Old 07-27-2013, 08:59 PM   #183
retrosmiths
Drives: Scion FR-S Whiteout
Quick Note: DDM Tuning H1 bulbs doesn't fit the Mini H1 projectors.
-Sent from outer space
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-28-2013, 11:32 AM   #184
Yruyur
Yruyur's Avatar
Think we found the issue. His bulb vs my bulb.
This makes sense of the pattern he was getting since the focus point is different on the much shorter bulb.
Sent from a Motorola DynaTAC 8000X
Old 07-28-2013, 11:54 AM   #185
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yep, that'll do it.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-30-2013, 07:31 PM   #186
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Did u order the same kit from the retro fit source? Which bulb is who's?
FRSfan111 is offline   Reply With Quote
Old 07-30-2013, 07:41 PM   #187
Yruyur
Yruyur's Avatar
Mine is the long one. Yes we ordered the same kit just a different bulb temperature. He contacted the retrofit source this morning and said they shipped him the wrong bulbs so they are shipping new ones to him.
The Following User Says Thank You to Yruyur For This Useful Post:
FR-Shadow (07-30-2013)
Old 07-31-2013, 03:09 AM   #188
FRSfan111
What was the temp of the ones that were so much brighter? The comparison pics was night and day.
Old 07-31-2013, 09:45 AM   #189
Yruyur
Yruyur's Avatar
6k. But we will take more comparison pics because they should be both bright once he gets the correct bulbs.
Old 08-01-2013, 02:06 AM   #190
retrosmiths
5000k should be even brighter.
Sent from my SGH-T889 using Tapatalk 2
2013 Scion FR-S
Old 08-03-2013, 01:17 AM   #191
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Got the right bulbs now 5000k @Yruyur has 6000k
FR-Shadow is offline   Reply With Quote
Old 08-03-2013, 02:17 AM   #192
retrosmiths
Awesome!
2013 Scion FR-S
Old 08-03-2013, 02:28 AM   #193
Yruyur
Yruyur's Avatar
So is our cutoff correct or should the dips line up so there is only one?
Also is it possible to "focus" the beam by moving the bulb in or our of the housing. I thought I recall the bulb sitting on something that coukd be moved via a nut.
Old 08-03-2013, 05:20 AM   #194
retrosmiths
From this pic below, I think the left one is almost perfect, except for that left side of the driver side that seems to be bowing down too much.
As for the right one, the driver side bows down the sides a bit too much on the right. The hotspot of the passenger side also seems a bit too high that the actual usable light gets lost in the cutoff.
So yeah, the top lines of both cutoffs should line up. The dips shouldn't though, the space between them should equal your headlight horizontal spacing.
I wouldn't really worry too much though, these are the Mini H1 projectors and they will rarely be perfect. I would say the left one is a 9, while the right one is 8.5.
2013 Scion FR-S
The Following 2 Users Say Thank You to retrosmiths For This Useful Post:
FR-Shadow (08-03-2013), Yruyur (08-03-2013)
Old 08-07-2013, 03:23 AM   #195
FR-Shadow
FR-Shadow's Avatar
@retrosmiths @civicdrivr
What do u think? The projectors were wide and i brought them in. I also lowered the beam to 21.5 in above the ground. My question is why is the left crisper and more blue cut off and the right side is just normal kind of
Old 08-07-2013, 03:35 AM   #196
retrosmiths
One of them needs rotation (see double side lines).
Right side, check bulb seating.
2013 Scion FR-S
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 10:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 08:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 04:16 PM
