Old 07-26-2013, 11:01 PM   #127
yhng
Drives: -
ordered the BRZ set and awaiting it to be redelivered by Evasive due to a little mixup. Can't wait!
yhng is offline   Reply With Quote
Old 07-30-2013, 08:20 PM   #128
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Installed Swift FR-S springs and SPC LCAs last week and got an alignment yesterday. These are great springs with a mild drop that handle and ride very similar to stock. Highly recommended. Name:  ImageUploadedByTapatalk1375229974.202648.jpg
1010110 is offline   Reply With Quote
Old 07-31-2013, 09:57 AM   #129
peachch
Drives: White 86 Sport Plus
Originally Posted by Anaxilus View Post
Did this ever happen?
Fr. Stock spring =2.9lb
Rr. Stock spring =2.2 lb
peachch is offline   Reply With Quote
The Following User Says Thank You to peachch For This Useful Post:
Anaxilus (07-31-2013)
Old 07-31-2013, 01:37 PM   #130
chimera118
Drives: DGM BRZ Prem AT
my springs just came in yesterday. hopefully i can get them installed this weekend.
were the LCAs necessary or just an upgrade?
chimera118 is offline   Reply With Quote
Old 07-31-2013, 02:52 PM   #131
1010110
It was necessary to adjust the rear camber since there is no stock adjustment. If you don't do LCAs or a whiteline read camber kit then you will be stuck with whatever camber you get with your new springs. Most people are reporting about -2 degrees. I wanted to be able to adjust to -1 degree.
The Following User Says Thank You to 1010110 For This Useful Post:
chimera118 (07-31-2013)
Old 07-31-2013, 03:03 PM   #132
kidgogeta
Drives: FRS
-2 for me is about right
kidgogeta is offline   Reply With Quote
Old 08-06-2013, 07:30 PM   #133
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
That's weird the FRS Springs I weighed were
Front 3 lbs 9 ounces
Rear 2 Lbs 9 ounces
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-09-2013, 11:53 AM   #134
peachch
Rear 2 Lbs 9 ounces
I weighted all 4 springs. LH and RH are very close. Mine is M/T. Is your car A/T?
Old 08-10-2013, 09:08 AM   #135
tonystewart
yes at
Old 08-14-2013, 10:23 AM   #136
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Did you order those crash bolt or they came with springs. Where did u order them and are they OEM?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 08-14-2013, 11:26 AM   #137
tonystewart
Nothing comes with the springs
Old 09-17-2013, 09:36 PM   #138
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Originally Posted by BillY2KFRC View Post
Here are some pics of my BRZ spec springs installed. Very impressed with these, car dropped 1", looks great. Had the car aligned and the handling feels great, although that is probably due mostly to the lower COG and better alignment. I also just switched to summer tires (Pilot SuperSports) so those made a huge handling improvement as well. I notice absolutely no decrease in ride quality, just as a previous poster mentioned. Even over some really bad roads the car feels just as compliant and stable as it did before.
Highly recommend these springs and Evasive Motorsports.
That looks great!
All of our customers with this kit love it as well!
Corner3garage is offline   Reply With Quote
Swift Springs Fitting - SoCal Only schtebie Southern California 16 11-29-2012 03:29 PM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
FS: Swift Motorsports Motorized Plate Holder kanundrum Exterior Parts (Aero, Lighting, Etc.) 4 06-12-2012 01:12 AM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
