Old 04-23-2013, 12:44 PM   #99
sid325
Drives: Ultramarine FR-S 6MT
Thanks FRSFirestorm, it would help if I just looked harder...
***Just ditched my DRL's using the Napa relay. Easy and even easier to undo. Thanks to whom ever figured that out.***
Originally Posted by FRSFirestorm View Post
Disregard the red circled. I borrowed this picture from another thread. Working from memory but I'm pretty certian its located in the spot circled in yellow. Anyway it is clearly located by using the schematic underneath the lid to this fues box. Looking for DRL Relay
sid325 is offline   Reply With Quote
The Following User Says Thank You to sid325 For This Useful Post:
Hardrock4445 (07-01-2013)
Old 06-28-2013, 04:21 PM   #100
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
Originally Posted by Hardrock4445 View Post
Napa relay part # AR6034. Replace relay with this one. No drl, no trips to dealer. Not free but works.
Thank you, this did the trick for me
cantholdanymore is offline   Reply With Quote
The Following User Says Thank You to cantholdanymore For This Useful Post:
Hardrock4445 (06-28-2013)
Old 07-12-2013, 09:24 PM   #101
coachzizi
Drives: 2013 scion FRS
i have flashback LED for my turn signals, i was hoping i can somehow hook up my DRL to my turn signals and disable it on my high beams, anyone has a clue how?
coachzizi is offline   Reply With Quote
Old 07-13-2013, 05:41 PM   #102
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
Highbeam\DRL Fix: Rplacing the ECU for Early Production Vehicles (SB0009-12)
Originally Posted by drftrdie View Post
Yes you have to get the ecu replaced from the dealer for free to correct this
Thanks for the very useful lead. I went to the Dealer today, when I said "ECU replacement" they all gave me this look - you know what I mean!
Sure enough, they had a print-out of Service Bulletin # SB-0009-12 in hand and ordered the new ECU within 10 minutes from my great revelation.
I felt vindicated as I was really paranoid after breaking the news that I obtained from the Forum. You guys rock - really.
Zagmeister is offline   Reply With Quote
Old 07-14-2013, 06:02 PM   #103
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
will this also disable high beam? I would like to keep high beam but disable the auto DRL. thx.
Originally Posted by Ishii Motors View Post
Ok, I hate DRL ( Day time running lights )
So let's turn them off.
It's very simple to do, Just remove the DRL Resistor. Makes the car just that much lighter as well! lol
1. So, access the Front Right Lower panel.
2. Undo the clips and bolt pictured.
(Peel back)
3. Locate DRL Resistor connector
Unplugg and tape up.
4. Remove DRL Resistor
5. Put back together.
Simple.
Ishii
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-15-2013, 02:22 PM   #104
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
No it will not disable the high beam. Everything will be 100% normal except you won't have DRLs.
Ishii
Ishii Motors is offline   Reply With Quote
Old 07-15-2013, 02:35 PM   #105
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Did this a few weeks ago:
High beams still work.
DRLs disabled.
No issues whatsoever.
I rolled my car up on to a few 2x4s to get a decent amount of room to work underneath. Took all of 5 minutes to do it. Super easy. Thanks for the writeup!
Old 07-15-2013, 04:22 PM   #106
Figo
Figo's Avatar
Thank u man. nice job.
Ishii
Old 07-15-2013, 07:15 PM   #107
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Just throwing this out there, but what I want to do is get the DRLs to turn on the low beams. Is this even possible? I haven't really looked into it, was thinking maybe someone here has.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 07-27-2013, 11:36 PM   #108
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by greighn View Post
Silvershadow,
A big thanks for this tip. I just installed the LED DRLs in my FR-S (the ones that go where the fog lights would be) and wanted to turn off the factory DRLs without a trip to the dealer or having to disassemble the car. Your tip worked perfectly...opened the panel, unplugged the cable, taped it up and put the panel back. High beams still work as expected but no DRLs and only a few minutes to do it, no tools required!
Thanks!!!
-Gary.
I used this method today and it worked great. Pop off the little panel, unplug the cable, tape up loose end and zip tied it to frame, put panel back on.
Easy as pie!
Old 07-28-2013, 02:12 AM   #109
Inersha
Drives: Subaru BRZ Black Silica
Nice!
Inersha is offline   Reply With Quote
Old 08-13-2013, 02:31 AM   #110
coachzizi
i swapped out my turn signals amber bulbs for flash back led. I also installed HID and fog lights, but when flashback led and fogs are on at the same time, they look stupid. im going to try and find a way to spice and wire my DRL to my turn signals. ill keep an update.
Old 08-15-2013, 12:38 AM   #111
Synack
Boosted
Synack's Avatar
Drives: Sideways
Lol that's my car. Going to put my relay back in because I disabled DRL today with Techstream on my netbook.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-07-2013, 06:48 AM   #112
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
just randomly browsing through ebay i saw the drl resistor for sale, but it was called injector resistor relay. so after i found out what it does, im gonna put the unit back on because it seems like it affects more than just drl.
am i wrong? im hoping i am and saving myself alot of trouble
mrlewistan is offline   Reply With Quote
