Old 04-17-2013, 06:24 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
Visconti tune map switch relocation?
Thought I would post this for other people as well since this may be a revolving question for other people as well.
@Visconti is it possible to have my current stg1 NA tune map switching relocated to something else since I just got a sparco wheel that I will be using with a hub and quick release? I am assuming that when I put on the new wheel, my cruise control feature will no longer be available.
ft86me is offline   Reply With Quote
Old 04-17-2013, 06:31 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
yes, he has options to use your defrost button i believe. submit a ticket and they'll take care of you.
ft86me (04-17-2013)
Old 04-17-2013, 06:32 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
thank you good sir
Old 04-17-2013, 09:39 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Pics of the seats please
Old 04-17-2013, 11:35 PM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
im changing the steering wheel. not the seats.
Old 07-27-2013, 12:56 AM   #6
PANDA86
Old School Status
Drives: .
Has anything come about with the cruise control modification?...
Also, which hub did you use? TIA.
PANDA86 is offline   Reply With Quote
Old 07-27-2013, 03:13 AM   #7
ft86me
ft86me's Avatar
Drives: 2013 FRS
there is an option to route the map switching to the defroster button. mind you the on the fly deal is not really doable now since you need to be WOT then push the defroster to see how many times the CEL blinks at you. It is recommended that you map switch when the ignition key is on and engine is OFF so you don't rev the shit out of your motor.
In terms of the hub, I am using the works bell hub. Other ones I believe have a compatibility issue due to a certain slot that is needed for it to work properly.
The Following User Says Thank You to ft86me For This Useful Post:
PANDA86 (07-27-2013)
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Ecutek Tune From Visconti tonytduc Engine, Exhaust, Transmission 3 03-13-2013 08:28 PM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 05:27 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 04:22 PM
