Old 04-01-2013, 02:12 AM   #15
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Huehuecoyotl View Post
a malfunctioning BOV could cause the results the OP of the boom thread we all just saw, tho he seemed pretty sure his BOV was working fine.
The only thing a malfunctioning bov can create is boost leak or compressor surge.
It can never cause a boost spike as it plays no part in controlling boost. That is solely the waste gates job.
The Following User Says Thank You to sw20kosh For This Useful Post:
mad_sb (04-01-2013)
Old 04-02-2013, 03:21 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ATSAaron View Post
1. throttle shut, zero boost. AKA idle or light cruise. This is when your engine creates the most vacuum. The hose going from the engine to the BOV is actually trying to suck the BOV open at this point. It is the job of the spring to prevent this. I have seen a couple threads on here about bad idles caused by BOV's being sucked open. Get stronger springs people (venders too).
I have the stiffest spring Tial makes for the 50mm Q BOV, and it can still open under high vacuum conditions.
Old 04-02-2013, 03:27 PM   #17
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
So wouldnt a diverter valve (ala VW's TSI motor) that recirculates the compressed air from the pressurized side of the turbo back to the intake side be more reliable and more efficient since it's using the already compressed air sent back to the intake side of the turbo to keep the turbo spooling? Or am I getting a recirc system confused with an anti-lag system?
Old 04-02-2013, 03:31 PM   #18
sw20kosh
Install bov before the maf. Problem fixed.
Old 04-02-2013, 05:29 PM   #19
RedLeader
RedLeader's Avatar
That failed utterly to address the question or point of my post. But thanks for trying.
Old 04-02-2013, 06:50 PM   #20
sw20kosh
No it addresses your post just fine. Recirculating the bov like you mentioned does not spool a turbo.
Since you mentioned reliability I gave you a safe and reliable way to not have issues with venting metered air. I assumed (wrongly) that you knew the very basics of turbocharging or would at least take the time to read up on how turbocharging works. As such I left out explanations.
By placing the bov before the maf (filter - turbo - bov - maf - throttleB) you avoid metered air from being lost. The air that is released was never metered by the maf.
People use recirculation valves (filter - maf - turbo - recirc valve - throttleB) because they want silent bov operation or they want to comply with emissions regulations. The recirc valve dumps metered air right in between the maf & turbo so metered air is not lost.
Old 04-02-2013, 10:35 PM   #21
superpilun
Drives: 1986 MR2
I don't mean to derail this thread but there is considerable debate over whether bov's are necessary and the extent to which not running one is detrimental to the turbocharger. There are many who believe that the fluttering sound heard when shutting the throttle with no bov is absolutely perfectly fine for the turbo, including Corky Bell and Crawford Performance. The theory is that the compressor surge which is harmful for a turbo occurs under load. For example:
[ame="http://www.youtube.com/watch?v=nCj6Spwl1CU"]True Compressor Surge - YouTube[/ame]
Those who choose to run without a bov also claim benefits such as less boost loss during shifting and better driveability.
superpilun is offline   Reply With Quote
Old 04-02-2013, 10:46 PM   #22
sw20kosh
If it wasn't detrimental to the turbo, OEMs would not use recirc valves.
Old 04-02-2013, 10:52 PM   #23
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
They are both harmful, but the surge under load will destroy a turbo much quicker. They are both making the same noise, doing the same thing.
I would never buy a turbo kit without a BOV, or a valve of some sort. Look at how many use them, and how many don't.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 07-29-2013, 02:50 PM   #24
audixieboy
Drives: frs
question
Alot over my head. I am just going to find some experts to put this in. Costly but thought I could save on the products they put in. I do alot of shopping on this site and the shirts, ties and such are very nice at the price.
http://www.aliexpress.com/item/Hong-...713915465.html
Can anyone tell me if this BOV would work?
Does it need a turbo to work?
And would i just be better off getting a UNIChip?
audixieboy is offline   Reply With Quote
Old 07-29-2013, 08:04 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So let me get this straight. You want to buy a cheapass knockoff HKS BOV from a Chinese website, but you don't know if you need a turbo.
1. No.
2. Yes.
3. For you, UNIChip would probably be the best option.
Old 07-30-2013, 10:01 AM   #26
audixieboy
Drives: frs
man, sorry if I hurt your feelings man. Take it you feed your family by selling expensive BOVs. Was just asking a question. Thanks for response. ****
Old 07-30-2013, 10:48 AM   #27
jamesm
an extremely, incomprehensibly stupid question, yes. why the hell would you need a BOV without a turbo? it seems as if you have no clue as to what the purpose of the piece your asking about is. many people find this annoying, and for good reason. you could've answered your own question just by reading the same thread you posted it in.
The Following User Says Thank You to jamesm For This Useful Post:
levifig (07-31-2013)
Old 07-30-2013, 10:56 AM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There is an Alabama joke to be made here, but I won't make it. Enjoy showing off your BOV.
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-16-2022 12:38 AM
XXR 527 18X8.75 35 OFFSET - GOLD FINISH - BLOW-OUT-PRICES!!~!~! MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 01:57 PM
Volk Racing/Gram Lights blow out sale Stav Canada Classifieds 9 11-30-2012 05:40 PM
***CUSCO COILOVERS BLOW OUT PRICING*** genometuning Brakes, Suspension, Chassis 11 10-23-2012 06:54 PM
