Old 07-25-2013, 07:25 PM   #1
jybrd
jybrd's Avatar
Drives: 2013 Scion FRS
bespoke and sub
I have installed an amp and two 10inch subs in my car and plugged them into the first pair of outs on the back of the bespoke. I have no sub, what am I missing. Sorry its about to rain so I will also be
jybrd is offline   Reply With Quote
Old 07-25-2013, 07:28 PM   #2
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
you need to turn on the sub-w output in the stereo menu
mit_peid is offline   Reply With Quote
Old 07-25-2013, 07:40 PM   #3
jybrd
jybrd's Avatar
I did that but now i notice a p.con on my amp do i have to run that somewhere?
Old 07-25-2013, 07:42 PM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Not familiar with what is p.con... is that just the power connector? Can't be too many wires connected to an amp: 12V power, Ground, remote turn-on, RCA cables, and speaker wires. Not sure what p.con is.... unless its some sub-level control?
Old 07-25-2013, 07:43 PM   #5
jybrd
jybrd's Avatar
remote turn on where do I run that? from the amp to ?
Old 07-25-2013, 07:46 PM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
there are a few places you can go get a remote turn on, but from the stock stereo I would go to one of two places: 1.) splice into the remote turn-on signal for the stock amp (I believe its the brown wire), 2.) splice into the ACC signal going to the stereo and run it to where your amp is. This is simply a 12VDC signal that goes to 12V when the stereo is on to turn on your amp.
Old 07-25-2013, 07:49 PM   #7
jybrd
jybrd's Avatar
Could this be my issue why my amp isnt getting power at all?
Old 07-25-2013, 07:55 PM   #8
jybrd
jybrd's Avatar
No luck. Wired that in and still no power. Fuses are good. Im lost
Old 07-25-2013, 07:55 PM   #9
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
Yes, the amp will not turn on without a remote wire connected. It's key'd on power so the amp only comes on when your car turns on. Otherwise you have an amp that is powered on at all time, car on or off. You can do a quick test to see if this is the issue. Insert a wire into the REM lug on the amp, tap the other end to the 12v constant (power wire for amp) and see if it trips the relay to power the amp.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 07-25-2013, 08:02 PM   #10
FRSPirate
FRSPirate's Avatar
I had a problem using the rem line outs from the head unit and the door speaker amps so i ran a wire from one of the key'd on fuses to the amp. Here this picture might clear things up. One thing, on this image it shows the REM line on the amp as the one of the end lugs on the amp... Some amps have the REM lug in between the 12v and ground so make sure you verify how each lug is marked.
-Alex
05 Raven R6
13 Raven FRS M/T
Old 07-25-2013, 08:26 PM   #11
jybrd
jybrd's Avatar
Ooup, got it. Ground wire wasnt sufficient enough. Installed new one and good to go! Thank you for your help!
Old 08-29-2013, 11:50 PM   #12
Charleswinky
Drives: 2013 scion frs
hi!! would u have time to show me a pic where you put ur ground wire? coz some stupid installers drilled a hole next to the border of the fuel pump area of mine! im so pissed
Charleswinky is offline   Reply With Quote
Old 08-29-2013, 11:51 PM   #13
Charleswinky
and they also drilled a hole next to my drivers side grommet and ran RCA and power on same side!
Old 08-30-2013, 12:27 AM   #14
mid_life_crisis
Drives: FR-S 10 #103 AT
I always use an existing bolt or stud.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
USB/BeSpoke RMStringer Electronics | Audio | NAV | Infotainment 3 03-11-2013 02:07 AM
WTB : Bespoke HU, $400 LOZZI Audio/Visual, Electronics, Infotainment, NAV 2 01-05-2013 11:40 AM
Another BeSpoke HU ML Audio/Visual, Electronics, Infotainment, NAV 3 10-15-2012 11:46 AM
FR-S BeSpoke Nav Coultergeist Electronics | Audio | NAV | Infotainment 6 09-25-2012 10:39 PM
BeSpoke, what all can it do? eriktherod Electronics | Audio | NAV | Infotainment 2 06-14-2012 05:03 PM
