Old 07-18-2013, 10:48 PM   #1
abling2
Drives: toyota gt86 firestorm red
weird noise when I go up on my driveway on an angle..HELP!!!
hello folks everytime I go up my driveway on an angle I hear a noise coming from the back it seems like the traction control and i notice the rear tire is free wheelin on the air, is this normal? em i going to break something in the future? I have no choice but to go up on an angle otherwise I will scrape my bumper thanks
abling2 is offline   Reply With Quote
Old 07-18-2013, 10:50 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Are you lowered? Thats normal when your setup has no suspension travel.
When that happens try pulling the ebrake slowly
86_ZN6 is offline   Reply With Quote
Old 07-18-2013, 10:53 PM   #3
abling2
Yes bro Im lowered on H&R super sport lowering springs.. if I don't pull the ebrake will I break something?
If I pull the ebrake slowly I won't hear that crazy weird noise going up the driveway? thanks
Old 07-19-2013, 10:16 AM   #4
jadewbj
jadewbj's Avatar
I thought I was scraping my drive at first but for me it was the sound of the traction control kicking in.
jadewbj is offline   Reply With Quote
Old 07-19-2013, 01:39 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes it is normal. Welcome to the life of a limited slip differential.
-alex
infinite012 (07-30-2013)
Old 07-19-2013, 02:59 PM   #6
abling2
thanks everyone.....
Old 07-30-2013, 01:09 AM   #7
makesdrivingfunagain
My friend owns a completely stock one, and when they drive up their driveway at an angle the wheel comes completely off the ground also. No mods at all on the suspension. Nothing has broke
makesdrivingfunagain is offline   Reply With Quote
Old 07-30-2013, 01:20 AM   #8
OrbitalEllipses
Drives: Attitude
If you don't pull the ebrake, you're spinning a wheel in the air. If you pull the ebrake, you're "tricking" the diff into sending power to the wheel on the ground.
Old 07-30-2013, 03:24 AM   #9
root
Drives: Raven FR-S
-alex
I think the noise is not the LSD, esp since our is Torson without clutch plates. Sounds like what is happening is when the one wheel becomes unweighted it spins freely while the car isn't moving so the traction control detects it as wheelspin. It then pulses the brakes on that wheel to stop it.
Pulling the parking brakes should help as it slows down that wheel and gives it some resistance torque. The LSD is a torque multiplier, it will transmit 4x the torque of the wheel with less traction to the one with more, so when you give some resistance with the brake it allows some torque transfer to the wheel still on the ground. If you don't, the wheel in the air has zero torque, and 4x zero is still zero.
root is offline   Reply With Quote
Old 07-30-2013, 12:33 PM   #10
mav1178
mav1178's Avatar
What I'm saying (in a different way) is: the noise (whether direct or indirect) is the result of the LSD system working.
Not saying it's clutch packs or brakes or whatever. If you've never sat in a car with a LSD (VLSD is probably the only exception to noise here), that's what it
s like.
-alex
Old 07-31-2013, 12:49 AM   #11
Ozzman
Drives: old
It's probably the E-Diff part the traction/stability control program kicking in. The car can use the ABS system to apply the brakes to a wheel with no traction so as to help send power to a wheel with traction.
Ozzman is offline   Reply With Quote
Old 07-31-2013, 10:59 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Normal. Sounds horrible, and has made me stall the car a couple times going up my parents driveway, but it is normal.
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 08:40 PM
weird noise when i go up my driveway on an angle abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-18-2013 11:04 PM
Heard a very weird noise today FlyingFool Engine, Exhaust, Transmission 1 03-24-2013 02:08 PM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 04:15 PM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 02:46 AM
