Old 07-30-2013, 07:25 PM   #617
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by xjohnx View Post
I doubt the OEM catback is the restriction. @robispec is making good numbers with the stock exhaust, no? I don't recall what his exact power mods are, but I know @DeliciousTuning posted them the other day. I do remember that he was on the 70mm pulley, stock catback, stock injectors and a 65c.
If the guys at Underdog Racing respond to me and confirm it will fit (or someone takes a bunch of pictures of the stock pulley bolt pattern/ribs) and @moto-mike thinks he can safely adjust the basemap tune for the 70mm pulley, i'll grab one and have brady throw it on Friday.
I'm not sure if a new belt is needed or not though. Maybe robi or delicious can comment.
anything else i'd need (map sensor?) or should stock be fine?
Sorry for missing this post earlier. You do not need a new belt for the 70mm pulley, as the 75mm setup has a fairly tight belt and leaves room for a smaller pulley. So it is an easy upgrade.
Good luck with the tune.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
ill86 (07-31-2013), xjohnx (07-30-2013)
Old 07-30-2013, 07:26 PM   #618
DeliciousTuning
Originally Posted by jamesm View Post
What benefit is there to starting a dyno at 2000rpm? I don't think my car has seen less than 2000rpm while moving since I bought it. You'd have to be lugging it around to even see that in practice. Not good for the car to load it up at low rpm like that.
Drive an automatic, they love creeping along at super low RPM's.
Cheers,
William Knose
Old 07-30-2013, 09:28 PM   #619
xjohnx
Grip>Slip
xjohnx's Avatar
Cheers,
William Knose
Thanks! Can you share where you found the pulley?
swift996 (07-30-2013)
Old 07-30-2013, 10:07 PM   #620
s2d4
s2d4's Avatar
Why not just go direct with sprintex?
Old 07-30-2013, 10:16 PM   #621
xjohnx
Grip>Slip
xjohnx's Avatar
Can't find anyone stateside that sells them. I believe @tom@kartboy will be making some soon, is that right?
Old 07-30-2013, 10:46 PM   #622
s2d4
s2d4's Avatar
I meant just order direct if you can't find anyone in the states.
Old 07-30-2013, 11:42 PM   #623
wrxgoose
WUB WUB
Drives: 2013 Firestorm
i was looking at the first post, and started laughing at my baseline. 151/???? sorry. wish i'd gotten a better graph print out.
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
lbroskee (07-30-2013)
Old 07-30-2013, 11:43 PM   #624
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
hahaha, i jus looked at that. photo fail
lbroskee is offline   Reply With Quote
Old 07-31-2013, 12:00 AM   #625
wrxgoose
WUB WUB
if i go get another dyno at pro-dyno, that'll let me have a new baseline/max. different type of dyno though, read much higher.
Old 07-31-2013, 12:02 AM   #626
lbroskee
lbroskee's Avatar
what's the most common dyno? I'd say that would b best bet for accurate numbers compared to others if that makes sense
Old 07-31-2013, 12:04 AM   #627
wrxgoose
WUB WUB
i'd been doing my runs on a dyno-dynamics, but Pro-Dyno uses a mustang dyno.
Old 07-31-2013, 03:03 AM   #628
sw20kosh
Drives: 2013 Black FR-S
Dynojet
Old 07-31-2013, 07:32 AM   #629
xjohnx
Grip>Slip
xjohnx's Avatar
Oh, ok. That makes sense now. I was hoping the ones that Underdog carried would fit because then I could have picked it up on my way for the install. They replied last night and confirmed it would not fit.
Oh well. No worries.
Old 07-31-2013, 10:50 AM   #630
jamesm
Cheers,
William Knose
Exactly, creeping along is the only realistic case. Does anyone really care how much torque they're laying down when creeping? You'll be at very low load, low rpm, and going full throttle at 2k rpm (to actually make the number on the graph) in high gear isn't exactly advisable anyway.
It's useless knowledge if you never actually see the conditions in real life.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
