Old 07-22-2013, 11:40 AM   #15
BRianZ
Brian
BRianZ's Avatar
Drives: '11 Frontier CC & '13 BRZ Limited
Mine was rattling, but mine came from the plastic covers over the child safety latches on the rear deck. I put some shelf-liner between the cover and the plastic piece it snaps into and the rattle is gone.
BRianZ is offline   Reply With Quote
Old 07-23-2013, 02:32 PM   #16
hyperpunx
interesting find!
Im gonna have to check this out and see if mine is rattling there.
Still need to fix the latch issue though.
hyperpunx is offline   Reply With Quote
Old 07-25-2013, 10:48 AM   #17
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
I this this issue too. But i found this out after they put padding on my left and ride airbags
1. Lithium Greese/WD-40 only works for a short time
2. Only solution: Closing the latch hard
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 07-25-2013, 12:33 PM   #18
frslee
Just drive it
Drives: 13' FR-S
Did you try using some electrical tape?
frslee is offline   Reply With Quote
Old 07-25-2013, 02:59 PM   #19
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Lithium Greese/WD-40 works for only 2-4 weeks for me too. WD-40 seems to work longer.
I've never tried closing the latch hard. Does it work until you fold down the seats again? If so, then I'll try that the next time. I applied WD-40 this week, so it will be 3 weeks or so until I can try it.
I tried blue painters tape around the hook to make them thicker. It actually made it worse.
Old 07-25-2013, 04:06 PM   #20
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I just checked mine and slamming them shut worked but i discovered the handles from the trunk access are extremely sensitive and you have to close them from inside the backseat when i tried to close it from the trunk the right latch wouldn't latch.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 07-26-2013, 01:45 PM   #21
hyperpunx
also.
when you slam the back seats, the fix only lasts a short while (at least for me). after you drive for a bit and go over some uneven pavement or cracks, the vibration will cause the issue to reoccur.
anyone else experience that?
Old 07-26-2013, 07:09 PM   #22
Sigh-on-Rice
I found in another forum about the rattle/vibration noise from the rear seat latch.
His one was caused by the black plastic piece touching the silver piece. (If you can tell what I mean from the above picture.) He got rid of the noise by applying some grease in between the 2 pieces.
This is not the case for me because mine is a popping noise and not rattle/vibration noise. But if anyone here is interested, it might work.
Old 07-27-2013, 01:05 AM   #23
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
I had this problem in my WRX. I wrapped the bar that connects the seat to the latch with electrical tape and it got rid of the rattle.
horrorbiz is offline   Reply With Quote
The Following User Says Thank You to horrorbiz For This Useful Post:
SPEEDGOD (12-13-2013)
Old 07-28-2013, 11:07 PM   #24
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
I sprayed all around but I haven't sprayed into that area specifically, I'll have to try.
Yup same here but I find that's the quickest fix
Old 12-13-2013, 12:10 AM   #25
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
I think your trick might be a good fix, I'll try that out. Thanks!
Old 06-15-2014, 02:56 PM   #26
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
I tried using Vasline it's been over 3 weeks and no noise. I'll update if there's any change.
Sent from my SM-N900W8 using Tapatalk
Old 06-16-2014, 01:42 AM   #27
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Thanks for the bump. I'll try it out.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-27-2014, 12:25 AM   #28
troek
troek's Avatar
Drives: 2012 Toyota 86
i noticed my latchers werent lining up the same on the metal bars the latch too. on the side that was affected, i folded down the seat, pealed back the carpet down by the hinge point, loosened the single bolt on top, pulled that corner of the seat as far forward as possible, and snugged it back down. the seat now shuts more solid, and the rattle/pop is gone. ill take a picture of the mentioned hinge later, i forgot to do it earlier.
troek is offline   Reply With Quote
The Following 2 Users Say Thank You to troek For This Useful Post:
husker741 (06-28-2014), SPEEDGOD (06-27-2014)
Reviews on the TRD Door Latches/Stabilizer RYU Cosmetic Modification (Interior/Exterior/Lighting) 84 04-08-2022 05:41 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Rear Seat Deletes ??? KVDB31 Cosmetic Modification (Interior/Exterior/Lighting) 40 08-17-2013 09:16 AM
JDM Rear Seat Silencer ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 4 01-09-2013 12:51 PM
car seat in the rear seat? 4032pauln Scion FR-S / Toyota 86 GT86 General Forum 20 09-05-2012 08:34 PM
