Old 07-30-2013, 11:51 PM   #1
popos1907
popos1907's Avatar
Drives: 13' FRS, 95' Nissan 240SX
Conversion spacers
I got some r33 skyline gtr rims that are just sitting in my room till my s14 comes back from paint and I wanna throw them on my frs anybody know of any good conversion spacer so I can bolt em up?
popos1907 is offline   Reply With Quote
Old 07-31-2013, 12:45 AM   #2
pitstops
Drives: SC RB FRS
kics makes some in various sizes.
pitstops is offline   Reply With Quote
Old 07-31-2013, 01:22 PM   #3
KONVERTER
KONVERTER's Avatar
If you get a spacer like that, it is going to need to be an "Adapter". Usually at least 25mm-30mm, literally bolts onto the hub and has new hub-bolts sticking out.
I have seen some 5x114.3 wheel hubs that will bolt on directly to the ft86 so there is no need for adapters... +/- $800
Kind of like 5 lug conversion kits for your S14, same thing...
KONVERTER is offline   Reply With Quote
Old 07-31-2013, 02:07 PM   #4
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
You mean this? http://www.meganracing.com/new/produ...=1580&catid=97
G_Ride is offline   Reply With Quote
Old 07-31-2013, 02:07 PM   #5
KONVERTER
KONVERTER's Avatar
exactly yes
By the time you put on a 25-30mm adapter the wheels will be sticking out ready for over fenders..
Old 07-31-2013, 02:18 PM   #6
slava
slava's Avatar
Drives: brZed
Not true. Kics makes 10mm and 15mm conversion spacers that would work perfect with R33 wheels. Depending on wheel design, you might have to cut studs.
If you decide not to do this, I would be very interested in buying your gtr wheels.
slava is offline   Reply With Quote
Old 07-31-2013, 06:29 PM   #7
popos1907
popos1907's Avatar
yea I know what ur talking about but I don't wanna change the whole hub I just wanted to do the spacer/adapter iv seen people run bmw wheels on their 240sx the same way and I also seen the r33 rims I have on frs
basically this but don't want cheap ebay stuff
http://www.ebay.com/itm/4-Wheel-Spac...7d2a96&vxp=mtr
Old 07-31-2013, 06:31 PM   #8
KONVERTER
KONVERTER's Avatar
I am no longer in the auto industry as far as performance parts go... But when I was it was at least a 20mm adapter.
If they make a spacer that is 10mm that is news to me!
Won't see me take it on a track though... I'd use them parked...
Old 07-31-2013, 06:36 PM   #9
popos1907
popos1907's Avatar
Old 07-31-2013, 06:36 PM   #10
popos1907
popos1907's Avatar
Old 07-31-2013, 06:37 PM   #11
popos1907
popos1907's Avatar
sorry bro no way will I sell em took me a long time to find a good set and got these from a buddy in japan
Old 07-31-2013, 06:40 PM   #12
popos1907
popos1907's Avatar
http://www.frsport.com/5X100-to-5X11...h_p_59987.html
well I found what im looking for let you guys know how it goes when I put the wheels on
Old 07-31-2013, 07:25 PM   #13
philstar
philstar's Avatar
Drives: Argento FR-S
15mm should work fine with the R33 wheels as long as you use the stock 215/45 tire size.
My friend used 10mm conversion spacer to put R33s on his FR-S and they fit no problem, so 15mm shouldn't be an issue. He had to cut the stock studs though if you were wondering.
And those pics of my car above are actually R33 reps that I got from Japan. Limited run by M2 Hanbai back in the day in a much less aggresive sizing so I was able to run a larger spacer so I didnt have to cut my stock studs to make them work. But now that I have confirmed that real R33's will fit, debating what to do next because I can find real ones all day and I am having trouble finding more of these reps on YAJ and I need drift spares!
philstar is offline   Reply With Quote
Old 07-31-2013, 07:35 PM   #14
popos1907
popos1907's Avatar
I really don't wanna cut the stock studs. Where did he get the 10mm at ?? Wonder if I will have to cut with 15 mm
CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) JonMotoring Wheels and Tires 102 04-30-2015 09:22 PM
Anyone Here Running the Kics 10mm 5x114 Conversion Spacers? slava Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-24-2013 02:41 AM
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 07:11 PM
Spacers grinding...? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-09-2013 03:54 AM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 05:14 AM
