Old 07-26-2013, 12:21 PM   #5881
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I ran my stock map for a couple weeks on the P&L catted header with no issue.
CircuitJerk is offline
Old 07-26-2013, 12:26 PM   #5882
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Ryan86 View Post
Then those that have headers installed without any spacers, once you running on your stock map, the CEL comes on. I further ran readings from Torque Pro, and my Cat sensors were hitting temps of up to 750 degrees, which is 100 degrees above the normal operating temperatures I have recorded prior to installing header.
I fitted spacers today to both sensors on the header, no CEL came on while on stock map and my temperatures are back down to normal.
AFAIK, there is no temperature sensor. It's a calculated figure from various sensors so may not actually be accurate.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 07-27-2013, 12:28 PM   #5883
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by ATL BRZ View Post
You might not want to have a spacer on the primary O2 sensor since it effects fueling. It could cause the car to run poorly over time since the sensor reading may be a different AFR than actual. The spacer on the secondary sensor is fine though. I believe the CEL was triggered only by the catalyst inefficiency reading from the secondary sensor.
You are certainly correct, hit the dyno, dropped by 8kw and 10nm torque. Removed the spacer on front sensor and all went to normal.
Thanks for the advise.
Ryan86 is offline
Old 07-27-2013, 05:50 PM   #5884
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
What are you getting at the dyno now?
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline
Old 07-27-2013, 06:06 PM   #5885
dabocx
dabocx's Avatar
Drives: Scion FRS
What would be the recommend EBCS I could get for the Full blown kit? Do you all offer one?
dabocx is offline
Old 07-28-2013, 01:04 AM   #5886
Ryan86
Road Warrior
Ryan86's Avatar
Will have to go dyno run v1.14b4 again, will post results soon.
Ryan86 is offline
Old 07-28-2013, 11:10 AM   #5887
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
V1.06b3 Stage 2 installed.
This flash has a smooth quiet idle with the new EL Header.
The car feels like it has more power everywhere in the torque band, the pull is excellent.
Data log in a few days, thanks John!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 07-28-2013, 11:22 AM   #5888
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
With 91 pump gas, I got +4whp and 3wtq
The driving changed dramitacally and the car is much fun to drive, feels like another car. However, I expected at least 10whp with what I experienced with how the car felt after the tune, but the dyno proved me wrong
Oh yeah, seems there's an issue with launch control. It only works on Map 2, can't be combined with flat-foot shifting for now. I'm sure John is working on that.
Other than that, the 1.14b4 is simply amazing. This is my first Ecutak tune, and I'm happy with it (expect for the glitches)
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline
Old 07-28-2013, 11:41 AM   #5889
xjohnx
Grip>Slip
xjohnx's Avatar
Just a reminder that JV has a thread in the FI forum for discussions about his FI tunes.
http://www.ft86club.com/forums/showthread.php?t=25885
xjohnx is offline
Old 07-28-2013, 11:43 AM   #5890
xjohnx
Grip>Slip
xjohnx's Avatar
Over a previous version of Visconti's tune? or over stock?
xjohnx is offline
Old 07-28-2013, 01:00 PM   #5891
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Over stock tune. I have TRD intake, HKS front pipe and Legamax catback and managed to dyno at 172whp & 140wtq (stock tune). Last night I ran 176whp 143wtq with the 1.14b4 tune. I think it could be the crappy pump-gas or my car would need a custom tune.
Oh yeah, the TRD intake was calibrated as a stock intake.
Old 07-28-2013, 01:52 PM   #5892
popos1907
popos1907's Avatar
Drives: 13' FRS, 95' Nissan 240SX
When u guys says datalog what do you mean? Iv been running my tune for a couple of days now should I be doing something other that driving it ?
popos1907 is offline
The Following User Says Thank You to popos1907 For This Useful Post:
ft86me (07-28-2013)
Old 07-28-2013, 01:57 PM   #5893
ft86me
ft86me's Avatar
Drives: 2013 FRS
It's a procedure for when you hook your computer up to your obii port then have the computer monitor all the things that's going on with the car while you drive it. Typical you'd do a pull from a dead stop or a slow roll to red in 2nd or 3rd gear. 3rd is better to see what it's like under load , but due to speed concerns 2nd should do. You then send that file to John to have him look and make sure everything is running safely and properly.
ft86me is offline
Old 07-28-2013, 03:41 PM   #5894
Opposed
Drives: 2013 Asphalt FR-S
That's interesting. I made 12whp over my stock tune with just an intake on the super old version 1.0 last year. The pump gas version 1.14 feels like my old 1.12 E85 tune...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
