#16171 | |
Kuruma Otaku
What the excessive movement does is mess with the balance wheel. Whipping a watch back and forth slows it down or speeds it up by adding or subtracting force that is greater than the spring is designed for. Or something...
Because titanium. |
#16172 |
Drives: Sexy Frs Firestorm M/T
I'm not sure how much longer I can hold out waiting for this car...
I know I must...but my will power has grown weak |
| The Following User Says Thank You to IntotheOcean For This Useful Post: | M-17 (07-29-2013) |
#16173 | |
Drives: '06 AM V8V Coupe
I really want to do something about my car's drivetrain...a 2ZR-FE with new 6 speed would be an improvement as they lost 10 pounds off the 1ZZ, but the 88mm stroke is still rather big. The 1ZR-FE would be nice, 78mm stroke means at 9500rpm it'll have the same piston speed as the F20C. Also I want some Yokohama S drives but the tires on the back are pretty new... |
#16174 | |
Kuruma Otaku
BTW, this is my newest: ![]() Seiko 6138 chronograph. Automatic with handwind, dual register. (Second hand isn't correct, though. Should be white.) The other one (6139) doesn't handwind, and only goes to 30minutes on the single register. Thing's as old as I am! As for the motor situation I would bet the rods and fasteners in the F20 are VASTLY superior to the 1ZR's. So don't count on the 9500rpm for long life.
Because titanium. |
#16175 |
WUB WUB
Drives: 2013 Firestorm
I was bad. I was coming back from a delivery, and i got to mess around a bit with a modded wrx. Said he had headerback exhaust. It wasnt pretty. By 75 (5 over speed limit) i had him by a bus length.
| The Following 2 Users Say Thank You to wrxgoose For This Useful Post: | IntotheOcean (07-29-2013), midnight23 (07-29-2013) |
#16176 | |
Of course the rods are much weaker (6400rpm rev limit), that's why they get thrown out and replaced with titanium MMC when I win the lottery (though supposedly ceramic particle reinforcement is not all that complicated to do, you just mix powders together and sinter, just the machining is annoying since you're trying to machine stuff that even diamond has trouble getting through). Bearings should be okay though, bore spacing is the same as the 2ZR so the crank journals should be the same or similar, aka larger per unit displacement, though something probably should be done about the oil pump (maybe steal the one off the 2AR-FE and put it in somehow, it's variable displacement too!). |
#16177 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I just saw Pimp My Ride for the first time. That explains a lot.
| The Following User Says Thank You to Anthony For This Useful Post: | Guff (07-29-2013) |
#16178 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Just finished up my brother's bike... It looks soooo sexy...
- The Ancient BRZ Sacrament by Zaku |
| The Following 3 Users Say Thank You to Guff For This Useful Post: |
#16179 |
Drives: 1985 P-Type
#16180 |
Drives: 2013 Whiteout FR-S
#16181 |
#16182 | |
Drives: Dark Grey Metallic 2013 BRZ
Have you ever seen professional slow pitch softball? its all 250-300 lb guys that look like they know their way around a bbq, but they all hit like crazy. |
| The Following User Says Thank You to RurumariGhost For This Useful Post: | Anthony (07-29-2013) |
#16183 |
Weight Nazi
Haha I thought Major League Tee Ball was a funny concept I came up with. If had thought of professional slow pitch softball, I would have still thought I came up with it. So no, I have never seen that, but it's now on the bucket list.
#16184 |
Ninja Cat Mod
I feel ya. I played 5 hours of volleyball yesterday. Got a little sunburned and my back is aching a bit. Totally worth it though.
I forgot all about the final being played yesterday, at least they won. ![]() Nice. My boy picked up a new bike and recently fixed it up. He got a Ducati 1050 for a good price, since the original owner didn't know about a recall for the bike.
Education is Important, but Race Cars are more Importanter |
| The Following 2 Users Say Thank You to M-17 For This Useful Post: | Guff (07-29-2013), ichitaka05 (07-29-2013) |
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-21-2014 11:46 PM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
