reply With Quote
Old 04-09-2013, 10:15 AM   #8
eckoflyte
Did you use the essex template to measure fitment? Im going with this setup as well so curious. How much space is there with a 3mm spacer? Thinking of extended studs and hubcentric slipons. Dont want to run anything above 3mm.
Old 04-09-2013, 05:17 PM   #9
Chee-Hu
Chee-Hu's Avatar
Do want a set in bronze!
Chee-Hu is offline   Reply With Quote
Old 08-02-2013, 07:40 AM   #10
eckoflyte
Rays Volk Racing TE37V (Bronze) 17x9 +36 5x100
These just landed at my door. Yokohama Australia have run out of 245/40/17 AD08R so I'll be mounting an old set of Kumho V700 Semi's on temporarily this coming week. Photos to come!
Had to wait 5 months for these as they were custom made by Rays. The size/bolt pattern is quite unique, so I presume they made this size specifically for the 86 and it should be a perfect fit.
The Following 6 Users Say Thank You to eckoflyte For This Useful Post:
adprokid (08-02-2013), diss7 (08-02-2013), humanshield (08-09-2013), Metabrz (08-03-2013), mit_peid (08-03-2013), PRORICAN (08-08-2013)
Old 08-02-2013, 07:58 AM   #11
joshontilt
joshontilt's Avatar
*drooling!!!
joshontilt is offline   Reply With Quote
Old 08-02-2013, 07:59 AM   #12
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Nice set, what's the weight on theses?
Ny Brz is offline   Reply With Quote
Old 08-02-2013, 09:02 AM   #13
eckoflyte
Not 100% sure TBH. I'd weigh it if I had a set of scales at home which I don't. I would assume it'd be similar to other TE37 in a similar size which would be ~ 7.7kg.
Old 08-08-2013, 02:02 PM   #14
RavSpec
Drives: Rx7
RAYS TE37V - 17x9.0 +36mm 5x100 @ 17.2 Lbs
RavSpec is offline   Reply With Quote
The Following User Says Thank You to RavSpec For This Useful Post:
rcm47 (08-09-2013)
Wheel Directory: Volk Racing TE37 17x9.5 +40 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 06-03-2017 11:29 PM
Wheel Directory: Volk Racing TE37 18x9.5 +45 kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-09-2016 10:12 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 06-24-2014 09:12 PM
Wheel Directory: Volk Racing TE37 17x8.0 +36 / 17x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-06-2014 12:19 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 / 18x10.0 +44 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-16-2013 07:28 PM
